Starcraft II: Generell Diskusjon
236 stemmer
  1. 1. Cheese taktikker yes/no?
    • Ja! Det er ingen problem med cheesing.
    • Nei! Det er helt patetisk!
Reposter siden vi endelig snakker om gameplay. Se punkt nr 1 :) Scout scout scout. Du må finne ut hva mostandern har begynt å produsere og bygge, så du kan bygge motstykker til hans units fortest mulig. SC2 følger de gamle stein,saks,papir reglene der alle enheter har (minst) en motpart som ødelegger den på null komma niks.
Scouting vil også hjelpe dere å forme en plan for tech tree upgrades så dere går for spesifikke strategier ikke bare alt mulig på en gang og taper.
En fin PC Gamer artikkel om hvordan bli bedre i SC2 multiplayer:
1. Adapt to survive
The single most important piece of advice is to base your build order on the enemy's build order. To do this, you need to learn to scout - this means sending out a Drone, Probe or SCV right after the start of a match to spy on what the other guy's building. You need to recognise every unit type on sight, and build accordingly.
2. Rinse, repeat
While you're scouting, you need to be starting off your economy. There are various strategies for this, but your first move should always be to set your Gatherer's onto Crystal deposits. Make sure they don't all cluster around one or movement will be slowed. Vespene Geysers can come a little later depending on your build order. Whatever you do, though, don't stop building Gatherers.
3. Don't be a miser
If you have money in the bank, you're wasting it. Your crystal and vespene gas reserves should rarely pass about 200, so spend, spend, spend. There is always an upgrade or some sort of unit limit increases that you can buy. Also resist queuing multiple units up, as that leaves money you could spend instantly on something else floating in limbo.
4. Try a ZERG RUSH
This technique's known as the 8-pool. Don't morph any Drones, but get up a Spawning Pool as soon as you hit 200 crystal. Next get a couple of Drones in, then an Overlord, then go hell for leather on morphing Zerglings. Once you've got six, charge the enemy base, aiming for a major structure. Have two more hot on their heels, and ready a Queen and a Roach Warren next.
5. Beat a turtler
If you think you're facing off against a turtling (heavy defence) player, you're often best cutting off his expansion rather than trying to crack his shell. With cheap units, harass the crystal/gas deposits near him to stop him claiming them while you're building your main army, and he'll struggle to build a fat enough force to hold off your eventual big guns.
6. Stick to THE PLAN
Learn and practice a variety of build orders. An on-the-fly hotchpotch will never work: you need to pick a plan in the early stages and commit to it. Think in terms of specific forces, rather than having to have one of everything (eg. ground assault or anti-air). Again, this should be based on what your scouting suggests the enemy is building.
7. Use your keyboard
You need to keep building while fighting, but setting up build queues takes time. But you can do it without taking your eyes off a fight by using hotkeys to select a production building and queue a unit. For instance tapping H and the Z gets you a zergling in a millisecond, while pressing B than A delivers a Terran Marine. Far faster than mousing around the map.
8. Momentous Macros
Each race has at leaast one very cheap manually activated temporary ability that boosts something significant. The Protoss Chrono Boost will makes a select building 25% faster, the Terran Mule can grab crystals at triple normal gather speed, and the Zerg Queen can spawn extra larvae. These are NOT optional toys: you need to be activating one every couple of minutes.
Endret av Bytex
AtW: Du om det, frøken negativ. :p Du får spørre om de gidder lage de to expansionene som en patch, så du slipper å cracke... øh, bruke internett for å spille dem. :p
Funny Funny, det er bare det at spillet vil/har allerede blitt cracket, og de som kjører cracket versjon slipper disse problemene. Det er bare tull å påstå at man må ha noe online verifisering av singleplayer for å ha matchmaking, achievments eller å slippe å ha i dvden.
AtW
De tingene jeg nevnte er bare noen av bonusene. Selvsagt er piratkopiering en stor grunn til hvorfor de krever at man er på nettet. Men poenget er at i stedet for å gi oss en kjip DRM som ikke tilfører noe som helst har de dratt den helt ut og virkelig gitt oss en grunn til å være koblet til nettet. Og seriøst, er det virkelig et problem i våre dager? Har du tilgang på mobiltelefon har du tilgang til bredbånd, så det er ikke noe unnskyldning. Bor du et sted så langt ute i ødemarken at du ikke har dekning til mobilen bør du nok flytte.
Edit: Selv har jeg bredbånd fra ICE, så jeg kan spille Starcraft 2 i bilen på vei til jobb om jeg vil. Bør kanskje parkere først, da. :p
Endret av vikingkylling
Er det noen plass man kan kjøpe spillet digital online? Slik at jeg bare får en CDkey? Vet du har Blizzard store, men 60 Euro blir i meste laget, da kan jeg likeså ta en tur til butikken.
jepp, jeg tok turen til Lefdal og kjøpte spillet for 299 og en is til 50 øre :)
men noen som har noen formening om når man kan spille zerg eller protos campaign? Regner vel med at det ikke har kommet noe info om dette enda men kan no diskutere/gjette oss til. Elsker storyen men hater terran så jeg sliter meg gjennom campaign no  :thumbdown:
Btw, noe sier meg at neste campaign blir zerg.
Hvorfor i svarte svingende får jeg beskjed om at kontoen min ikke er knyttet opp mot en starcraft nøkkel.
Jeg kjøpte starcraft 2 digitalt fra blizzard, prøver å logge inn når spillet er installert og får beskjed om at jeg ikke har nøkkel. Inne på battle.net kontoen står det ACTIVE; og jeg får heller ikke lov å kjøpe ny lisens ettersom jeg allerede har en.. HVA POKKER ER DETTE FOR NOE DRIT BLIZZARD!?
noen som har hørt om lignende problemer?
Kan vel ha noe med at det var release i dag og xxxxxxx antall folk prøver å logge på samtidig? ;)
Ja, noe blizzard bør regne med, men de er for opptatt med å insitere på at folk må være online selv for singleplayer at de ikke bryr seg om at man blir rævkjørt som lovlig kunde...
AtW
Det er en stor forskjell på å "må være online" og å "må være på battle.net". Settlers 7, Assassin's Creed 2 osv krever at du er på nettet når du spiller, men det tilfører ikke en dritt. SC2 krever at du er på battle.net, men til gjengjeld får du online achivements, du slipper å bruke platen selv om du kjøpte den i butikk (nettopp testet selv), du får en svært bra matchmaking (kanskje ikke med den beste vennelisten, men har ikke prøvd den selv) og så videre. Akkurat nå er det nok litt problem for noen å logge seg på, men det vil roe seg over de neste dagene. Til tross for problemene vil du nok være enig i at det er langt flere fordeler enn ulemper med det nye systemet. Og da har vi ikke engang begynt å diskutere piratkopiering, DRM og alt det tullet der. ;)
Det er ikke noen praktisk forskjell på å være online og på Battle.net. Resultatet er uansett at du må koble deg til nettet for å kunne spille singleplayer.
Jeg er ikke interessert i achievements. Jeg vil bare spille. Offline. Men Blizzard har bestemt seg for at de skal spionere på meg når jeg gjør dette.
Hvilke fordeler har det nye systemet for oss som ikke vil ha noe som helst med noe som har noe med online å gjøre i singleplayer?
Jeg skal gå med på at det er praktisk å kunne spille uten plata i, men utover det kan jeg ikke komme på noe som ikke like greit kunne blitt synkronisert når du eventuelt logget på Battle.net.
AtW
Hvilken grunn har de gitt oss til å kaoble på nettet i singleplayer? Alt kunne vært oppnådd uten å være koblet på nettet. Og ja, det er jo åpenbart et problem, se på alle som har hatt trøbbel, har dette vært folk uten nett? Nei, det har det ikke, men allikevel har nett-tullet skapt trøbbel. Og selvsagt bør man flytte, blizzard gjør aldri noe galt, folk må jo bare forvente å skifte bosted for å følge blizzards vilje.
AtW
Kjøpte spillet for 299 på elkjøp igår. installerte og spilte igjennom 3 campaign oppdrag. Var sinnsykt morsomt, og veldig bra. Aldri spilt SC før, bare Age of Empires og Warcraft. Men dette var faktisk veldig bra.
noen som la merke til reklamen på tv skjermen i kantina, har reklame for "iPistol" :)
Herreguuuuud som jeg hater eskorte-missions. Ødela nesten lysten på å fortsette.
Terrans er ikke så gøy å spille nei, nesten like kjedelig som human i WoW. Minner meg om hjernedøde rednecks som stemte på Bush.
Enig.
Ga meg faktisk i går etter kun ett forsøk på det første escort missionet. Brutal er ganske hardt (whoda thunk it?). :)
Man må ikke ha konstatt internett tilkobling mens man spiller. Har ikke testet å start campeign uten å logge inn enda, men merket at jeg mista tilkobling til battle.net i noen sekunder, og fikk en melding om at jeg ikke kunnne få achievements da. Men fikk fortsatt lov til å spille.
Satt oppe til rett rundt halv 1 jeg også. Var slit å komme seg opp i dag, men DAMN så morro! Musikken er jo drit rå, og ler godt hver gang jeg ser på nyhetskanalen. Likte også den Viking arcade maskinen. ^_^
Veldig kult med upgrades og research også! Kan nå bygge supply depots uten noe konstruksjons tid. Orbital drop supply depots=konge! :D
Da har jeg også anskaffet dette. Var aldri noe flink i SC, men nå som jeg er litt eldre kan jeg kanskje klare og også tenke litt taktikk og strategi. Sliter fortsatt litt med å holde oversikten når jeg skal være på 17 steder samtidig. >_<
Hittil er iallefall campaign grisegøy. Spilte 4 timer-ish i går. Holder meg til Normal inntil videre. Blir bare sint og lei om jeg skal sliiite meg gjennom hvert oppdrag.
Haha! La merke til det selv. Masse små nuggets overalt. Liker'e!
*mine innlegg*
Endret av Joakim Skurk
