Bra cd-rom?
http://www.mpx.no/asp/info.asp?g0=215&g1=6...88&l=2&lantall=
BenQ 656A CD-ROM 56x IDE/ATAPI
56X max. Data Transfer Rate The CD-ROM 656A has a data transfer rate of 56X.
Flash Memory Flash Memory provides an easy solution for you to upgrade the software in your BenQ drive. Not only improving the performance of the drive but also by adding support for the latest standards and types of CD media.
Data transfer rate: 8400 KB/sec (56X) Max.
Burst:33.3MB / sec (Ultra DMA mode)
Access-time: 90ms typical
Er dette en bra cd-rom i forhold de de "vanlige" andre?
Skal få byttet min delvis defekte sony 52x cd-rom hos mpx, og skulle egentlig ha en samsung cd-rom, men så kom jeg over denne her som vare raskere og hadde flash memory....er denne fra BenQ bedre?
