FlinkeFreddy Skrevet 4. september 2010 Del Skrevet 4. september 2010 Hei, kjører Mint vers. 8. Har prøvd å starte Desktop Drapes etter å ha installert det fra pakkebehandleren. Jeg får følgende melding når jeg prøver å starte det i terminalen: freddy-laptop Skrivebord # drapes (/usr/lib/drapes/drapes.exe:2536): GLib-WARNING **: g_set_prgname() called multiple times /root/.gtkrc-2.0:1: error: unexpected character `\342', expected keyword - e.g. `style' (/usr/lib/drapes/drapes.exe:2536): GnomeUI-WARNING **: While connecting to session manager: None of the authentication protocols specified are supported. (/usr/lib/drapes/drapes.exe:2536): GnomeUI-WARNING **: While connecting to session manager: None of the authentication protocols specified are supported. Unhandled Exception: GLib.GException: Failed to contact configuration server; some possible causes are that you need to enable TCP/IP networking for ORBit, or you have stale NFS locks due to a system crash. See http://projects.gnome.org/gconf/ for information. (Details - 1: Failed to get connection to session: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.) at GConf.Client.GetConnections (System.String dir) [0x00000] at GConf.Client.AddNotify (System.String dir, GConf.NotifyEventHandler notify) [0x00000] at Drapes.Config.Settings..ctor () [0x00000] at Drapes.DrapesApp..ctor (System.String[] args) [0x00000] at Drapes.DrapesApp.Main (System.String[] args) [0x00000] Aner ikke hva dette betyr, kanskje fordi jeg ikke har sååååå mye peiling på Linux. Noen som har noen ideer? Mvh Freddy Lenke til kommentar
