Småprat rundt/om CoD: Black Ops
"The Intervention is available at level 4, when Create-A-Class is unlocked. The rifle has a low fire rate and high sway, but has high damage multipliers with varying levels of recoil. Extended Magazines doubles its 5-round capacity, which is the lowest of all sniper rifles.
With Stopping Power, the weapon kills in one hit to the head, neck, chest and stomach. Without, shots to the stomach will not gain a kill, unless the target is already damaged. These only apply in normal circumstances, targets will require multiple hits when Painkiller, Last Stand or Final Stand is used. However, Headshots cancel out Last and Final Stand.
With a Silencer, Stopping Power is needed to get any one-hit-kills, and even then, only Head-Chest shots will do so.
In Hardcore, the weapon will always neutralize targets with or without Stopping Power, regardless of attachments, again unless Last Stand, Final Stand or Painkiller is being used by enemies. Due to this fact, other sniper rifles are recommended, as the Intervention's low rate of fire lets it down as other rifles can attain one hit kills while having higher rates of fire and low recoil - as well as higher magazine capacities.
The rifle is the best to do the "Perfectionist" challenge due to its low magazine capacity. Also, it has a very quick Reload Cancel when reloading an empty magazine. Its ammo counter is filled as soon as the mag is taken out.
The Intervention is statistically outclassed by the Barrett .50 Cal, sharing the same damage multipliers while having a slower rate of fire. Though the Barrett is limited by it's recoil, it can still hit follow-up shots significantly faster than the Intervention. Some people believe the Intervention is somehow more accurate, but there is no evidence to support this. Despite it's drawbacks, the Intervention is a popular weapon for it's bolt-action "feel," and is common among quick-scopers and people making montage clips. "
Det er en grunn til at jeg har spillt MW2 hver dag siden release.
Her er grunnen:
(tatt fra profil)
Alder:15 år gammel
Men du er over 12 år, så egentlig for gammel til slike spill.
Har selv spilt det hele tiden siden det kom ut med litt pauser på noen uker til en mnd pga at spillet irriterer meg litt for mye av og til.
anywaays ON TOPIC!
Hvis BO får ett veldig stort irritasjonsmoment blir det RC-car tenker jeg. Siden den kun krever 3 kills og varer så lenge du vil.
Simpel forklaring: Han spillte softcore og at alle skuddene penentrerte gjennom bomba. Når skudd penetrerer gjennom diverse objekter, vil skuddene nesten ikke ta skade på fienden i det hele tatt.
var den beste videoen jeg fant da. tror du hadde blitt ganske wtf og videoen med spawnkillingen ikke var tatt vekk.
uansett, moro at duden fikk 7 hitmarkere, for så å bli sprayet ned over mappet, av et våpen med thermal.
