TheCatIsALie Skrevet 23. september 2010 Rapporter Del Skrevet 23. september 2010 Using CPU #1 Each iteration is 12.25 MFLOPS Starting CPU stress test, Completed 1000 iterations without errors (12.25 GFLOP) Completed 2000 iterations without errors (24.50 GFLOP) Completed 3000 iterations without errors (36.75 GFLOP) Completed 4000 iterations without errors (49.00 GFLOP) Completed 5000 iterations without errors (61.25 GFLOP) Completed 6000 iterations without errors (73.50 GFLOP) No problems detected in 6598 iterations, bye! StressCPU ran 0 minutes 9 seconds. Execution halted. Using CPU #1 Each iteration is 12.25 MFLOPS Starting CPU stress test, Completed 1000 iterations without errors (12.25 GFLOP) Completed 2000 iterations without errors (24.50 GFLOP) Completed 3000 iterations without errors (36.75 GFLOP) Completed 4000 iterations without errors (49.00 GFLOP) Completed 5000 iterations without errors (61.25 GFLOP) Completed 6000 iterations without errors (73.50 GFLOP) Completed 7000 iterations without errors (85.75 GFLOP) Completed 8000 iterations without errors (98.00 GFLOP) Completed 9000 iterations without errors (110.25 GFLOP) Completed 10000 iterations without errors (122.50 GFLOP) Completed 11000 iterations without errors (134.75 GFLOP) Completed 12000 iterations without errors (147.00 GFLOP) Completed 13000 iterations without errors (159.25 GFLOP) Completed 14000 iterations without errors (171.50 GFLOP) Completed 15000 iterations without errors (183.75 GFLOP) Completed 16000 iterations without errors (196.00 GFLOP) Completed 17000 iterations without errors (208.25 GFLOP) Completed 18000 iterations without errors (220.50 GFLOP) Completed 19000 iterations without errors (232.75 GFLOP) Completed 20000 iterations without errors (245.00 GFLOP) Completed 21000 iterations without errors (257.25 GFLOP) Completed 22000 iterations without errors (269.50 GFLOP) Completed 23000 iterations without errors (281.75 GFLOP) Completed 24000 iterations without errors (294.00 GFLOP) Completed 25000 iterations without errors (306.25 GFLOP) Completed 26000 iterations without errors (318.50 GFLOP) Completed 27000 iterations without errors (330.75 GFLOP) Completed 28000 iterations without errors (343.00 GFLOP) Completed 29000 iterations without errors (355.25 GFLOP) Completed 30000 iterations without errors (367.50 GFLOP) Completed 31000 iterations without errors (379.75 GFLOP) Completed 32000 iterations without errors (392.00 GFLOP) Completed 33000 iterations without errors (404.25 GFLOP) Completed 34000 iterations without errors (416.50 GFLOP) Completed 35000 iterations without errors (428.75 GFLOP) Completed 36000 iterations without errors (441.00 GFLOP) No problems detected in 36090 iterations, bye! StressCPU ran 0 minutes 51 seconds. Execution halted. Har overklokket fra 3,16GHz, til 3,8GHz. Ca 450 FSB Hva er feilen? Kan jeg rette på det, eller må clock ned? Vil klokke maksimalt, da min GTX 480 kan yte bedre jo kjappere CPU. Har intel E8500 Lenke til kommentar
