[GTA]Hvordan bruke kodene på IV?
Kodene er telefonnummer du kan ringe med mobilen.
Dial cheats into Niko's cell phone (press up). Note: do not save after entering a cheat - this may cause problems, and may prevent you from unlocking certain achievements.
http://www.gtaivchea...s-xbox-360.html
Lukke til.
Hei, takk for svare. du va nå hyggeligge i forhold til han andre.... men eg har prøvd og slå inn nommeret, ingenting skjer.
Hmm, då er eg ikkje sikker på kva det kan vere. Eg har dessverre ikkje GTA IV tilgjengeleg her, så eg får ikkje testa det ut sjølv. Har du prøvd fleire forskjellege kodar? Det kan vere at ikkje alle fungerer.
Her er ei meir detaljert beskriving eg fann.
While playing the game, press Up to display Niko's cell phone. Press Up again to access the keypad. Then, enter one of the following codes to activate the corresponding cheat function. Once a code has been entered correctly, a new "Cheats" menu option will be available on your phone, below "Options", where you can access the cheats without having to enter the phone number again. Note: Do not save the game after enabling a code to avoid unforeseen problems. Enabling some cheats will prevent the indicated achievement(s) from being earned. You can usually only spawn one vehicle at a time. Any previously spawned vehicles will disappear. However, if you spawn a vehicle, save the game, and load again, you can spawn another one and your original will not disappear. You must have it in your parking space in front of a safehouse or it will be gone before you have a chance to spawn another.
http://www.cheatcc.com/xbox360/grandtheftauto4cheatscodes.html
http://www.cheatcc.c...heatscodes.html
Ja, eg har prøvd fleire kodar... men d nytar ikkje, det står noko om multiplayer og redigere noe.... husker ikke, avinstalerte d, brukte litt plass.
