Sitter på maskinen til en kompis som har fånn infisert pcen med et slags MSN-virus.
Meldingen som sendes er slik:
se på dette bildet   http://www.facebook.ozodo.com/facebook_gallery.php?image=DSC001**********.JPG
Har kjørt Malwarebytes' Anti-Malware og Combofix.
Legger ved logger:
Malware:
Malwarebytes' Anti-Malware 1.46
www.malwarebytes.org
Databaseversjon: 4436
Windows 6.1.7600
Internet Explorer 8.0.7600.16385
16.08.2010 19:06:16
mbam-log-2010-08-16 (19-06-16).txt
Skanntype: Full skann (C:\|D:\|E:\|F:\|)
Objekter skannet: 296195
Tid tilbakelagt: 1 time®, 31 minutt(er), 45 sekund(er)
Minneprosesser infisert: 0
Minnemoduler infisert: 1
Registernøkler infisert: 4
Registerverdier infisert: 4
Registerfiler infisert: 0
Mapper infisert: 0
Filer infisert 68
(Ingen skadelige objekter funnet)
C:\Users\Nicolai\AppData\Local\Temp\sshnas21.dll (Trojan.Agent.Gen) -> Delete on reboot.
HKEY_CURRENT_USER\SOFTWARE\10DPP6O2VE (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Handle (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\XML (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\ZE18MW23GY (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\metropolis (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ze18mw23gy (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\jrmx9x1gml (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\windows update services (Backdoor.IRCBot) -> Quarantined and deleted successfully.
Mapper infisert:
Filer infisert
C:\Users\Nicolai\AppData\Local\Temp\Hj1.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hki.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Download\DSC0014084920.JPG.scr (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\4HDALQG2\e[1].exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\1334728.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\1517108.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\1631650.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\2080675.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\2495839.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\3015541.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\3208534.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\3725195.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\4197340.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\4668786.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\5192718.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\5783253.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\5942951.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\6296320.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\6467957.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\6686531.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\6865580.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\7602778.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\7859772.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\8134231.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\8153272.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\8188236.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\8888541.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\9335040.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\9817349.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\BbAld6I87I.log (Backdoor.Agent) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\He167GM0kM.log (Extension.Mismatch) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hj0.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hj2.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hj3.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hj4.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hj5.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hj6.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hj7.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hj8.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hj9.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hjz.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hka.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkb.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkc.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkd.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hke.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkf.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkg.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkh.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkj.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkk.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkl.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkm.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkn.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hko.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkp.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hks.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkt.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hku.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkv.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Hkx.exe (Trojan.Agent.Gen) -> Delete on reboot.
C:\Users\Nicolai\AppData\Local\Temp\Hky.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully.
C:\Windows\MSetup\BASW-01278A18\FailSafeFactoryInstaller_1017.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Roaming\chrtmp (Malware.Trace) -> Quarantined and deleted successfully.
C:\Windows\Tasks\{22116563-108C-42c0-A7CE-60161B75E508}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Windows\Tasks\{35DC3473-A719-4d14-B7C1-FD326CA84A0C}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Windows\Tasks\{62C40AA6-4406-467a-A5A5-DFDF1B559B7A}.job (Trojan.FakeAlert) -> Quarantined and deleted successfully.
DDS:
DDS (Ver_10-03-17.01) - NTFSX64
Run by Nicolai at 0:09:43,78 on 19.08.2010
Internet Explorer: 8.0.7600.16385 BrowserJavaVersion: 1.6.0_18
Microsoft Windows 7 Home Premium 6.1.7600.0.1252.47.1044.18.3957.2631 [GMT 2:00]
============== Running Processes ===============
C:\windows\system32\wininit.exe
C:\windows\system32\lsm.exe
C:\windows\system32\svchost.exe -k DcomLaunch
C:\windows\system32\nvvsvc.exe
C:\windows\system32\svchost.exe -k RPCSS
C:\windows\System32\svchost.exe -k LocalServiceNetworkRestricted
C:\windows\System32\svchost.exe -k LocalSystemNetworkRestricted
C:\windows\system32\svchost.exe -k netsvcs
C:\windows\system32\svchost.exe -k LocalService
C:\windows\system32\svchost.exe -k NetworkService
C:\windows\System32\spoolsv.exe
C:\windows\system32\svchost.exe -k LocalServiceNoNetwork
C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
C:\Program Files (x86)\Bonjour\mDNSResponder.exe
C:\Program Files\WIDCOMM\Bluetooth Software\btwdins.exe
C:\windows\system32\svchost.exe -k LocalServiceAndNoImpersonation
C:\Program Files (x86)\McAfee\SiteAdvisor\McSACore.exe
C:\windows\SysWOW64\rundll32.exe
C:\Program Files\Common Files\McAfee\SystemCore\mfevtps.exe
C:\windows\SysWOW64\Rezip.exe
C:\Program Files (x86)\CyberLink\Shared files\RichVideo.exe
C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE
C:\Program Files\Common Files\McAfee\SystemCore\mcshield.exe
C:\Program Files\Common Files\McAfee\SystemCore\mfefire.exe
C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
C:\windows\system32\SearchIndexer.exe
C:\windows\system32\taskhost.exe
C:\windows\system32\Dwm.exe
C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe
C:\windows\system32\taskeng.exe
C:\Program Files (x86)\Samsung\Samsung Support Center\SSCKbdHk.exe
C:\Program Files (x86)\Samsung\Samsung Recovery Solution 4\WCScheduler.exe
C:\windows\Explorer.EXE
C:\windows\system32\svchost.exe -k NetworkServiceNetworkRestricted
C:\windows\System32\rundll32.exe
C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe
C:\Program Files\Synaptics\SynTP\SynTPHelper.exe
C:\Windows\System32\rundll32.exe
C:\Users\Public\S-2535-6853-2745\winrsvn.exe
C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe
C:\Program Files (x86)\CyberLink\Power2Go\CLMLSvc.exe
C:\Program Files (x86)\CyberLink\PowerDVD8\PDVD8Serv.exe
C:\Users\Public\HEX-5823-6893-6818\jusched.exe
C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\Program Files (x86)\Windows Live\Contacts\wlcomm.exe
C:\Program Files\Windows Media Player\wmpnetwk.exe
C:\Program Files\Spotify\spotify.exe
C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbam.exe
C:\windows\System32\svchost.exe -k LocalServicePeerNet
C:\windows\system32\DllHost.exe
C:\Program Files (x86)\Mozilla Firefox\firefox.exe
C:\Users\Nicolai\AppData\Local\Temp\0089733.exe
C:\Users\Nicolai\AppData\Local\Temp\9180576.exe
C:\windows\System32\svchost.exe -k WerSvcGroup
C:\Download\dds.scr
C:\windows\system32\conhost.exe
C:\windows\system32\wbem\wmiprvse.exe
============== Pseudo HJT Report ===============
uStart Page = hxxp://www.google.com/ig/redirectdomain?brand=smsn&bmod=smsn
uDefault_Page_URL = hxxp://www.google.com/ig/redirectdomain?brand=smsn&bmod=smsn
mLocal Page = c:\windows\syswow64\blank.htm
uInternet Settings,ProxyOverride = *.local
BHO: Adobe PDF Link Helper: {18df081c-e8ad-4283-a596-fa578c2ebdc3} - c:\program files (x86)\common files\adobe\acrobat\activex\AcroIEHelperShim.dll
BHO: McAfee Phishing Filter: {27b4851a-3207-45a2-b947-be8afe6163ab} - c:\progra~1\mcafee\msk\mskapbho.dll
BHO: scriptproxy: {7db2d5a0-7241-4e79-b68d-6309f01c5231} - c:\program files (x86)\common files\mcafee\systemcore\ScriptSn.20100816154622.dll
BHO: Påloggingshjelp for Windows Live ID: {9030d464-4c02-4abf-8ecc-5164760863c6} - c:\program files (x86)\common files\microsoft shared\windows live\WindowsLiveLogin.dll
BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - c:\program files (x86)\google\google toolbar\GoogleToolbar_32.dll
BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files (x86)\google\googletoolbarnotifier\5.5.5126.1836\swg.dll
BHO: McAfee SiteAdvisor BHO: {b164e929-a1b6-4a06-b104-2cd0e90a88ff} - c:\progra~2\mcafee\sitead~1\mcieplg.dll
BHO: Java Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - c:\program files (x86)\java\jre6\bin\jp2ssv.dll
TB: McAfee SiteAdvisor Toolbar: {0ebbbe48-bad4-4b4c-8e5a-516abecae064} - c:\progra~2\mcafee\sitead~1\mcieplg.dll
TB: Google Toolbar: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files (x86)\google\google toolbar\GoogleToolbar_32.dll
uRun: [DAEMON Tools Lite] "c:\program files (x86)\daemon tools lite\DTLite.exe" -autorun
uRun: [steam] "c:\program files (x86)\steam\Steam.exe" -silent
uRun: [msnmsgr] "c:\program files (x86)\windows live\messenger\msnmsgr.exe" /background
uRun: [Windows Boot Control] c:\users\public\s-2535-6853-2745\winrsvn.exe
uRun: [Metropolis] rundll32.exe c:\users\nicolai\appdata\local\temp\sshnas21.dll,GetHandle
uRun: [ZE18MW23GY] c:\users\nicolai\appdata\local\temp\Hj2.exe
uRun: [Java Update Manager] c:\users\public\hex-5823-6893-6818\jusched.exe
mRun: [updateLBPShortCut] "c:\program files (x86)\cyberlink\labelprint\muitransfer\muistartmenu.exe" "c:\program files (x86)\cyberlink\labelprint" updatewithcreateonce "software\cyberlink\labelprint\2.5"
mRun: [CLMLServer] "c:\program files (x86)\cyberlink\power2go\CLMLSvc.exe"
mRun: [updateP2GoShortCut] "c:\program files (x86)\cyberlink\power2go\muitransfer\muistartmenu.exe" "c:\program files (x86)\cyberlink\power2go" updatewithcreateonce "software\cyberlink\power2go\6.0"
mRun: [updatePDRShortCut] "c:\program files (x86)\cyberlink\powerdirector\muitransfer\muistartmenu.exe" "c:\program files (x86)\cyberlink\powerdirector" updatewithcreateonce "software\cyberlink\powerdirector\7.0"
mRun: [RemoteControl8] "c:\program files (x86)\cyberlink\powerdvd8\PDVD8Serv.exe"
mRun: [PDVD8LanguageShortcut] "c:\program files (x86)\cyberlink\powerdvd8\language\Language.exe"
mRun: [updatePPShortCut] "c:\program files (x86)\cyberlink\powerproducer\muitransfer\muistartmenu.exe" "c:\program files (x86)\cyberlink\powerproducer" updatewithcreateonce "software\cyberlink\powerproducer\5.0"
mRun: [updatePSTShortCut] "c:\program files (x86)\cyberlink\dvd suite\muitransfer\muistartmenu.exe" "c:\program files (x86)\cyberlink\dvd suite" updatewithcreateonce "software\cyberlink\PowerStarter"
mRun: [APLangApp] "c:\program files (x86)\anypc client\APLangApp.exe"
mRun: [uCam_Menu] "c:\program files (x86)\cyberlink\youcam\muitransfer\muistartmenu.exe" "c:\program files (x86)\cyberlink\youcam" updatewithcreateonce "software\cyberlink\youcam\2.0"
mRun: [QuickTime Task] "c:\program files (x86)\quicktime\QTTask.exe" -atboottime
mRun: [sunJavaUpdateSched] "c:\program files (x86)\common files\java\java update\jusched.exe"
mRun: [Adobe Reader Speed Launcher] "c:\program files (x86)\adobe\reader 9.0\reader\Reader_sl.exe"
mRun: [Adobe ARM] "c:\program files (x86)\common files\adobe\arm\1.0\AdobeARM.exe"
mRun: [mcui_exe] "c:\program files\mcafee.com\agent\mcagent.exe" /runkey
StartupFolder: c:\progra~3\micros~1\windows\startm~1\programs\startup\blueto~1.lnk - c:\program files\widcomm\bluetooth software\BTTray.exe
mPolicies-explorer: NoActiveDesktop = 1 (0x1)
mPolicies-explorer: NoActiveDesktopChanges = 1 (0x1)
mPolicies-explorer: ForceActiveDesktopOn = 0 (0x0)
mPolicies-system: ConsentPromptBehaviorAdmin = 5 (0x5)
mPolicies-system: ConsentPromptBehaviorUser = 3 (0x3)
mPolicies-system: EnableUIADesktopToggle = 0 (0x0)
IE: Add to Google Photos Screensa&ver - c:\windows\system32\GPhotos.scr/200
IE: Google Sidewiki - c:\program files (x86)\google\google toolbar\component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll/cmsidewiki.html
IE: Send bilde til &Bluetooth-enhet... - c:\program files\widcomm\bluetooth software\btsendto_ie_ctx.htm
IE: Send side til &Bluetooth-enhet... - c:\program files\widcomm\bluetooth software\btsendto_ie.htm
IE: {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\program files\widcomm\bluetooth software\btsendto_ie.htm
IE: {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - {5F7B1267-94A9-47F5-98DB-E99415F33AEC} - c:\program files (x86)\windows live\writer\WriterBrowserExtension.dll
IE: {2670000A-7350-4f3c-8081-5663EE0C6C49} - {48E73304-E1D6-4330-914C-F5F514E3486C} - c:\progra~2\micros~2\office12\ONBttnIE.dll
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~2\micros~2\office12\REFIEBAR.DLL
DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_18-windows-i586.cab
DPF: {CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_18-windows-i586.cab
DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_18-windows-i586.cab
Handler: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\progra~2\mcafee\sitead~1\McIEPlg.dll
{27B4851A-3207-45A2-B947-BE8AFE6163AB}
{4f3ed5cd-0726-42a9-87f5-d13f3d2976ac}
{7DB2D5A0-7241-4E79-B68D-6309F01C5231}
{9030D464-4C02-4ABF-8ECC-5164760863C6}
{AA58ED58-01DD-4d91-8333-CF10577473F7}
{AF69DE43-7D58-4638-B6FA-CE66B5AD205D}
{B164E929-A1B6-4A06-B104-2CD0E90A88FF}
{0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064}
{2318C2B1-4965-11d4-9B18-009027A5CD4F}
mRun-x64: [RtHDVCpl] c:\program files\realtek\audio\hda\RAVCpl64.exe -s
mRun-x64: [synTPEnh] %ProgramFiles%\Synaptics\SynTP\SynTPEnh.exe
mRun-x64: [NvCplDaemon] RUNDLL32.EXE c:\windows\system32\NvCpl.dll,NvStartup
IE-X64: {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\program files\widcomm\bluetooth software\btsendto_ie.htm
================= FIREFOX ===================
FF - ProfilePath - c:\users\nicolai\appdata\roaming\mozilla\firefox\profiles\unmcgona.default\
FF - prefs.js: browser.startup.homepage - hxxp://vg.no
FF - component: c:\program files (x86)\mcafee\siteadvisor\components\McFFPlg.dll
FF - plugin: c:\program files (x86)\google\picasa3\npPicasa3.dll
FF - plugin: c:\program files (x86)\google\update\1.2.183.13\npGoogleOneClick8.dll
FF - plugin: c:\program files (x86)\microsoft\office live\npOLW.dll
FF - plugin: c:\program files (x86)\windows live\photo gallery\NPWLPG.dll
FF - plugin: c:\windows\syswow64\macromed\flash\NPSWF32.dll
FF - HiddenExtension: Java Console: No Registry Reference - c:\program files (x86)\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA}
---- FIREFOX POLICIES ----
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("ui.use_native_colors", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("ui.use_native_popup_windows", false);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("browser.enable_click_image_resizing", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("accessibility.browsewithcaret_shortcut.enabled", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("javascript.options.mem.high_water_mark", 32);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("javascript.options.mem.gc_frequency", 1600);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.IDN.whitelist.lu", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.IDN.whitelist.nu", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.IDN.whitelist.nz", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbaam7a8h", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgberp4a5d4ar", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--p1ai", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbayh7gpa", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.IDN.whitelist.tel", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.auth.force-generic-ntlm", false);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.proxy.type", 5);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.buffer.cache.count", 24);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("network.buffer.cache.size", 4096);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("dom.ipc.plugins.timeoutSecs", 45);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("svg.smil.enabled", false);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("ui.trackpoint_hack.enabled", -1);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("browser.formfill.debug", false);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("browser.formfill.agedWeight", 2);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("browser.formfill.bucketSize", 1);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("browser.formfill.maxTimeGroupings", 25);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("browser.formfill.timeGroupingSize", 604800);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("browser.formfill.boundaryWeight", 25);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("browser.formfill.prefixWeight", 5);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("accelerometer.enabled", true);
c:\program files (x86)\mozilla firefox\greprefs\all.js - pref("html5.enable", false);
c:\program files (x86)\mozilla firefox\greprefs\security-prefs.js - pref("security.ssl.allow_unrestricted_renego_everywhere__temporarily_available_pref", true);
c:\program files (x86)\mozilla firefox\greprefs\security-prefs.js - pref("security.ssl.renego_unrestricted_hosts", "");
c:\program files (x86)\mozilla firefox\greprefs\security-prefs.js - pref("security.ssl.treat_unsafe_negotiation_as_broken", false);
c:\program files (x86)\mozilla firefox\greprefs\security-prefs.js - pref("security.ssl.require_safe_negotiation", false);
c:\program files (x86)\mozilla firefox\greprefs\security-prefs.js - pref("security.ssl3.rsa_seed_sha", true);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox-branding.js - pref("app.update.download.backgroundInterval", 600);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox-branding.js - pref("app.update.url.manual", "http://www.firefox.com");
c:\program files (x86)\mozilla firefox\defaults\pref\firefox-branding.js - pref("browser.search.param.yahoo-fr-ja", "mozff");
c:\program files (x86)\mozilla firefox\defaults\pref\firefox-l10n.js - pref("browser.fixup.alternate.suffix", ".no");
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.name", "chrome://browser/locale/browser.properties");
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.description", "chrome://browser/locale/browser.properties");
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("xpinstall.whitelist.add", "addons.mozilla.org");
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("xpinstall.whitelist.add.36", "getpersonas.com");
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("lightweightThemes.update.enabled", true);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("browser.allTabs.previews", false);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("plugins.hide_infobar_for_outdated_plugin", false);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("plugins.update.notifyUser", false);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("toolbar.customization.usesheet", false);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.nptest.dll", true);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npswf32.dll", true);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npctrl.dll", true);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npqtplugin.dll", true);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled", false);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("browser.taskbar.previews.enable", false);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("browser.taskbar.previews.max", 20);
c:\program files (x86)\mozilla firefox\defaults\pref\firefox.js - pref("browser.taskbar.previews.cachetime", 20);
============= SERVICES / DRIVERS ===============
R0 mfehidk;McAfee Inc. mfehidk;c:\windows\system32\drivers\mfehidk.sys [2010-8-16 528616]
R1 mfenlfk;McAfee NDIS Light Filter;c:\windows\system32\drivers\mfenlfk.sys [2010-8-16 75288]
R1 mfewfpk;McAfee Inc. mfewfpk;c:\windows\system32\drivers\mfewfpk.sys [2010-8-16 279752]
R1 SABI;SAMSUNG Kernel Driver For Windows 7;c:\windows\system32\drivers\SABI.sys [2010-3-11 13824]
R1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\drivers\vwififlt.sys [2009-7-14 59904]
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files (x86)\mcafee\siteadvisor\McSACore.exe [2010-3-11 203280]
R2 McMPFSvc;McAfee Personal Firewall-tjeneste;"c:\program files\common files\mcafee\mcsvchost\McSvHost.exe" /McCoreSvc [2010-8-16 355440]
R2 McNaiAnn;McAfee VirusScan Announcer;"c:\program files\common files\mcafee\mcsvchost\McSvHost.exe" /McCoreSvc [2010-8-16 355440]
R2 McProxy;McAfee Proxy Service;"c:\program files\common files\mcafee\mcsvchost\McSvHost.exe" /McCoreSvc [2010-8-16 355440]
R2 McShield;McShield;c:\program files\common files\mcafee\systemcore\mcshield.exe [2010-8-16 199032]
R2 mfefire;McAfee Firewall Core Service;c:\program files\common files\mcafee\systemcore\mfefire.exe [2010-8-16 244840]
R2 mfevtp;McAfee Validation Trust Protection Service;c:\program files\common files\mcafee\systemcore\mfevtps.exe [2010-8-16 148520]
R2 Rezip;Rezip;c:\windows\syswow64\Rezip.exe [2010-3-11 311296]
R3 cfwids;McAfee Inc. cfwids;c:\windows\system32\drivers\cfwids.sys [2010-8-16 62416]
R3 CryptOSD;Phoenix CryptOSD Device Driver;c:\windows\system32\drivers\CryptOSD.sys [2009-6-25 431488]
R3 mfeavfk;McAfee Inc. mfeavfk;c:\windows\system32\drivers\mfeavfk.sys [2010-8-16 189880]
R3 mfefirek;McAfee Inc. mfefirek;c:\windows\system32\drivers\mfefirek.sys [2010-8-16 440688]
R3 NVHDA;Service for NVIDIA High Definition Audio Driver;c:\windows\system32\drivers\nvhda64v.sys [2010-3-12 83488]
R3 yukonw7;NDIS6.2 Miniport Driver for Marvell Yukon Ethernet Controller;c:\windows\system32\drivers\yk62x64.sys [2009-9-28 395264]
S2 gupdate;Googles oppdateringstjeneste (gupdate);c:\program files (x86)\google\update\GoogleUpdate.exe [2010-7-5 135664]
S3 btusbflt;Bluetooth USB Filter;c:\windows\system32\drivers\btusbflt.sys [2010-3-12 52264]
S3 btwl2cap;Bluetooth L2CAP Service;c:\windows\system32\drivers\btwl2cap.sys [2010-7-5 35104]
S3 fssfltr;fssfltr;c:\windows\system32\drivers\fssfltr.sys [2010-7-5 61280]
S3 fsssvc;Windows Live Tryggere for familien-tjenesten;c:\program files (x86)\windows live\family safety\fsssvc.exe [2010-4-28 704872]
S3 Impcd;Impcd;c:\windows\system32\drivers\Impcd.sys [2010-3-12 151936]
S3 mferkdet;McAfee Inc. mferkdet;c:\windows\system32\drivers\mferkdet.sys [2010-8-16 93840]
S3 RTL8167;Realtek 8167 NT Driver;c:\windows\system32\drivers\Rt64win7.sys [2009-6-10 187392]
S3 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\wat\WatAdminSvc.exe [2010-7-5 1255736]
=============== Created Last 30 ================
2010-08-16 15:33:18 0 d-----w- c:\users\nicolai\appdata\roaming\Malwarebytes
2010-08-16 15:33:05 24664 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-08-16 15:33:05 0 d-----w- c:\programdata\Malwarebytes
2010-08-16 15:33:04 0 d-----w- c:\program files (x86)\Malwarebytes' Anti-Malware
2010-08-16 13:46:28 0 d-----w- c:\program files\McAfee.com
2010-08-16 13:46:21 9984 ----a-w- c:\windows\system32\drivers\mfeclnk.sys
2010-08-16 13:46:13 93840 ----a-w- c:\windows\system32\drivers\mferkdet.sys
2010-08-16 13:46:13 75288 ----a-w- c:\windows\system32\drivers\mfenlfk.sys
2010-08-16 13:46:13 62416 ----a-w- c:\windows\system32\drivers\cfwids.sys
2010-08-16 13:46:13 528616 ----a-w- c:\windows\system32\drivers\mfehidk.sys
2010-08-16 13:46:13 440688 ----a-w- c:\windows\system32\drivers\mfefirek.sys
2010-08-16 13:46:13 279752 ----a-w- c:\windows\system32\drivers\mfewfpk.sys
2010-08-16 13:46:13 189880 ----a-w- c:\windows\system32\drivers\mfeavfk.sys
2010-08-16 13:46:13 121504 ----a-w- c:\windows\system32\drivers\mfeapfk.sys
2010-08-13 07:51:52 118 ----a-w- c:\windows\system32\MRT.INI
2010-08-12 12:41:11 463360 ----a-w- c:\windows\system32\drivers\srv.sys
2010-08-12 12:41:11 404992 ----a-w- c:\windows\system32\drivers\srv2.sys
2010-08-12 12:41:11 162304 ----a-w- c:\windows\system32\drivers\srvnet.sys
2010-08-12 12:41:09 340992 ----a-w- c:\windows\system32\schannel.dll
2010-08-12 12:41:09 224256 ----a-w- c:\windows\syswow64\schannel.dll
2010-08-08 22:56:44 812 ----a-w- c:\windows\system32\drivers\scdskr01.dat
2010-08-08 22:56:44 541 ----a-w- c:\windows\system32\drivers\scdhkr01.dat
2010-08-08 22:56:44 500 ----a-w- c:\windows\system32\drivers\RSTable.dat
2010-08-08 22:56:44 36 ----a-w- c:\windows\system32\drivers\scdstr01.dat
2010-08-08 16:47:45 0 d-----w- C:\Team17
2010-08-03 15:55:39 12867584 ----a-w- c:\windows\syswow64\shell32.dll
==================== Find3M ====================
2010-07-29 06:30:34 82944 ----a-w- c:\windows\syswow64\iccvid.dll
2010-07-21 23:19:21 74124 ----a-w- c:\windows\system32\perfc014.dat
2010-07-21 23:19:21 448210 ----a-w- c:\windows\system32\perfh014.dat
2010-07-10 16:29:07 153376 ----a-w- c:\windows\syswow64\javaws.exe
2010-07-10 16:29:07 145184 ----a-w- c:\windows\syswow64\javaw.exe
2010-07-10 16:29:07 145184 ----a-w- c:\windows\syswow64\java.exe
2010-07-10 16:29:06 411368 ----a-w- c:\windows\syswow64\deploytk.dll
2010-07-05 18:29:40 834544 ----a-w- c:\windows\system32\drivers\sptd.sys
2010-07-05 16:46:39 0 ----a-w- c:\windows\system32\drivers\144D_SAMSUNG_N_R580_08JB.mrk
2010-06-30 07:13:46 1192960 ----a-w- c:\windows\system32\wininet.dll
2010-06-30 06:25:31 978432 ----a-w- c:\windows\syswow64\wininet.dll
2010-06-30 06:25:18 1226240 ----a-w- c:\windows\syswow64\urlmon.dll
2010-06-30 06:22:45 606208 ----a-w- c:\windows\syswow64\mstime.dll
2010-06-30 06:22:34 5971456 ----a-w- c:\windows\syswow64\mshtml.dll
2010-06-30 06:22:33 64512 ----a-w- c:\windows\syswow64\msfeedsbs.dll
2010-06-30 06:21:57 48128 ----a-w- c:\windows\syswow64\jsproxy.dll
2010-06-30 06:21:47 185856 ----a-w- c:\windows\syswow64\iepeers.dll
2010-06-30 06:21:47 176640 ----a-w- c:\windows\syswow64\ieui.dll
2010-06-30 06:21:46 10985472 ----a-w- c:\windows\syswow64\ieframe.dll
2010-06-30 06:21:44 381440 ----a-w- c:\windows\syswow64\iedkcs32.dll
2010-06-30 06:19:16 12800 ----a-w- c:\windows\syswow64\msfeedssync.exe
2010-06-19 07:05:01 5507968 ----a-w- c:\windows\system32\ntoskrnl.exe
2010-06-19 06:53:18 52224 ----a-w- c:\windows\system32\rtutils.dll
2010-06-19 06:33:29 3955080 ----a-w- c:\windows\syswow64\ntkrnlpa.exe
2010-06-19 06:33:29 3899784 ----a-w- c:\windows\syswow64\ntoskrnl.exe
2010-06-19 06:23:50 37376 ----a-w- c:\windows\syswow64\rtutils.dll
2010-06-19 04:32:34 3122688 ----a-w- c:\windows\system32\win32k.sys
2010-06-08 06:02:06 1233920 ----a-w- c:\windows\syswow64\msxml3.dll
2010-06-08 05:36:31 1877504 ----a-w- c:\windows\system32\msxml3.dll
2010-06-03 02:41:44 3600384 ----a-w- c:\windows\syswow64\GPhotos.scr
2010-05-27 07:24:13 34304 ----a-w- c:\windows\syswow64\atmlib.dll
2010-05-27 06:34:09 46080 ----a-w- c:\windows\system32\atmlib.dll
2010-05-27 04:11:32 366080 ----a-w- c:\windows\system32\atmfd.dll
2010-05-27 03:49:37 293888 ----a-w- c:\windows\syswow64\atmfd.dll
2010-03-11 23:38:11 36156 ----a-w- c:\windows\inf\perflib\0414\perfd.dat
2010-03-11 23:38:11 36156 ----a-w- c:\windows\inf\perflib\0414\perfc.dat
2010-03-11 23:38:11 298300 ----a-w- c:\windows\inf\perflib\0414\perfi.dat
2010-03-11 23:38:11 298300 ----a-w- c:\windows\inf\perflib\0414\perfh.dat
2009-07-14 04:54:24 174 --sha-w- c:\program files\desktop.ini
2009-07-14 04:54:24 174 --sha-w- c:\program files (x86)\desktop.ini
2009-07-14 01:00:34 291294 ----a-w- c:\windows\inf\perflib\0000\perfi.dat
2009-07-14 01:00:34 291294 ----a-w- c:\windows\inf\perflib\0000\perfh.dat
2009-07-14 01:00:32 31548 ----a-w- c:\windows\inf\perflib\0000\perfd.dat
2009-07-14 01:00:32 31548 ----a-w- c:\windows\inf\perflib\0000\perfc.dat
2009-06-10 20:44:08 9633792 --sha-r- c:\windows\fonts\StaticCache.dat
2009-07-14 01:39:53 398848 --sha-w- c:\windows\winsxs\amd64_microsoft-windows-mail-app_31bf3856ad364e35_6.1.7600.16385_none_4d4d1f2f696639a2\WinMail.exe
2009-07-14 01:14:45 396800 --sha-w- c:\windows\winsxs\x86_microsoft-windows-mail-app_31bf3856ad364e35_6.1.7600.16385_none_f12e83abb108c86c\WinMail.exe
============= FINISH: 0:11:50,75 ===============
Har kjørt full scan med McAffe, uten hell.
Endret av Umlaut
Kjørte Malwarebytes' Anti-Malware på nytt, og det ser ut som at de samme filene kommer tilbake. Legger ved loggen fra den siste skannen.
Malwarebytes' Anti-Malware 1.46 www.malwarebytes.org Databaseversjon: 4436 Windows 6.1.7600 Internet Explorer 8.0.7600.16385 19.08.2010 03:26:44 mbam-log-2010-08-19 (03-26-44).txt Skanntype: Full skann (C:\|D:\|E:\|F:\|) Objekter skannet: 305114 Tid tilbakelagt: 53 minutt(er), 30 sekund(er) Minneprosesser infisert: 2 Minnemoduler infisert: 1 Registernøkler infisert: 3 Registerverdier infisert: 2 Registerfiler infisert: 0 Mapper infisert: 0 Filer infisert 27 Minneprosesser infisert: C:\Users\Nicolai\AppData\Local\Temp\Hj2.exe (Trojan.Agent.Gen) -> Unloaded process successfully. C:\Users\Nicolai\AppData\Local\Temp\Hkg.exe (Trojan.Agent.Gen) -> Unloaded process successfully. Minnemoduler infisert: C:\Users\Nicolai\AppData\Local\Temp\sshnas21.dll (Trojan.Agent.Gen) -> Delete on reboot. Registernøkler infisert: HKEY_CURRENT_USER\SOFTWARE\Microsoft\Handle (Malware.Trace) -> Quarantined and deleted successfully. HKEY_CURRENT_USER\SOFTWARE\XML (Trojan.FakeAlert) -> Quarantined and deleted successfully. HKEY_CURRENT_USER\SOFTWARE\ZE18MW23GY (Trojan.FakeAlert) -> Quarantined and deleted successfully. Registerverdier infisert: HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ze18mw23gy (Trojan.Agent.Gen) -> Quarantined and deleted successfully. HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\metropolis (Trojan.Agent.Gen) -> Quarantined and deleted successfully. Registerfiler infisert: (Ingen skadelige objekter funnet) Mapper infisert: (Ingen skadelige objekter funnet) Filer infisert C:\Users\Nicolai\AppData\Local\Temp\Hj2.exe (Trojan.Agent.Gen) -> Delete on reboot. C:\Users\Nicolai\AppData\Local\Temp\Hkg.exe (Trojan.Agent.Gen) -> Delete on reboot. C:\Users\Nicolai\AppData\Local\Temp\sshnas21.dll (Trojan.Agent.Gen) -> Delete on reboot. C:\Users\Nicolai\AppData\Local\Mozilla\Firefox\Profiles\unmcgona.default\Cache\4BDECFBFd01 (Backdoor.Bot) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\4064367.exe (Backdoor.Bot) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\4095401.exe (Backdoor.Bot) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\7824519.exe (Backdoor.Bot) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\9206278.exe (Backdoor.Bot) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\He167GM0kM.log (Extension.Mismatch) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hj1.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hj4.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hj5.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hj6.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hj7.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hj9.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hjz.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hka.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hkc.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hkd.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hkf.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hkh.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hkj.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\Hkm.exe (Trojan.Agent.Gen) -> Quarantined and deleted successfully. C:\Users\Nicolai\AppData\Local\Temp\kH71j6c88c.log (Extension.Mismatch) -> Quarantined and deleted successfully. C:\Windows\Tasks\{22116563-108C-42c0-A7CE-60161B75E508}.job (Trojan.Downloader) -> Quarantined and deleted successfully. C:\Windows\Tasks\{35DC3473-A719-4d14-B7C1-FD326CA84A0C}.job (Trojan.Downloader) -> Quarantined and deleted successfully. C:\Windows\Tasks\{62C40AA6-4406-467a-A5A5-DFDF1B559B7A}.job (Trojan.FakeAlert) -> Quarantined and deleted successfully.
Kjørte den msnvirusremovalen før jeg kjørte Malwarebytesen.
Endret av Umlaut
RSIT-logg:
Logfile of random's system information tool 1.08 (written by random/random)
Run by Nicolai at 2010-08-24 15:52:53
System drive C: has 186 GB (80%) free of 231 GB
Total RAM: 3957 MB (74% free)
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 15:52:58, on 24.08.2010
Platform: Windows 7 (WinNT 6.00.3504)
MSIE: Internet Explorer v8.00 (8.00.7600.16385)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\Samsung\Easy Display Manager\dmhkcore.exe
C:\Program Files (x86)\SAMSUNG\EasySpeedUpManager\EasySpeedUpManager.exe
C:\Users\Public\K-7695-6489-5842\csrrsn.exe
C:\Program Files (x86)\AnyPC Client\APLangApp.exe
C:\Download\RSIT.exe
C:\Program Files (x86)\trend micro\Nicolai.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: McAfee Phishing Filter - {27B4851A-3207-45A2-B947-BE8AFE6163AB} - c:\progra~1\mcafee\msk\mskapbho.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files (x86)\Common Files\McAfee\SystemCore\ScriptSn.20100816154622.dll
O2 - BHO: Påloggingshjelp for Windows Live ID - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files (x86)\Google\GoogleToolbarNotifier\5.5.5126.1836\swg.dll
O2 - BHO: McAfee SiteAdvisor BHO - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\PROGRA~2\mcafee\SITEAD~1\mcieplg.dll
O2 - BHO: Java Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
O3 - Toolbar: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~2\mcafee\SITEAD~1\mcieplg.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
O4 - HKLM\..\Run: [updateLBPShortCut] "C:\Program Files (x86)\CyberLink\LabelPrint\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\LabelPrint" UpdateWithCreateOnce "Software\CyberLink\LabelPrint\2.5"
O4 - HKLM\..\Run: [CLMLServer] "C:\Program Files (x86)\CyberLink\Power2Go\CLMLSvc.exe"
O4 - HKLM\..\Run: [updateP2GoShortCut] "C:\Program Files (x86)\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\Power2Go" UpdateWithCreateOnce "SOFTWARE\CyberLink\Power2Go\6.0"
O4 - HKLM\..\Run: [updatePDRShortCut] "C:\Program Files (x86)\CyberLink\PowerDirector\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\PowerDirector" UpdateWithCreateOnce "Software\CyberLink\PowerDirector\7.0"
O4 - HKLM\..\Run: [RemoteControl8] "C:\Program Files (x86)\CyberLink\PowerDVD8\PDVD8Serv.exe"
O4 - HKLM\..\Run: [PDVD8LanguageShortcut] "C:\Program Files (x86)\CyberLink\PowerDVD8\Language\Language.exe"
O4 - HKLM\..\Run: [updatePPShortCut] "C:\Program Files (x86)\CyberLink\PowerProducer\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\PowerProducer" UpdateWithCreateOnce "Software\CyberLink\PowerProducer\5.0"
O4 - HKLM\..\Run: [updatePSTShortCut] "C:\Program Files (x86)\CyberLink\DVD Suite\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\DVD Suite" UpdateWithCreateOnce "Software\CyberLink\PowerStarter"
O4 - HKLM\..\Run: [APLangApp] "C:\Program Files (x86)\AnyPC Client\APLangApp.exe"
O4 - HKLM\..\Run: [uCam_Menu] "C:\Program Files (x86)\CyberLink\YouCam\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\YouCam" UpdateWithCreateOnce "Software\CyberLink\YouCam\2.0"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [sunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [mcui_exe] "C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
O4 - HKCU\..\Run: [DAEMON Tools Lite] "C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe" -autorun
O4 - HKCU\..\Run: [steam] "C:\Program Files (x86)\Steam\Steam.exe" -silent
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [Windows Boot Control] C:\Users\Public\S-2535-6853-2745\winrsvn.exe
O4 - HKCU\..\Run: [XBV6RD5SZF] C:\Users\Nicolai\AppData\Local\Temp\Hj2.exe
O4 - HKCU\..\Run: [Metropolis] rundll32.exe C:\Users\Nicolai\AppData\Local\Temp\sshnas21.dll,GetHandle
O4 - HKCU\..\Run: [WinSysCntrl32] C:\Users\Public\K-7695-6489-5842\csrrsn.exe
O4 - HKUS\S-1-5-19\..\Run: [sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'LOKAL TJENESTE')
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'LOKAL TJENESTE')
O4 - HKUS\S-1-5-20\..\Run: [sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'NETTVERKSTJENESTE')
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'NETTVERKSTJENESTE')
O4 - Global Startup: Bluetooth.lnk = ?
O8 - Extra context menu item: Add to Google Photos Screensa&ver - res://C:\windows\system32\GPhotos.scr/200
O8 - Extra context menu item: Google Sidewiki - res://C:\Program Files (x86)\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_89D8574934B26AC4.dll/cmsidewiki.html
O8 - Extra context menu item: Send bilde til &Bluetooth-enhet... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O8 - Extra context menu item: Send side til &Bluetooth-enhet... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: Send til OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end til OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~2\Office12\REFIEBAR.DLL
O9 - Extra button: Send til Bluetooth - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: Send til &Bluetooth-enhet... - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O10 - Unknown file in Winsock LSP: c:\program files (x86)\common files\microsoft shared\windows live\wlidnsp.dll
O18 - Protocol: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~2\mcafee\SITEAD~1\mcieplg.dll
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\windows\System32\alg.exe (file missing)
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: Bonjour-tjeneste (Bonjour Service) - Apple Inc. - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\WIDCOMM\Bluetooth Software\btwdins.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\windows\system32\fxssvc.exe (file missing)
O23 - Service: Googles oppdateringstjeneste (gupdate) (gupdate) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files (x86)\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\windows\system32\lsass.exe (file missing)
O23 - Service: McAfee SiteAdvisor Service - Unknown owner - C:\Program Files (x86)\McAfee\SiteAdvisor\McSACore.exe
O23 - Service: McAfee Personal Firewall-tjeneste (McMPFSvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee VirusScan Announcer (McNaiAnn) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\Program Files\McAfee\VirusScan\mcods.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McShield - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe
O23 - Service: McAfee Firewall Core Service (mfefire) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mfefire.exe
O23 - Service: McAfee Validation Trust Protection Service (mfevtp) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\mfevtps.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\windows\System32\msdtc.exe (file missing)
O23 - Service: McAfee Anti-Spam Service (MSK80Service) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\windows\system32\lsass.exe (file missing)
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\windows\system32\nvvsvc.exe (file missing)
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\windows\system32\lsass.exe (file missing)
O23 - Service: Rezip - Unknown owner - C:\windows\SysWOW64\Rezip.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files (x86)\CyberLink\Shared files\RichVideo.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\windows\system32\sppsvc.exe (file missing)
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files (x86)\Common Files\Steam\SteamService.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\windows\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\windows\system32\vssvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Wat\WatUX.exe,-601 (WatAdminSvc) - Unknown owner - C:\windows\system32\Wat\WatAdminSvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\windows\system32\wbengine.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%PROGRAMFILES%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
End of file - 13388 bytes
======Scheduled tasks folder======
C:\windows\tasks\GoogleUpdateTaskMachineCore.job
C:\windows\tasks\GoogleUpdateTaskMachineUA.job
C:\windows\tasks\{22116563-108C-42c0-A7CE-60161B75E508}.job
C:\windows\tasks\{35DC3473-A719-4d14-B7C1-FD326CA84A0C}.job
C:\windows\tasks\{62C40AA6-4406-467a-A5A5-DFDF1B559B7A}.job
======Registry dump======
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}]
Adobe PDF Link Helper - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll [2009-02-27 75128]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{27B4851A-3207-45A2-B947-BE8AFE6163AB}]
McAfee Phishing Filter - c:\progra~1\mcafee\msk\mskapbho.dll [2010-05-03 245272]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{7DB2D5A0-7241-4E79-B68D-6309F01C5231}]
scriptproxy - C:\Program Files (x86)\Common Files\McAfee\SystemCore\ScriptSn.20100816154622.dll [2010-05-31 73288]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{9030D464-4C02-4ABF-8ECC-5164760863C6}]
Påloggingshjelp for Windows Live ID - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll [2009-08-18 403840]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AA58ED58-01DD-4d91-8333-CF10577473F7}]
Google Toolbar Helper - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll [2010-07-12 278192]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AF69DE43-7D58-4638-B6FA-CE66B5AD205D}]
Google Toolbar Notifier BHO - C:\Program Files (x86)\Google\GoogleToolbarNotifier\5.5.5126.1836\swg.dll [2010-07-12 814648]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{B164E929-A1B6-4A06-B104-2CD0E90A88FF}]
McAfee SiteAdvisor BHO - c:\PROGRA~2\mcafee\SITEAD~1\mcieplg.dll [2009-01-29 145424]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}]
Java Plug-In 2 SSV Helper - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll [2010-07-10 41760]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar]
{0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - McAfee SiteAdvisor Toolbar - c:\PROGRA~2\mcafee\SITEAD~1\mcieplg.dll [2009-01-29 145424]
{2318C2B1-4965-11d4-9B18-009027A5CD4F} - Google Toolbar - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll [2010-07-12 278192]
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run]
"UpdateLBPShortCut"=C:\Program Files (x86)\CyberLink\LabelPrint\MUITransfer\MUIStartMenu.exe [2009-05-19 222504]
"CLMLServer"=C:\Program Files (x86)\CyberLink\Power2Go\CLMLSvc.exe [2009-06-03 103720]
"UpdateP2GoShortCut"=C:\Program Files (x86)\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe [2009-05-19 222504]
"UpdatePDRShortCut"=C:\Program Files (x86)\CyberLink\PowerDirector\MUITransfer\MUIStartMenu.exe [2008-01-04 222504]
"RemoteControl8"=C:\Program Files (x86)\CyberLink\PowerDVD8\PDVD8Serv.exe [2009-04-15 91432]
"PDVD8LanguageShortcut"=C:\Program Files (x86)\CyberLink\PowerDVD8\Language\Language.exe [2009-04-15 50472]
"UpdatePPShortCut"=C:\Program Files (x86)\CyberLink\PowerProducer\MUITransfer\MUIStartMenu.exe [2008-12-03 218408]
"UpdatePSTShortCut"=C:\Program Files (x86)\CyberLink\DVD Suite\MUITransfer\MUIStartMenu.exe [2009-07-21 210216]
"APLangApp"=C:\Program Files (x86)\AnyPC Client\APLangApp.exe [2009-11-20 13312]
"UCam_Menu"=C:\Program Files (x86)\CyberLink\YouCam\MUITransfer\MUIStartMenu.exe [2009-05-19 222504]
"QuickTime Task"=C:\Program Files (x86)\QuickTime\QTTask.exe [2010-03-18 421888]
"SunJavaUpdateSched"=C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [2010-01-11 246504]
"Adobe Reader Speed Launcher"=C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe [2009-10-03 35696]
"Adobe ARM"=C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2009-09-04 935288]
"mcui_exe"=C:\Program Files\McAfee.com\Agent\mcagent.exe [2010-06-24 1484856]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
"DAEMON Tools Lite"=C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe [2010-04-01 357696]
"Steam"=C:\Program Files (x86)\Steam\Steam.exe [2010-07-05 1238352]
"msnmsgr"=C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe [2010-04-16 3872080]
"Windows Boot Control"=C:\Users\Public\S-2535-6853-2745\winrsvn.exe [2010-08-10 80896]
"XBV6RD5SZF"=C:\Users\Nicolai\AppData\Local\Temp\Hj2.exe [2010-08-22 193536]
"Metropolis"=C:\Users\Nicolai\AppData\Local\Temp\sshnas21.dll [2010-08-23 249344]
"WinSysCntrl32"=C:\Users\Public\K-7695-6489-5842\csrrsn.exe [2010-08-24 47616]
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Bluetooth.lnk - C:\Program Files (x86)\WIDCOMM\Bluetooth Software\BTTray.exe
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad]
WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED}
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\securityproviders]
"SecurityProviders"=credssp.dll
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\mcmscsvc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MCODS]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PEVSystemStart]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\procexp90.Sys]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\AFD]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\McMPFSvc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mcmscsvc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\MCODS]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfefire]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfefirek]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfefirek.sys]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfehidk]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfehidk.sys]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfevtp]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\PEVSystemStart]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\procexp90.Sys]
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"ConsentPromptBehaviorAdmin"=5
"ConsentPromptBehaviorUser"=3
"EnableUIADesktopToggle"=0
"dontdisplaylastusername"=0
"legalnoticecaption"=
"legalnoticetext"=
"shutdownwithoutlogon"=1
"undockwithoutlogon"=1
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\explorer]
"NoActiveDesktop"=1
"NoActiveDesktopChanges"=1
"ForceActiveDesktopOn"=0
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\standardprofile\authorizedapplications\list]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\domainprofile\authorizedapplications\list]
======File associations======
.js - edit - C:\Windows\System32\Notepad.exe %1
.js - open - C:\Windows\System32\WScript.exe "%1" %*
======List of files/folders created in the last 2 months======
2010-08-24 15:33:19 ----D---- C:\Program Files (x86)\trend micro
2010-08-24 15:33:18 ----D---- C:\rsit
2010-08-24 15:24:57 ----D---- C:\!KillBox
2010-08-24 14:28:17 ----RA---- C:\Users\Nicolai\AppData\Roaming\lL166.txt
2010-08-24 14:18:39 ----D---- C:\Users\Nicolai\AppData\Roaming\download2
2010-08-23 15:16:47 ----RA---- C:\Users\Nicolai\AppData\Roaming\JHml0.txt
2010-08-19 03:52:51 ----D---- C:\windows\PCHEALTH
2010-08-19 03:47:56 ----SHD---- C:\Config.Msi
2010-08-19 00:06:59 ----RD---- C:\32788R22FWJFW
2010-08-18 21:25:44 ----RA---- C:\Users\Nicolai\AppData\Roaming\EDIb7.txt
2010-08-16 17:33:18 ----D---- C:\Users\Nicolai\AppData\Roaming\Malwarebytes
2010-08-16 17:33:06 ----A---- C:\windows\SysWOW64\drivers\mbamswissarmy.sys
2010-08-16 17:33:05 ----D---- C:\ProgramData\Malwarebytes
2010-08-16 17:33:04 ----D---- C:\Program Files (x86)\Malwarebytes' Anti-Malware
2010-08-12 14:41:09 ----A---- C:\windows\SysWOW64\schannel.dll
2010-08-12 14:40:53 ----A---- C:\windows\SysWOW64\ntoskrnl.exe
2010-08-12 14:40:53 ----A---- C:\windows\SysWOW64\ntkrnlpa.exe
2010-08-12 14:40:46 ----A---- C:\windows\SysWOW64\mshtml.dll
2010-08-12 14:40:45 ----A---- C:\windows\SysWOW64\wininet.dll
2010-08-12 14:40:45 ----A---- C:\windows\SysWOW64\urlmon.dll
2010-08-12 14:40:45 ----A---- C:\windows\SysWOW64\ieframe.dll
2010-08-12 14:40:44 ----A---- C:\windows\SysWOW64\mstime.dll
2010-08-12 14:40:44 ----A---- C:\windows\SysWOW64\msfeedsbs.dll
2010-08-12 14:40:44 ----A---- C:\windows\SysWOW64\ieui.dll
2010-08-12 14:40:44 ----A---- C:\windows\SysWOW64\iepeers.dll
2010-08-12 14:40:44 ----A---- C:\windows\SysWOW64\iedkcs32.dll
2010-08-12 14:40:43 ----A---- C:\windows\SysWOW64\msfeedssync.exe
2010-08-12 14:40:43 ----A---- C:\windows\SysWOW64\jsproxy.dll
2010-08-12 14:40:35 ----A---- C:\windows\SysWOW64\rtutils.dll
2010-08-12 14:40:33 ----A---- C:\windows\SysWOW64\iccvid.dll
2010-08-12 14:40:30 ----A---- C:\windows\SysWOW64\msxml3.dll
2010-08-10 14:12:55 ----RA---- C:\Users\Nicolai\AppData\Roaming\BjC8G.txt
2010-08-10 11:21:35 ----RA---- C:\Users\Nicolai\AppData\Roaming\Bb7M1.txt
2010-08-10 06:03:30 ----RA---- C:\Users\Nicolai\AppData\Roaming\DchAg.txt
2010-08-10 00:21:52 ----RA---- C:\Users\Nicolai\AppData\Roaming\ml0jD.txt
2010-08-09 21:56:13 ----RA---- C:\Users\Nicolai\AppData\Roaming\Bd6CH.txt
2010-08-08 20:47:15 ----RA---- C:\Users\Nicolai\AppData\Roaming\BD8gm.txt
2010-08-08 20:47:12 ----RA---- C:\Users\Nicolai\AppData\Roaming\BHml0.txt
2010-08-08 18:47:45 ----D---- C:\Team17
2010-08-03 17:55:39 ----A---- C:\windows\SysWOW64\shell32.dll
2010-08-03 17:51:43 ----D---- C:\Program Files (x86)\Adobe
2010-07-13 18:38:42 ----D---- C:\Program Files (x86)\Common Files\Symantec Shared
2010-07-10 20:14:56 ----D---- C:\Users\Nicolai\AppData\Roaming\CyberLink
2010-07-10 18:30:00 ----D---- C:\Users\Nicolai\AppData\Roaming\LimeWire
2010-07-10 18:29:33 ----D---- C:\ProgramData\Sun
2010-07-10 18:29:32 ----D---- C:\Program Files (x86)\Common Files\Java
2010-07-10 18:29:21 ----A---- C:\windows\SysWOW64\javaws.exe
2010-07-10 18:29:21 ----A---- C:\windows\SysWOW64\javaw.exe
2010-07-10 18:29:21 ----A---- C:\windows\SysWOW64\java.exe
2010-07-10 18:29:21 ----A---- C:\windows\SysWOW64\deploytk.dll
2010-07-10 18:29:04 ----D---- C:\Program Files (x86)\Java
2010-07-10 18:27:51 ----D---- C:\Program Files (x86)\LimeWire
2010-07-06 01:04:30 ----D---- C:\ProgramData\Symantec
2010-07-06 01:04:30 ----D---- C:\ProgramData\Norton
2010-07-06 01:04:28 ----D---- C:\ProgramData\NortonInstaller
2010-07-05 23:44:03 ----D---- C:\windows\SysWOW64\Wat
2010-07-05 22:47:44 ----A---- C:\windows\SysWOW64\PresentationHostProxy.dll
2010-07-05 22:47:44 ----A---- C:\windows\SysWOW64\PresentationHost.exe
2010-07-05 22:47:44 ----A---- C:\windows\SysWOW64\netfxperf.dll
2010-07-05 22:47:44 ----A---- C:\windows\SysWOW64\mscoree.dll
2010-07-05 22:47:44 ----A---- C:\windows\SysWOW64\dfshim.dll
2010-07-05 22:12:16 ----D---- C:\ProgramData\Sports Interactive
2010-07-05 22:11:35 ----D---- C:\Users\Nicolai\AppData\Roaming\Sports Interactive
2010-07-05 22:07:40 ----A---- C:\windows\SysWOW64\d3dx10_41.dll
2010-07-05 22:07:40 ----A---- C:\windows\SysWOW64\D3DCompiler_41.dll
2010-07-05 22:07:38 ----A---- C:\windows\SysWOW64\D3DX9_41.dll
2010-07-05 22:07:37 ----A---- C:\windows\SysWOW64\XAPOFX1_3.dll
2010-07-05 22:07:36 ----A---- C:\windows\SysWOW64\XAudio2_4.dll
2010-07-05 22:07:34 ----A---- C:\windows\SysWOW64\xactengine3_4.dll
2010-07-05 22:07:33 ----A---- C:\windows\SysWOW64\X3DAudio1_6.dll
2010-07-05 22:07:31 ----A---- C:\windows\SysWOW64\d3dx10_40.dll
2010-07-05 22:07:31 ----A---- C:\windows\SysWOW64\D3DCompiler_40.dll
2010-07-05 22:07:30 ----A---- C:\windows\SysWOW64\D3DX9_40.dll
2010-07-05 22:07:29 ----A---- C:\windows\SysWOW64\XAudio2_3.dll
2010-07-05 22:07:29 ----A---- C:\windows\SysWOW64\XAPOFX1_2.dll
2010-07-05 22:07:28 ----A---- C:\windows\SysWOW64\xactengine3_3.dll
2010-07-05 22:07:27 ----A---- C:\windows\SysWOW64\X3DAudio1_5.dll
2010-07-05 22:07:26 ----A---- C:\windows\SysWOW64\XAudio2_2.dll
2010-07-05 22:07:26 ----A---- C:\windows\SysWOW64\XAPOFX1_1.dll
2010-07-05 22:07:25 ----A---- C:\windows\SysWOW64\xactengine3_2.dll
2010-07-05 22:07:24 ----A---- C:\windows\SysWOW64\d3dx10_39.dll
2010-07-05 22:07:24 ----A---- C:\windows\SysWOW64\D3DCompiler_39.dll
2010-07-05 22:07:22 ----A---- C:\windows\SysWOW64\D3DX9_39.dll
2010-07-05 22:07:21 ----A---- C:\windows\SysWOW64\XAudio2_1.dll
2010-07-05 22:07:21 ----A---- C:\windows\SysWOW64\XAPOFX1_0.dll
2010-07-05 22:07:20 ----A---- C:\windows\SysWOW64\xactengine3_1.dll
2010-07-05 22:07:20 ----A---- C:\windows\SysWOW64\X3DAudio1_4.dll
2010-07-05 22:07:18 ----A---- C:\windows\SysWOW64\d3dx10_38.dll
2010-07-05 22:07:18 ----A---- C:\windows\SysWOW64\D3DCompiler_38.dll
2010-07-05 22:07:17 ----A---- C:\windows\SysWOW64\D3DX9_38.dll
2010-07-05 22:07:16 ----A---- C:\windows\SysWOW64\XAudio2_0.dll
2010-07-05 22:07:15 ----A---- C:\windows\SysWOW64\xactengine3_0.dll
2010-07-05 22:07:15 ----A---- C:\windows\SysWOW64\X3DAudio1_3.dll
2010-07-05 22:07:14 ----A---- C:\windows\SysWOW64\d3dx10_37.dll
2010-07-05 22:07:14 ----A---- C:\windows\SysWOW64\D3DCompiler_37.dll
2010-07-05 22:07:12 ----A---- C:\windows\SysWOW64\D3DX9_37.dll
2010-07-05 22:07:11 ----A---- C:\windows\SysWOW64\xactengine2_10.dll
2010-07-05 22:07:09 ----A---- C:\windows\SysWOW64\d3dx10_36.dll
2010-07-05 22:07:09 ----A---- C:\windows\SysWOW64\D3DCompiler_36.dll
2010-07-05 22:07:08 ----A---- C:\windows\SysWOW64\d3dx9_36.dll
2010-07-05 22:07:06 ----A---- C:\windows\SysWOW64\xactengine2_9.dll
2010-07-05 22:07:06 ----A---- C:\windows\SysWOW64\d3dx10_35.dll
2010-07-05 22:07:05 ----A---- C:\windows\SysWOW64\D3DCompiler_35.dll
2010-07-05 22:07:04 ----A---- C:\windows\SysWOW64\xactengine2_8.dll
2010-07-05 22:07:04 ----A---- C:\windows\SysWOW64\d3dx9_35.dll
2010-07-05 22:07:03 ----A---- C:\windows\SysWOW64\X3DAudio1_2.dll
2010-07-05 22:07:02 ----A---- C:\windows\SysWOW64\d3dx10_34.dll
2010-07-05 22:07:02 ----A---- C:\windows\SysWOW64\D3DCompiler_34.dll
2010-07-05 22:07:01 ----A---- C:\windows\SysWOW64\d3dx9_34.dll
2010-07-05 22:07:00 ----A---- C:\windows\SysWOW64\xinput1_3.dll
2010-07-05 22:06:59 ----A---- C:\windows\SysWOW64\xactengine2_7.dll
2010-07-05 22:06:58 ----A---- C:\windows\SysWOW64\d3dx10_33.dll
2010-07-05 22:06:58 ----A---- C:\windows\SysWOW64\D3DCompiler_33.dll
2010-07-05 22:06:56 ----A---- C:\windows\SysWOW64\d3dx9_33.dll
2010-07-05 22:06:55 ----A---- C:\windows\SysWOW64\xactengine2_6.dll
2010-07-05 22:06:54 ----A---- C:\windows\SysWOW64\xactengine2_5.dll
2010-07-05 22:06:53 ----A---- C:\windows\SysWOW64\d3dx10.dll
2010-07-05 22:06:50 ----A---- C:\windows\SysWOW64\xactengine2_4.dll
2010-07-05 22:06:50 ----A---- C:\windows\SysWOW64\x3daudio1_1.dll
2010-07-05 22:06:49 ----A---- C:\windows\SysWOW64\d3dx9_31.dll
2010-07-05 22:06:48 ----A---- C:\windows\SysWOW64\xactengine2_3.dll
2010-07-05 22:06:47 ----A---- C:\windows\SysWOW64\xinput1_2.dll
2010-07-05 22:06:46 ----A---- C:\windows\SysWOW64\xinput1_1.dll
2010-07-05 22:06:46 ----A---- C:\windows\SysWOW64\xactengine2_2.dll
2010-07-05 22:06:45 ----A---- C:\windows\SysWOW64\xactengine2_1.dll
2010-07-05 22:06:30 ----A---- C:\windows\SysWOW64\d3dx9_30.dll
2010-07-05 22:06:28 ----A---- C:\windows\SysWOW64\xactengine2_0.dll
2010-07-05 22:06:28 ----A---- C:\windows\SysWOW64\x3daudio1_0.dll
2010-07-05 22:06:27 ----A---- C:\windows\SysWOW64\d3dx9_29.dll
2010-07-05 22:06:26 ----A---- C:\windows\SysWOW64\d3dx9_28.dll
2010-07-05 22:06:24 ----A---- C:\windows\SysWOW64\d3dx9_27.dll
2010-07-05 22:06:22 ----A---- C:\windows\SysWOW64\d3dx9_26.dll
2010-07-05 22:06:17 ----A---- C:\windows\SysWOW64\d3dx9_25.dll
2010-07-05 22:06:15 ----A---- C:\windows\SysWOW64\d3dx9_24.dll
2010-07-05 22:03:39 ----D---- C:\windows\SysWOW64\Adobe
2010-07-05 22:01:45 ----HD---- C:\Program Files (x86)\Zero G Registry
2010-07-05 22:01:45 ----D---- C:\Program Files (x86)\Sports Interactive
2010-07-05 21:57:46 ----D---- C:\Users\Nicolai\AppData\Roaming\Spotify
2010-07-05 21:01:43 ----D---- C:\Program Files (x86)\CCleaner
2010-07-05 20:54:27 ----D---- C:\ProgramData\{93E26451-CD9A-43A5-A2FA-C42392EA4001}
2010-07-05 20:53:16 ----D---- C:\ProgramData\Apple Computer
2010-07-05 20:53:16 ----D---- C:\Program Files (x86)\QuickTime
2010-07-05 20:53:04 ----D---- C:\Program Files (x86)\Apple Software Update
2010-07-05 20:52:44 ----D---- C:\Program Files (x86)\Common Files\Apple
2010-07-05 20:52:34 ----D---- C:\ProgramData\Apple
2010-07-05 20:52:34 ----D---- C:\Program Files (x86)\Bonjour
2010-07-05 20:42:13 ----D---- C:\Users\Nicolai\AppData\Roaming\vlc
2010-07-05 20:41:48 ----D---- C:\Program Files (x86)\VideoLAN
2010-07-05 20:33:42 ----D---- C:\Program Files (x86)\Common Files\Steam
2010-07-05 20:33:40 ----D---- C:\Program Files (x86)\Steam
2010-07-05 20:29:53 ----D---- C:\Users\Nicolai\AppData\Roaming\Mozilla
2010-07-05 20:29:20 ----D---- C:\Program Files (x86)\DAEMON Tools Lite
2010-07-05 20:28:48 ----D---- C:\Users\Nicolai\AppData\Roaming\DAEMON Tools Lite
2010-07-05 20:28:45 ----D---- C:\ProgramData\DAEMON Tools Lite
2010-07-05 20:28:24 ----D---- C:\Program Files (x86)\Mozilla Firefox
2010-07-05 20:26:09 ----D---- C:\Download
2010-07-05 20:24:19 ----D---- C:\Users\Nicolai\AppData\Roaming\Macromedia
2010-07-05 20:24:19 ----D---- C:\Users\Nicolai\AppData\Roaming\Adobe
2010-07-05 20:20:34 ----D---- C:\Users\Nicolai\AppData\Roaming\Google
2010-07-05 19:13:54 ----A---- C:\windows\SysWOW64\ntdll.dll
2010-07-05 19:13:54 ----A---- C:\windows\SysWOW64\asycfilt.dll
2010-07-05 19:13:53 ----A---- C:\windows\SysWOW64\vbscript.dll
2010-07-05 19:13:53 ----A---- C:\windows\SysWOW64\secproc_isv.dll
2010-07-05 19:13:52 ----A---- C:\windows\SysWOW64\secproc.dll
2010-07-05 19:13:52 ----A---- C:\windows\SysWOW64\RMActivate_isv.exe
2010-07-05 19:13:52 ----A---- C:\windows\SysWOW64\RMActivate.exe
2010-07-05 19:13:51 ----A---- C:\windows\SysWOW64\secproc_ssp_isv.dll
2010-07-05 19:13:51 ----A---- C:\windows\SysWOW64\secproc_ssp.dll
2010-07-05 19:13:51 ----A---- C:\windows\SysWOW64\RMActivate_ssp_isv.exe
2010-07-05 19:13:51 ----A---- C:\windows\SysWOW64\RMActivate_ssp.exe
2010-07-05 19:13:50 ----A---- C:\windows\SysWOW64\inetcomm.dll
2010-07-05 19:13:49 ----A---- C:\windows\SysWOW64\t2embed.dll
2010-07-05 19:13:46 ----A---- C:\windows\SysWOW64\explorer.exe
2010-07-05 19:13:46 ----A---- C:\windows\explorer.exe
2010-07-05 19:13:43 ----A---- C:\windows\SysWOW64\wow32.dll
2010-07-05 19:13:43 ----A---- C:\windows\SysWOW64\user.exe
2010-07-05 19:13:43 ----A---- C:\windows\SysWOW64\setup16.exe
2010-07-05 19:13:43 ----A---- C:\windows\SysWOW64\ntvdm64.dll
2010-07-05 19:13:43 ----A---- C:\windows\SysWOW64\instnm.exe
2010-07-05 19:13:20 ----A---- C:\windows\SysWOW64\CPFilters.dll
2010-07-05 19:13:18 ----A---- C:\windows\SysWOW64\psisdecd.dll
2010-07-05 19:13:09 ----A---- C:\windows\SysWOW64\quartz.dll
2010-07-05 19:13:09 ----A---- C:\windows\SysWOW64\msyuv.dll
2010-07-05 19:13:09 ----A---- C:\windows\SysWOW64\msvidc32.dll
2010-07-05 19:13:09 ----A---- C:\windows\SysWOW64\msrle32.dll
2010-07-05 19:13:09 ----A---- C:\windows\SysWOW64\mciavi32.dll
2010-07-05 19:13:09 ----A---- C:\windows\SysWOW64\iyuv_32.dll
2010-07-05 19:13:09 ----A---- C:\windows\SysWOW64\avifil32.dll
2010-07-05 19:13:08 ----A---- C:\windows\SysWOW64\tsbyuv.dll
2010-07-05 19:13:06 ----A---- C:\windows\SysWOW64\jscript.dll
2010-07-05 19:13:04 ----A---- C:\windows\SysWOW64\sspicli.dll
2010-07-05 19:13:04 ----A---- C:\windows\SysWOW64\secur32.dll
2010-07-05 19:12:48 ----A---- C:\windows\SysWOW64\fontsub.dll
2010-07-05 19:12:48 ----A---- C:\windows\SysWOW64\atmlib.dll
2010-07-05 19:12:48 ----A---- C:\windows\SysWOW64\atmfd.dll
2010-07-05 19:12:44 ----A---- C:\windows\SysWOW64\tzres.dll
2010-07-05 19:07:52 ----D---- C:\Users\Nicolai\AppData\Roaming\Identities
2010-07-05 19:07:27 ----D---- C:\Program Files (x86)\Phoenix Technologies Ltd
2010-07-05 19:04:29 ----D---- C:\Program Files (x86)\Microsoft Silverlight
2010-07-05 19:03:25 ----A---- C:\windows\SysWOW64\d3dx9_32.dll
2010-07-05 19:01:58 ----D---- C:\Program Files (x86)\Microsoft
2010-07-05 19:01:33 ----D---- C:\Program Files (x86)\Windows Live SkyDrive
2010-07-05 19:01:28 ----D---- C:\Program Files (x86)\Windows Live
2010-07-05 19:00:18 ----D---- C:\Program Files (x86)\Common Files\Windows Live
2010-07-05 18:59:45 ----D---- C:\Program Files (x86)\Microsoft Office Suite Activation Assistant
2010-07-05 18:56:55 ----D---- C:\Program Files (x86)\Common Files\DESIGNER
2010-07-05 18:56:42 ----D---- C:\Program Files (x86)\Microsoft.NET
2010-07-05 18:55:25 ----D---- C:\ProgramData\Microsoft Help
2010-07-05 18:55:09 ----RHD---- C:\MSOCache
2010-07-05 18:54:05 ----D---- C:\Program Files (x86)\Microsoft Office
2010-07-05 18:53:18 ----D---- C:\Program Files (x86)\Microsoft Works
2010-07-05 18:53:11 ----A---- C:\windows\SysWOW64\wintrust.dll
2010-07-05 18:53:10 ----A---- C:\windows\SysWOW64\cabview.dll
2010-07-05 18:52:12 ----D---- C:\ProgramData\Adobe
2010-07-05 18:51:56 ----D---- C:\Program Files (x86)\Common Files\Adobe
2010-07-05 18:46:18 ----SD---- C:\Users\Nicolai\AppData\Roaming\Microsoft
2010-07-05 18:46:18 ----D---- C:\Users\Nicolai\AppData\Roaming\Media Center Programs
2010-07-05 18:44:24 ----SHD---- C:\Recovery
======List of files/folders modified in the last 2 months======
2010-08-24 15:51:04 ----D---- C:\windows\Temp
2010-08-24 15:34:08 ----D---- C:\windows\Tasks
2010-08-24 15:33:19 ----RD---- C:\Program Files (x86)
2010-08-22 19:47:14 ----D---- C:\windows\System32
2010-08-22 19:47:14 ----D---- C:\windows\inf
2010-08-19 04:17:35 ----D---- C:\windows\Microsoft.NET
2010-08-19 03:53:55 ----SHD---- C:\windows\Installer
2010-08-19 03:53:21 ----D---- C:\windows\SysWOW64
2010-08-19 03:52:51 ----D---- C:\Windows
2010-08-19 03:48:31 ----RSD---- C:\windows\assembly
2010-08-19 03:46:22 ----RD---- C:\Program Files
2010-08-19 03:41:55 ----D---- C:\Program Files (x86)\Common Files\InstallShield
2010-08-19 03:41:51 ----HD---- C:\Program Files (x86)\InstallShield Installation Information
2010-08-19 00:58:54 ----D---- C:\windows\Prefetch
2010-08-16 20:07:46 ----HD---- C:\ProgramData
2010-08-16 19:29:23 ----D---- C:\Program Files (x86)\McAfee.com
2010-08-16 19:29:23 ----D---- C:\Program Files (x86)\Common Files\McAfee
2010-08-16 17:33:06 ----D---- C:\windows\SysWOW64\drivers
2010-08-16 17:25:04 ----D---- C:\Program Files (x86)\McAfee
2010-08-13 20:27:56 ----D---- C:\windows\winsxs
2010-08-13 20:26:18 ----D---- C:\windows\SysWOW64\migration
2010-08-13 20:26:18 ----D---- C:\Program Files (x86)\Internet Explorer
2010-08-13 09:52:19 ----SHD---- C:\System Volume Information
2010-08-03 17:48:17 ----D---- C:\ProgramData\Partner
2010-07-15 00:57:07 ----D---- C:\windows\LiveKernelReports
2010-07-14 03:01:17 ----SD---- C:\ProgramData\Microsoft
2010-07-06 16:01:22 ----D---- C:\ProgramData\CyberLink
2010-07-06 15:53:52 ----D---- C:\ProgramData\McAfee
2010-07-06 06:09:32 ----D---- C:\ProgramData\WinClon
2010-07-06 01:53:35 ----D---- C:\windows\rescache
2010-07-05 23:44:08 ----D---- C:\Program Files (x86)\Windows Mail
2010-07-05 23:44:06 ----D---- C:\windows\AppPatch
2010-07-05 23:44:03 ----D---- C:\windows\ehome
2010-07-05 23:43:59 ----D---- C:\windows\SysWOW64\nb-NO
2010-07-05 22:53:59 ----D---- C:\windows\debug
2010-07-05 22:44:35 ----D---- C:\Program Files (x86)\Common Files\microsoft shared
2010-07-05 22:05:04 ----D---- C:\windows\Logs
2010-07-05 20:45:08 ----D---- C:\Program Files (x86)\Google
2010-07-05 19:51:42 ----D---- C:\Program Files (x86)\Windows Sidebar
2010-07-05 19:51:42 ----D---- C:\Program Files (x86)\Windows Photo Viewer
2010-07-05 19:51:42 ----D---- C:\Program Files (x86)\Windows Media Player
2010-07-05 19:51:42 ----D---- C:\Program Files (x86)\Windows Defender
2010-07-05 19:51:42 ----D---- C:\Program Files (x86)\Common Files\System
2010-07-05 19:51:41 ----D---- C:\windows\servicing
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\XPSViewer
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\winrm
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\WCN
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\wbem
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\sv-SE
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\slmgr
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\Printing_Admin_Scripts
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\MUI
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\migwiz
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\DriverStore
2010-07-05 19:51:40 ----D---- C:\windows\SysWOW64\Dism
2010-07-05 19:51:37 ----D---- C:\windows\SysWOW64\com
2010-07-05 19:51:37 ----D---- C:\windows\PolicyDefinitions
2010-07-05 19:51:37 ----D---- C:\windows\IME
2010-07-05 19:51:25 ----D---- C:\windows\SysWOW64\fi-FI
2010-07-05 19:51:11 ----D---- C:\windows\SysWOW64\en-US
2010-07-05 19:51:11 ----D---- C:\windows\SysWOW64\drivers\en-US
2010-07-05 19:51:07 ----D---- C:\windows\en-US
2010-07-05 19:51:05 ----D---- C:\windows\Speech
2010-07-05 19:38:57 ----D---- C:\windows\SysWOW64\da-DK
2010-07-05 19:07:45 ----SHD---- C:\$Recycle.Bin
2010-07-05 19:07:18 ----D---- C:\windows\MSetup
2010-07-05 19:05:38 ----D---- C:\Program Files (x86)\CyberLink
2010-07-05 19:05:19 ----D---- C:\ProgramData\Temp
2010-07-05 18:59:02 ----RSD---- C:\windows\Fonts
2010-07-05 18:55:43 ----D---- C:\windows\ShellNew
2010-07-05 18:46:18 ----RD---- C:\Users
======List of drivers (R=Running, S=Stopped, 0=Boot, 1=System, 2=Auto, 3=Demand, 4=Disabled)======
R0 iaStor;Intel AHCI Controller; C:\windows\system32\DRIVERS\iaStor.sys []
R0 mfehidk;McAfee Inc. mfehidk; C:\windows\system32\drivers\mfehidk.sys []
R0 rdyboost;ReadyBoost; C:\windows\System32\drivers\rdyboost.sys []
R0 sptd;sptd; C:\windows\System32\Drivers\sptd.sys []
R1 mfenlfk;McAfee NDIS Light Filter; C:\windows\system32\DRIVERS\mfenlfk.sys []
R1 mfewfpk;McAfee Inc. mfewfpk; C:\windows\system32\drivers\mfewfpk.sys []
R1 SABI;SAMSUNG Kernel Driver For Windows 7; \??\C:\windows\system32\Drivers\SABI.sys []
R1 vwififlt;Virtual WiFi Filter Driver; C:\windows\system32\DRIVERS\vwififlt.sys []
R3 athr;Atheros Extensible Wireless LAN device driver; C:\windows\system32\DRIVERS\athrx.sys []
R3 cfwids;McAfee Inc. cfwids; C:\windows\system32\drivers\cfwids.sys []
R3 CryptOSD;Phoenix CryptOSD Device Driver; C:\windows\system32\DRIVERS\CryptOSD.sys []
R3 IntcAzAudAddService;Service for Realtek HD Audio (WDM); C:\windows\system32\drivers\RTKVHD64.sys []
R3 mfeapfk;McAfee Inc. mfeapfk; C:\windows\system32\drivers\mfeapfk.sys []
R3 mfeavfk;McAfee Inc. mfeavfk; C:\windows\system32\drivers\mfeavfk.sys []
R3 mfefirek;McAfee Inc. mfefirek; C:\windows\system32\drivers\mfefirek.sys []
R3 NVHDA;Service for NVIDIA High Definition Audio Driver; C:\windows\system32\drivers\nvhda64v.sys []
R3 SynTP;Synaptics TouchPad Driver; C:\windows\system32\DRIVERS\SynTP.sys []
S3 a73wb1zv;a73wb1zv; C:\windows\SysWOW64\drivers\a73wb1zv.sys []
S3 BthEnum;Bluetooth Enumerator Service; C:\windows\system32\DRIVERS\BthEnum.sys []
S3 BthPan;Bluetooth Device (Personal Area Network); C:\windows\system32\DRIVERS\bthpan.sys []
S3 BTHPORT;Bluetooth Port-driver; C:\windows\System32\Drivers\BTHport.sys []
S3 BTHUSB;Bluetooth Radio USB-driver; C:\windows\System32\Drivers\BTHUSB.sys []
S3 btusbflt;Bluetooth USB Filter; C:\windows\system32\drivers\btusbflt.sys []
S3 btwaudio;Bluetooth-lydenhet; C:\windows\system32\drivers\btwaudio.sys []
S3 btwavdt;Bluetooth AVDT; C:\windows\system32\DRIVERS\btwavdt.sys []
S3 btwl2cap;Bluetooth L2CAP Service; C:\windows\system32\DRIVERS\btwl2cap.sys []
S3 btwrchid;btwrchid; C:\windows\system32\DRIVERS\btwrchid.sys []
S3 igfx;igfx; C:\windows\system32\DRIVERS\igdkmd64.sys []
S3 Impcd;Impcd; C:\windows\system32\DRIVERS\Impcd.sys []
S3 mfeavfk01;McAfee Inc.; C:\windows\SysWOW64\drivers\mfeavfk01.sys []
S3 mferkdet;McAfee Inc. mferkdet; C:\windows\system32\drivers\mferkdet.sys []
S3 pciide;pciide; C:\windows\system32\DRIVERS\pciide.sys []
S3 RFCOMM;Bluetooth Device (RFCOMM Protocol TDI); C:\windows\system32\DRIVERS\rfcomm.sys []
S3 RTL8167;Realtek 8167 NT Driver; C:\windows\system32\DRIVERS\Rt64win7.sys []
======List of services (R=Running, S=Stopped, 0=Boot, 1=System, 2=Auto, 3=Demand, 4=Disabled)======
R2 Apple Mobile Device;Apple Mobile Device; C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [2010-06-10 144176]
R2 Bonjour Service;Bonjour-tjeneste; C:\Program Files (x86)\Bonjour\mDNSResponder.exe [2010-05-18 345376]
R2 btwdins;Bluetooth Service; C:\Program Files\WIDCOMM\Bluetooth Software\btwdins.exe [2009-10-02 873248]
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service; C:\Program Files (x86)\McAfee\SiteAdvisor\McSACore.exe [2009-01-23 203280]
R2 McMPFSvc;McAfee Personal Firewall-tjeneste; C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 355440]
R2 mcmscsvc;McAfee Services; C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 355440]
R2 McNaiAnn;McAfee VirusScan Announcer; C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 355440]
R2 McNASvc;McAfee Network Agent; C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 355440]
R2 McProxy;McAfee Proxy Service; C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 355440]
R2 McShield;McShield; C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe [2010-05-31 199032]
R2 mfefire;McAfee Firewall Core Service; C:\Program Files\Common Files\McAfee\SystemCore\\mfefire.exe [2010-05-31 244840]
R2 mfevtp;McAfee Validation Trust Protection Service; C:\Program Files\Common Files\McAfee\SystemCore\mfevtps.exe [2010-05-31 148520]
R2 MSK80Service;McAfee Anti-Spam Service; C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 355440]
R2 nvsvc;NVIDIA Display Driver Service; C:\windows\system32\nvvsvc.exe []
R2 Rezip;Rezip; C:\windows\SysWOW64\Rezip.exe [2009-03-05 311296]
R2 RichVideo;Cyberlink RichVideo Service(CRVS); C:\Program Files (x86)\CyberLink\Shared files\RichVideo.exe [2009-07-07 247152]
R2 wlidsvc;Windows Live ID Sign-in Assistant; C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE [2009-08-18 2291568]
S2 gupdate;Googles oppdateringstjeneste (gupdate); C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2010-07-05 135664]
S3 gusvc;Google Software Updater; C:\Program Files (x86)\Google\Common\Google Updater\GoogleUpdaterService.exe [2010-03-11 182768]
S3 McODS;McAfee Scanner; C:\Program Files\McAfee\VirusScan\mcods.exe [2010-04-15 509416]
S3 odserv;Microsoft Office Diagnostics Service; C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE12\ODSERV.EXE [2008-11-04 441712]
S3 ose;Office Source Engine; C:\Program Files (x86)\Common Files\Microsoft Shared\Source Engine\OSE.EXE [2006-10-26 145184]
S3 Steam Client Service;Steam Client Service; C:\Program Files (x86)\Common Files\Steam\SteamService.exe [2010-08-08 407336]
S3 WatAdminSvc;@%SystemRoot%\system32\Wat\WatUX.exe,-601; C:\windows\system32\Wat\WatAdminSvc.exe []
-----------------EOF-----------------
Kjører Malwarebytes' nå. KOmmer med logg når den har kjørt seg ferdig.
Malwarebytes'
Windows 6.1.7600
24.08.2010 17:32:09
mbam-log-2010-08-24 (17-32-09).txt
Objekter skannet: 308546
Tid tilbakelagt: 1 time®, 34 minutt(er), 9 sekund(er)
Minneprosesser infisert: 1
Registernøkler infisert: 2
Registerverdier infisert: 5
Mapper infisert: 0
Filer infisert 29
C:\Users\Public\K-7695-6489-5842\csrrsn.exe (Backdoor.Bot) -> Unloaded process successfully.
C:\Users\Nicolai\AppData\Local\Temp\sshnas21.dll (Trojan.Downloader) -> Delete on reboot.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\winsyscntrl32 (Backdoor.Bot) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\metropolis (Trojan.Downloader) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\java developer script browse (Trojan.Downloader) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\bk (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\idln2 (Malware.Trace) -> Quarantined and deleted successfully.
Mapper infisert:
Filer infisert
C:\Users\Public\K-7695-6489-5842\csrrsn.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\!KillBox\Temp\5298422.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$R42AGEA.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$R7ACOKR.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$R874MMK.log (Extension.Mismatch) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RAK3EKU.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RDELY2T.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RE0IV61.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$REATC0D.log (Extension.Mismatch) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RGM8Y16.log (Extension.Mismatch) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RH7MTDE.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RH8DWBC.log (Extension.Mismatch) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RHT650X.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RMA3NS3.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RN1G9S0.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RRMQMOJ.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RS3HWUZ.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RXXKM0Y.log (Extension.Mismatch) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RZKDLOT.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\$Recycle.Bin\S-1-5-21-3308257777-3062976545-735110923-1001\$RZQSIQF.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\0862237.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\5777403.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Local\Temp\Bl7jC8GleG.log (Extension.Mismatch) -> Quarantined and deleted successfully.
C:\Users\Nicolai\AppData\Roaming\chrtmp (Malware.Trace) -> Quarantined and deleted successfully.
C:\Users\Public\jusched.exe (Trojan.Downloader) -> Delete on reboot.
Endret av Umlaut
