Kaplan Skrevet 20. september 2010 Rapporter Del Skrevet 20. september 2010 Har en filserver som kjører Ubuntu, har en del disker som er montert i forskjellige mapper. Nå får jeg en feilmelding, betyr dette at disken er død? Finnes det noen stunt man kan gjøre for å berge data? Nyeste backup er nemlig litt eldre enn jeg setter pris på.... Har ikke fysisk tilgang på boksen akkurat nå. Her er feilmeldingen: orjan@boks:/home/orjan$ ls data ls: reading directory data: Input/output error Etter å ha avmontert: orjan@boks:/home/orjan$ sudo mount -a mount: wrong fs type, bad option, bad superblock on /dev/sdd1, missing codepage or other error In some cases useful info is found in syslog - try dmesg | tail or so orjan@boks:/home/orjan$ dmesg|tail [677273.904106] Buffer I/O error on device sdd1, logical block 5 [677273.904135] Buffer I/O error on device sdd1, logical block 6 [677273.904164] Buffer I/O error on device sdd1, logical block 7 [677273.906236] sd 1:0:1:0: SCSI error: return code = 0x00040000 [677273.906241] end_request: I/O error, dev sdd, sector 63 [677273.906245] Buffer I/O error on device sdd1, logical block 0 [677273.906275] Buffer I/O error on device sdd1, logical block 1 [677616.891844] sd 1:0:1:0: SCSI error: return code = 0x00040000 [677616.891852] end_request: I/O error, dev sdd, sector 65 [677616.891869] EXT3-fs: unable to read superblock orjan@boks:/home/orjan$ dmesg|grep sdd [ 25.594970] SCSI device sdd: 160836480 512-byte hdwr sectors (82348 MB) [ 25.594987] sdd: Write Protect is off [ 25.594991] sdd: Mode Sense: 00 3a 00 00 [ 25.595015] SCSI device sdd: write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 25.595072] SCSI device sdd: 160836480 512-byte hdwr sectors (82348 MB) [ 25.595086] sdd: Write Protect is off [ 25.595090] sdd: Mode Sense: 00 3a 00 00 [ 25.595113] SCSI device sdd: write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 25.595118] sdd: sdd1 [ 25.604387] sd 1:0:1:0: Attached scsi disk sdd [ 35.701544] EXT3 FS on sdd1, internal journal [373926.331009] end_request: I/O error, dev sdd, sector 12375 [373926.331915] end_request: I/O error, dev sdd, sector 12519 [373926.331949] journal_bmap: journal block not found at offset 27 on sdd1 [373926.331983] Aborting journal on device sdd1. [373926.333174] end_request: I/O error, dev sdd, sector 12423 [373926.333179] Buffer I/O error on device sdd1, logical block 1545 [373926.333209] lost page write due to I/O error on sdd1 [373942.011989] end_request: I/O error, dev sdd, sector 12375 [373942.012577] EXT3-fs error (device sdd1): ext3_find_entry: reading directory #2 offset 0 [373942.012979] end_request: I/O error, dev sdd, sector 63 [373942.012985] Buffer I/O error on device sdd1, logical block 0 [373942.013014] lost page write due to I/O error on sdd1 [373959.374879] end_request: I/O error, dev sdd, sector 8279 [373959.374886] Buffer I/O error on device sdd1, logical block 1027 [373959.374920] lost page write due to I/O error on sdd1 [398760.587483] end_request: I/O error, dev sdd, sector 12375 [398760.587802] EXT3-fs error (device sdd1): ext3_journal_start_sb: Detected aborted journal [460044.180730] end_request: I/O error, dev sdd, sector 12375 [460060.144935] end_request: I/O error, dev sdd, sector 12375 [460060.145512] EXT3-fs error (device sdd1): ext3_find_entry: reading directory #2 offset 0 [546350.526323] end_request: I/O error, dev sdd, sector 12375 [546377.057938] end_request: I/O error, dev sdd, sector 12375 [546377.058512] EXT3-fs error (device sdd1): ext3_find_entry: reading directory #2 offset 0 [573937.502076] end_request: I/O error, dev sdd, sector 12375 [632660.106026] end_request: I/O error, dev sdd, sector 12375 [632674.011154] end_request: I/O error, dev sdd, sector 12375 [632674.011748] EXT3-fs error (device sdd1): ext3_find_entry: reading directory #2 offset 0 [674282.098072] end_request: I/O error, dev sdd, sector 12375 [674398.549031] end_request: I/O error, dev sdd, sector 12375 [674417.470870] end_request: I/O error, dev sdd, sector 12375 [674419.252790] end_request: I/O error, dev sdd, sector 12375 [675228.373132] end_request: I/O error, dev sdd, sector 12375 [676927.660315] end_request: I/O error, dev sdd, sector 12375 [676927.660596] EXT3-fs error (device sdd1): ext3_find_entry: reading directory #2 offset 0 [676946.413484] end_request: I/O error, dev sdd, sector 12375 [676949.923070] end_request: I/O error, dev sdd, sector 12375 [676953.526115] end_request: I/O error, dev sdd, sector 12375 [676989.457779] end_request: I/O error, dev sdd, sector 12375 [677091.104548] end_request: I/O error, dev sdd, sector 12375 [677222.656661] end_request: I/O error, dev sdd, sector 12423 [677222.656667] Buffer I/O error on device sdd1, logical block 1545 [677222.656700] lost page write due to I/O error on sdd1 [677273.903948] end_request: I/O error, dev sdd, sector 63 [677273.903954] Buffer I/O error on device sdd1, logical block 0 [677273.903990] Buffer I/O error on device sdd1, logical block 1 [677273.904020] Buffer I/O error on device sdd1, logical block 2 [677273.904049] Buffer I/O error on device sdd1, logical block 3 [677273.904078] Buffer I/O error on device sdd1, logical block 4 [677273.904106] Buffer I/O error on device sdd1, logical block 5 [677273.904135] Buffer I/O error on device sdd1, logical block 6 [677273.904164] Buffer I/O error on device sdd1, logical block 7 [677273.906241] end_request: I/O error, dev sdd, sector 63 [677273.906245] Buffer I/O error on device sdd1, logical block 0 [677273.906275] Buffer I/O error on device sdd1, logical block 1 Lenke til kommentar
tingo Skrevet 20. september 2010 Rapporter Del Skrevet 20. september 2010 (endret) Stunt finnes det alltids, men det krever i de fleste tilfeller at du har fysisk tilgang til maskinen og / eller disken. Først ville jeg ha sjekket at kontaktene til disken står ordetlig i, og tatt dem ut og satt dem inn igjen. Hvis det ikke hjelper, se om du får disken til å virke etter at den er blitt kald. Hvis det funker, så kan du kanskje redde data ut "stykkevis og delt" ved å kopiere til disken blir varm, la den kjøle seg ned osv. Til slutt (nest siste løsning) dersom kontrollerkortet på disken er defekt så kan det byttes. Siste (og dyreste) løsning: IBAS. Endret 20. september 2010 av tingo Lenke til kommentar
bollapinnsvin Skrevet 22. september 2010 Rapporter Del Skrevet 22. september 2010 (endret) Jeg ville vært forsiktig med å berge data "stykkvis og delt" når disken er kald osv. Dette er fordi det er fort gjort å gjøre mer, og i verste fall uopprettelig, skade på disken. Endret 2. november 2010 av Runar Fjernet reklame. Lenke til kommentar
