TheCatIsALie Skrevet 17. september 2010 Rapporter Del Skrevet 17. september 2010 Jada, nå tenker du nok "dust, ta ned grafikken", eller "kjøp ny PC!" Men les først, svar etterpå. Min hardware: Operating System MS Windows 7 Ultimate 64-bit CPU Intel Core 2 Duo E8500 @ 3.16GHz 43 °C Wolfdale 45nm Technology RAM 4.0GB Dual-Channel DDR2 @ 332MHz (6-5-5-15) Motherboard ASUSTeK Computer INC. P5KPL/EPU (Socket 775) Graphics ACER X243HQ @ 1920x1080 SAMSUNG @ 1360x768 NVIDIA GeForce GTX 480 LogMeIn Mirror Driver Hard Drives 977GB Seagate ST31000528AS ATA Device (IDE) 48 °C 313GB Seagate ST3320620AS ATA Device (Unknown Interface) 49 °C 977GB Western Digital WDC WD10EARS-00Y5B1 ATA Device (IDE) 45 °C 488GB Western Digital WDC WD5000AAJS-00TKA0 ATA Device (IDE) 52 °C Optical Drives LIBENMF HU7G5IN0P SCSI CdRom Device Optiarc DVD RW AD-5170A ATA Device Audio Realtek High Definition Audio Noe rotete, men alt er der. Jeg får 9-10 FPS, dette er i starten, i skipet. Fikk rundt 30-40 med 9800GTX+ før.. Hvorfor får jeg så sinnsykt lav fps? Spiller i 1080p, samme fps på low og high settings. Lenke til kommentar
solve91 Skrevet 17. september 2010 Rapporter Del Skrevet 17. september 2010 Jada, nå tenker du nok "dust, ta ned grafikken", eller "kjøp ny PC!" Men les først, svar etterpå. Min hardware: Operating System MS Windows 7 Ultimate 64-bit CPU Intel Core 2 Duo E8500 @ 3.16GHz 43 °C Wolfdale 45nm Technology RAM 4.0GB Dual-Channel DDR2 @ 332MHz (6-5-5-15) Motherboard ASUSTeK Computer INC. P5KPL/EPU (Socket 775) Graphics ACER X243HQ @ 1920x1080 SAMSUNG @ 1360x768 NVIDIA GeForce GTX 480 LogMeIn Mirror Driver Hard Drives 977GB Seagate ST31000528AS ATA Device (IDE) 48 °C 313GB Seagate ST3320620AS ATA Device (Unknown Interface) 49 °C 977GB Western Digital WDC WD10EARS-00Y5B1 ATA Device (IDE) 45 °C 488GB Western Digital WDC WD5000AAJS-00TKA0 ATA Device (IDE) 52 °C Optical Drives LIBENMF HU7G5IN0P SCSI CdRom Device Optiarc DVD RW AD-5170A ATA Device Audio Realtek High Definition Audio Noe rotete, men alt er der. Jeg får 9-10 FPS, dette er i starten, i skipet. Fikk rundt 30-40 med 9800GTX+ før.. Hvorfor får jeg så sinnsykt lav fps? Spiller i 1080p, samme fps på low og high settings. det fleste ser jo veldig vel og bra ut stusser likevel på ram-hastigheten, 332Mhz? gaming-rigger har vel et minste på 800mhz. grafikkortet er jo helt nytt fra nvidia, så det burde kunne dra det meste (og steke noen egg i samme slengen). har du husket å oppdatere skjermdrivere og directx? det kan ofte dra ned ytelsen. Lenke til kommentar
TheCatIsALie Skrevet 17. september 2010 Forfatter Rapporter Del Skrevet 17. september 2010 (endret) Alt er oppdatert, men RAMen ja.. la ikke merke til det. EDIT: Har nå "fiksa" RAMen, er nå: 4.0GB Dual-Channel DDR2 @ 400MHz (6-6-6-18) Det er 800MHz. Var nok lite, da jeg tidligere har klokka ned, siden jeg klokka CPU. Men fjerna CPU-klokk. (Da senket jeg både CPU til stock, og RAM til enda mindre enn stock, da den blir klokket opp med CPUen. Endret 17. september 2010 av Jevrio Lenke til kommentar
TheCatIsALie Skrevet 17. september 2010 Forfatter Rapporter Del Skrevet 17. september 2010 Ser helt fælt ut.. og samme FPS på low og max.. På bildet er alt på max. Lenke til kommentar
Bjonski Skrevet 18. september 2010 Rapporter Del Skrevet 18. september 2010 Virker som kortet ditt blir for varmt og produserer artifacts. Lenke til kommentar
TheCatIsALie Skrevet 18. september 2010 Forfatter Rapporter Del Skrevet 18. september 2010 Hvorfor kan jeg da spille BFBC2 på max uten noen problemer? Lenke til kommentar
solve91 Skrevet 18. september 2010 Rapporter Del Skrevet 18. september 2010 kansje det er support-problemer med 480 og mass effect. et råd kan vere å google en sammenheng mellom grafikkortet og spillet. synest selv det hele hørest rart ut...det er jo et nytt spill som mange har skaffet seg, burde vel vere support i de beste grafikkortene... Lenke til kommentar
TheCatIsALie Skrevet 19. september 2010 Forfatter Rapporter Del Skrevet 19. september 2010 (endret) feil tråd. Endret 19. september 2010 av Jevrio Lenke til kommentar
