"Sound support soundcore" module?
Driver og installerer ALSA, og det første punktet i installasjonen er dette:
You must turn on the sound support soundcore module. This is in the kernel. Look in the sound drivers directory and it should be the first option. Most people enable the module setting. That way you can load and unload the module manually if you have multiple soundcards/devices or if you intend to debug or use cutting edge software which may cause your drivers to halt sometimes. Of course it also means you have more control of your system.
Most modern distros come with soundcore compiled as a module. You can check this in numerous ways. The easiest way is to type.
modinfo soundcore
If this command returns that you have this module, then you don't need to recompile your kernel.
modinfo soundcore viste at jeg ikke hadde denne saken, men jeg finner den heller ikke i configen til kjernen. Hvor er den?
