Debian problem - libpam bork
299 packages upgraded, 69 newly installed, 3 to remove and 1  not upgraded.
Need to get 0B/180MB of archives. After unpacking 160MB will be used.
Do you want to continue? [Y/n] y
E: Internal Error, Could not perform immediate configuration (2) on libpam0g
pTL:~# apt-get install libpam0g
Reading Package Lists... Done
Building Dependency Tree... Done
The following extra packages will be installed:
 libdb3 libpam-modules
3 packages upgraded, 0 newly installed, 0 to remove and 297  not upgraded.
Need to get 0B/446kB of archives. After unpacking 116kB will be used.
E: Internal Error, Could not perform immediate configuration (2) on libpam-modules
pTL:~# apt-get install libpam-modules
 libdb3 libpam0g
pTL:~#
Tips? ( orker ikke skrive mer :p )
Går ut ifra at du prøver å oppdatere fra Woody til Sid?!
Isåfall kan du prøve med:
apt-get -o APT::Force-LoopBreak=true dist-upgrade
Det fungerte iallefall for meg. For sikkerhets skyld ville jeg nok ha prøvd med en "-s" for å sjekke at ting fungerte.
Editert: Ble litt usikker nå, men du kan nå prøve... :-?
