Windows Aero Label Problem
Jeg har i et par dager nå prøvd meg på å programmere med Windows Aero i programmer. Men jeg har støtt på et problem, hvordan får jeg brukt Label, Button, TextBox på Aero?
KODEN:
Imports System.Runtime.InteropServices
Public Class Form1
   <StructLayout(LayoutKind.Sequential)> _
   Public Structure MARGINS
       Public cxLeftWidth As Integer
       Public cxRightWidth As Integer
       Public cyTopHeight As Integer
       Public cyButtomheight As Integer
   End Structure
   <DllImport("dwmapi.dll")> _
   Public Shared Function DwmExtendFrameIntoClientArea(ByVal hWnd As IntPtr, ByRef pMarinset As MARGINS) As Integer
   End Function
   Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
       On Error Resume Next
       Dim margins As MARGINS = New MARGINS
       margins.cxLeftWidth = -1
       margins.cxRightWidth = -1
       margins.cyTopHeight = -1
       margins.cyButtomheight = -1
       'set all the four value -1 to apply glass effect to the whole window
       'set your own value to make specific part of the window glassy.
       Dim hwnd As IntPtr = Me.Handle
       Dim result As Integer = DwmExtendFrameIntoClientArea(hwnd, margins)
   End Sub
End Class
