Hei! Jeg vil gjerne adde dette til min browser : i stedet for og navigere til en nettside må jeg trykke på "go" knappen, men jeg vil endre sånn at jeg kan trykke enter.
Det hadde også hvert fint om noen kunne lære meg og adde bookmarks og hjemmeside :)
Kode :
Public Class Form1
Dim i As Integer = 1
________________________________________
Private Sub Loading(ByVal sender As System.Object, ByVal e As System.Windows.Forms.WebBrowserProgressChangedEventArgs)
ProgressBar1.Maximum = e.MaximumProgress
If Not e.CurrentProgress = -1 And Not e.CurrentProgress > e.MaximumProgress Then
ProgressBar1.Value = e.CurrentProgress
End If
Label1.Visible = True
End Sub
Private Sub Done(ByVal sender As Object, ByVal e As Windows.Forms.WebBrowserDocumentCompletedEventArgs)
TabControl1.SelectedTab.Text = CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).DocumentTitle
ToolStripTextBox1.Text = CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).Url.ToString
Me.Text = CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).DocumentTitle & "" 'put whatever you want in the parentheses
End Sub
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Dim Browser As New Windows.Forms.WebBrowser
TabControl1.TabPages.Add("New Tab")
Browser.Name = "Febzter"
Browser.Dock = DockStyle.Fill
TabControl1.SelectedTab.Controls.Add(Browser)
AddHandler Browser.ProgressChanged, AddressOf Loading
AddHandler Browser.DocumentCompleted, AddressOf Done
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).GoHome()
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).ScriptErrorsSuppressed = True
End Sub
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
Label1.Text = CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).StatusText
End Sub
Private Sub AddTabToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles AddTabToolStripMenuItem.Click
TabControl1.SelectTab(i)
i = i + 1
End Sub
Private Sub RemoveTabToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles RemoveTabToolStripMenuItem.Click
If Not TabControl1.TabPages.Count = 1 Then
TabControl1.TabPages.RemoveAt(TabControl1.SelectedIndex)
TabControl1.SelectTab(TabControl1.TabPages.Count - 1)
i = i - 1
End If
End Sub
Private Sub PrintToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles PrintToolStripMenuItem.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).ShowPrintDialog()
End Sub
Private Sub PrintPreviewToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles PrintPreviewToolStripMenuItem.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).ShowPrintPreviewDialog()
End Sub
Private Sub PageSetupToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles PageSetupToolStripMenuItem.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).ShowPageSetupDialog()
End Sub
Private Sub PropertiesToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles PropertiesToolStripMenuItem.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).ShowPropertiesDialog()
End Sub
Private Sub CloseToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CloseToolStripMenuItem.Click
End
End Sub
Private Sub HideToolbarsToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles HideToolbarsToolStripMenuItem.Click
If MenuStrip1.Visible = True And ToolStrip1.Visible = True Then
MenuStrip1.Visible = False
ToolStrip1.Visible = False
Else
End If
End Sub
Private Sub TabControl1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TabControl1.Click
'This keeps it so that when you click on a different tab, the TextBox displays the URL of that tab.
End Sub
Private Sub ToolStripButton5_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ToolStripButton5.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).Navigate(ToolStripTextBox1.Text)
End Sub
Private Sub ToolStripButton1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ToolStripButton1.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).GoBack()
End Sub
Private Sub ToolStripButton4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ToolStripButton4.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).GoForward()
End Sub
Private Sub ToolStripButton3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ToolStripButton3.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).Stop()
End Sub
Private Sub ToolStripButton2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ToolStripButton2.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).Refresh()
End Sub
Private Sub ToolStripButton6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ToolStripButton6.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).Navigate("http://www.google.com/search?hl=en&q=" & ToolStripTextBox2.Text & "&btnG=Google+Search")
End Sub
Private Sub LinkLabel1_LinkClicked(ByVal sender As System.Object, ByVal e As System.Windows.Forms.LinkLabelLinkClickedEventArgs)
Process.Start("http://gamer-news.pcriot.com/")
End Sub
Private Sub ToolStripButton7_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ToolStripButton7.Click
CType(TabControl1.SelectedTab.Controls.Item(0), Windows.Forms.WebBrowser).Navigate("www.gamer-news.pcriot.com")
End Sub
