Info om den nye Dell UltraSharp U3011
B-QL
REVIEW 16.09.2010: http://www.cnet.com.au/dell-ultrasharp-u3011-339305812.htm
Editor's rating: 9.0
Conclusion
The U3011 is massive and sublime. It's by no means cheap, but you're paying for the panel. For those who can justify it, it brings much needed improvements over the 3008WFP. For those who can't, go for the U2711 instead.
REVIEW 13.10.2010: http://www.tftcentral.co.uk/reviews/dell_u3011.htm
Overall though I thought this was another excellent addition to the Dell monitor range. It's backed by Dell's well-regarded support and warranty, and their price is very competitive as ever. Well worth looking at if you want a 30" screen.
Nå er den lagt ut på Dell.com, 1499.00$
http://accessories.us.dell.com/sna/products/Displays/productdetail.aspx?c=us&l=en&cs=19&sku=224-9949
Dustinhome.no har også fått den:
http://www.dustinhome.no/pd_5010483369.aspx
Driver til skjermen:
http://support.euro.dell.com/support/downloads/download.aspx?c=no&l=no&s=gen&releaseid=R272770&formatcnt=0&libid=0&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=404834
Endret av B-QL
DellTM UltraSharpTM U3011 30”W Monitor with PremierColor
DISPLAY
Panel Size:
75.6 cm
30 Inches (30-inch wide viewable image size)
Aspect Ratio
Widescreen (16:10)
Panel Type:
IPS (In-Plane Switching )
Optimal Resolution:
2560 x 1600 at 60 Hz
Contrast Ratio:
1000: 1 (typical), Dynamic Contrast Ratio: 100,000:1 (Max)
Brightness:
370 cd/m2 (typical)
Response Time:
7ms (gray to gray)
Viewing Angle
(178° vertical / 178° horizontal)
Color Support:
1.07 billion colors
Pixel Pitch:
0.2505mm
Display Type
Widescreen Flat Panel Display
CONNECTIVITY
2 High Definition Multimedia Interface (HDMI)
2 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
Component Connectors
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
7 in 1 Media reader
DC power connector for Dell Soundbar
STAND
Height-Adjustable stand,tilt and swivel and built in cable-management
BUILT-IN DEVICES
Media Card Reader and USB 2.0 Hi-Speed Hub (with 1 USB upstream port and 4 USB downstream ports)
SECURITY
Security lock slot (cable lock sold separately)
Anti-theft stand lock slot (to panel), Capacitive touch controls
COLOR, SIZE AND WEIGHT
Dimensions (W x D x H):
694.5 x 211.3 x 481.3 mm ~ 571.3 mm (27.34”x8.32”x18.95” ~ 22.50”)
Weight (panel only - for VESA mount)
9.3 kg (20.40 lbs)
Weight (with packaging)
15.3kg (33.76lbs)
Environmental and Regulatory
ELECTRICAL
Voltage Required:
100 to 240 VAC / 50 or 60 Hz ±3Hz / 2.5 A (Max)
Power Consumption (Operational):
110W(typical) / 250W(maximum)**
** Maximum power consumption with max luminance, Dell Soundbar, and USB active.
Power Consumption Stand by / Sleep:
Less than 2 W
ENVIRONMENTAL
Temperature Range Operating:
5° to 35° C (41° to 95° F)
Temperature Range Non-operating:
Storage : -20° to 60° (-4° to 140° F)
Shipping : -20° to 60° (-4° to 140° F)
Humidity Range Operating:
10% to 80% (non-condensing)
Humidity Range Non-operating:
Storage : 5% to 90% (non-condensing)
Shipping : 5% to 90% (non-condensing)
Altitude Operating:
3,657.6 m (12,000 ft) max
Altitude Non-operating:
12,192 m (40,000 ft) max
COMPLIANCE AND STANDARDS
ENERGY STAR 5.0
EPEAT Silver
Product Safety, EMC and Environmental Datasheets
Dell Regulatory Compliance Home Page
Dell and the Environment
WHAT'S IN THE BOX
Monitor with stand
Power Cable
DVI Cable
DisplayPort(DP) Cable
VGA Cable (attached to the monitor)
Drivers and Documentation media
Color Calibrated Factory-Report
Quick Setup Guide
Safety Information
Endret av B-QL
Perverse priser. Sett den ned til 10k så kjøper jeg øyeblikkelig. 30" prisene har ikke rørt seg på 3-4 år, og det har heller ikke kommet noen nye modeller iløpet av denne tiden. Prisnivået er derfor fullstendig uholdbart når det er snakk om gamle modeller med dårlige specs, og når man får en fersk 27" 2560x1440 til 6000kr (U2711).
Jeg er også skeptisk til å kjøpe en så dyr skjerm nå som 120hz og en ny HDMI revisjon er på trappene.
Endret av mad_arab
  • 1 måned senere...
  • 3 uker senere...
  • 2 uker senere...
