Lenovo 412L i3 370M på GS.no - trygt kjøp?
hei. Jeg har funnet en ganske god skole-PC (erstatte dritt Aceren jeg fikk fra fylket for kr 1700 når jeg begynte på VG1) synes jeg, men hva synes dere?
http://www.gs.no/produkt.php?id=39214
Jeg har to spørsmål:
1. er GS.no trygt å kjøpe fra? med tanke på kundeservice of sikker levering?
2. http://www.notebookcheck.net/Review-Lenovo-Thinkpad-L412-Notebook.31514.0.html
Er proceccoren under-clocket til 1ghz eller noe av Lenovo?
The results of the Cinebench Tests (R10, R11) in the 64-bit variant lie in the lowest third of the expected values on comparable hardware. Especially striking is the comparably low value in the Cinebench Single Core Rendering Test (1932 points), which the L412 shares with the L512. Notebooks with identical CPU are usually able to achieve up to 2900 points here, representing up to a 50% increase over the L-series' results.
For this reason, we looked at the CPU in the benchmark test a bit more critically. Here, we realize that during the Single Core Rendering Test the chip practically never achieves its maximum performance of 2.1 GHz and often dips below a 1GHz clock rate. The problem does not lie with temperature, as the CPU stays at a stable level of under 50 degrees Celsius both before and after the benchmarks. It leaves one with the conclusion that there must be something (known) set to brake the system in this manner, which makes sense in the context of this test among the others in the benchmark suite.
