Doofenscmitz treningslogg! Nå semi deaktivert...
Begynner innspurten neste uke med DETTE :new_woot:
Jeg tror jeg begynner fra uke 4 for høy nok intensitet, var dette jeg fulgte i fjor for å bli FIT...
8 Ukers forbrenningsprogram
UKE1
A1: One Arm DB Squat 3x15
A2: Dumbbell Press 3x12 50 sec
B1: Band Row 3x12
B2: Hamstring Curl with Stability Ball 3x15 50 sec
C1: Shoulder Press with dumbbell 2x12
C2: Bicep Curl with dumbbell 2x12 50 sec
D1: Regular Plank 2x45 sec
D2: One Leg Calf Raise 2x15 50 sec
UKE 2
A1: Split Bulgarian Squat with dumbbell 3x10 ea
A2: Pull ups 3x12 45 sec
B1: Hip Bridge with Stability Ball 3x12
B2: Bench Press 3x10 45 sec
C1: Shoulder DB Press on the ball 2x12
C2: Calf Raise 2x12 50 sec
D1: Bicycle Kick 2x25+
D2: Superman 2x12 50 sec
UKE 3
A1: Barbell Deadlift 3x12
A2: Lat Pull Down with Fitness Bands 3x10 45 sec
B1: Bulgarian Squat 3x10
B2: Dumbbell Press 3x12 45 sec
C1: Barbell Military Press 2x10
C2: Bench Dip 2x12 45 sec
D1: Double Crunch 2x20+
D2: Superman 2x15+ 45 sec
UKE 4
A1: Explosive Pushup 3x20+
A2: Alternating Split Squat Jump 3x15ea 45 sec
B1: Bench Press 3x8
B2: Jump Squat 3x20+ 45 sec
C1: Chin Up 2x15+
C2: Snatch-grip deadlift (Wide Grip) 2x10 45 sec
D1: Barbell Bent Over Row 2x10
D2: One Leg Calf Raise 2x10 45 sec
UKE 5
A1: Incline Bench Press 3x8
A2: Ball Squat with dumbbell 3x8 40 sec
B1: 45 degree Lat pull down with bands 3 8
B2: DB Squat And Press 3x10 40 sec
C1: Elevated Pushups 2x8
C2: Dumbbell Swing 2x15+ 40 sec
D1: Band Row 2x10
D2: Regular Plank 2x8 40 sec
UKE 6
A1: Dumbbell Press 3x6
A2: Front Barbell Squat 3x8 40 sec
B1: Elevated Ball Pushups 3x8
B2: Reverse lunges with dumbbell 3x6 40 sec
C1: Barbell Row 2x8
C2: Hip Bridge (One Leg) 2x8 40 sec
D1: Close Grip Pull ups (with weights) 2x6
D2: Side Plank 2x8 40 sec
UKE 7
A1: Bench Press 3x6
A2 Barbell Reverse Lunges 3x6
A3: Pull ups (weighted) 3x8 35 sec
B1: Dumbbell Press 3x6
B2: One Arm DB Snatch 3x10ea
B3: Dumbbell Bent Over Row 3x8 35 sec
C1: Military Shoulder Press 2x8
C2: Stability Ball Crunch with Bands 2x6 35 sec
UKE 8
A1: Incline Dumbbell Press 3x6
A2 Barbell Squat 3x6
A4: Barbell Deadlift 3x6 60 sec
B1: Bench Press 3x6
B2: One Arm DB Snatch 3x8
B3: Barbell Bent over row 3x6
B4: Stationary Barbell Lunges 3x8 each 60 sec
C1: Ball Crunch with bands 2x60 sec 40 sec
Endret av Doofenschmitz
Dagens trening (som gikk i dass :realmad: )
Knebøy
8x20kg, 30kg, 40kg, 50kg, 60kg, 70kg
Her ble det så tungt at jeg holdt på å kollapse :wallbash: Tok en pause på 5 minutter og jobbet meg så nedover...
6x60kg, 50kg, 40kg, 30kg
Chinups
6xBW
6xBW
6xBW
Dips
6xBW +3 +3 +3 +3 +3
Økta gikk til fans siden jeg hadde dårlig tid og knebøyen straffa meg så JÆVLIG :ermm:
På an igjen på mandag, da skal kroppen STRAFFES for dårlig oppførsel i dag :ph34r:
Uke 1 påbegynt...
Supersett 1, 3 sett, 50 sekunder pause mellom settene
A1: 15x One Arm DB Squat 10kg
A2: 12x Dumbbell Press 17,5kg
Supersett 2, 3 sett, 50 sekunder pause mellom settene
B1: 12x Band Row grønne strikk
B2: 15x Hamstring Curl with Stability Ball
Supersett 3, 2 sett, 50 sekunder pause mellom settene
C1: 12x Shoulder Press with dumbbell 8kg
C2: 12x Bicep Curl with dumbbell 8kg
Supersett 4, 2 sett, 45 sekunder pause mellom settene
D1: Regular Plank 30sec
D2: 15x One Leg Calf Raise kroppsvekt
Avslutningssett
Pallofpress 10x11,5kg
Ok økt, kjørte så hardt jeg klarte å var søkksvett allerede midt i økta.
Justerer a1 til 15kg
Justerer a2 til 20kg
Justerer b1 til røde strikk
Justerer c1 til 10kg
Justerer c2 til 10kg
Justerer d2 til 5kg ekstra vekt
Skal være fotoklar etter uke 4 om jeg klarer å opprettholde den forbrenninga jeg har klart nå i det siste...
Justerer også b2 til enfots for mer trykk på hamstrings.
Svømming i dag, intervall. Må ha noe kondis til sommeren...
Justerer i tillegg opp proteininntaket siden vekta viste 65.8 kg i morges... Mister jeg muskelmasse? :ohmy:
Klypa viser UNDER 7 millimeter nå... :new_woot:
Kardiodag, svømming...
200 meter rolig/oppvarming
5 drag bestående av 25 meter rolig, 25 meter flatt ut og så 45 sekunder pause.
50 meter rolig, kjapp pause (25-30 sek.) og så 100 meter rolig til.
Ok økt, merket at jeg har bedre lungekapasitet enn i fjor. Mulig all rasinga på fjellet i vinter har gjort noe vettig med kroppen... :hmm:
Såååå, dag to av tre i uke en av programmet...
Blir spennende å se hvordan treningen blir etter justeringene.
Det var det programmet jeg brukte i fjor så har tro på at dette skal funke :roll:
edit: kom frem til at å begynne på uke 1 ikke var så dumt allikevel, dette burde bygge en hvis kondisjon som trengs videre utover...
Dagens supermannproduksjon...
A1: 15x One Arm DB Squat 15kg
A2: 12x Dumbbell Press 20kg
B1: 12x Band Row røde strikk
C1: 12x Shoulder Press with dumbbell 10kg
D1: Regular Plank 45sec
Idag økte jeg vektene på det første settet og var VÅT etter 2 supersett... :ph34r:
Jeg var anpusten i sikkert 10 minutter etter økta og satt å pusta som en hval i badstua etterpå, det var hææærlig... :!:
B2skal få foregå med to føtter istedenfor planlagt enfots og A1 skal økes til 20kg mens A2 tas ned til 17,5kg med mere intensitet.
Hele økta var gjennomført på ca 35 minutter, justerer pausene kortere på fredag og satser på å ha gjennomført på under 30 minutter.
M1:3 scoops Prozyme
M2:2 scoops Prozyme og en liten banan
M3:1 kyllingfilet, 1 porsjon ris, kyllingsaus og et lass brokkoli
M4:2 skiver speltbrød med meierismør, et økologisk egg på hver skive og 5,5 dl økologisk melk
Dagens økt...
A1: 15x One Arm DB Squat 20kg
Egentlig ganske ok økt til tross for at jeg måtte drite etter andre settet i supersett 2 :p
Protip: gå på do FØR en treningsøkt...
Nå inntas det en pakke riskaker (100gram) med diverse sukkerartikler på... Sjokoladesaus, jordbærsyltetøy og lønnesirup funker bra :new_woot:
UKE 2
Supersett 1, 3 sett, 45 sekunder pause mellom settene
A1: 12 x Split Bulgarian Squat with dumbbell 10 each 20kg
A2: 6 x Pull ups kroppsvekt
Supersett 2, 3 sett, 45 sekunder pause mellom settene
B1: 12 x Hip Bridge with Stability Ball 12
B2: 10 x Bench Press 40kg
Supersett 3, 2 sett, 45 sekunder pause mellom settene
C1: 12 x Shoulder DB Press on the ball 2x10kg
C2: 12 x Calf Raise kroppsvekt
D1: 30 x Bicycle Kick
D2: 12 x Superman
Skulle aldri spist riskaker før treninga, tror rett og slett jeg ikke responderer på karbo på positivt vis...
edit: bytter A1 med A2 og øker reps på nye A1 til 8, samt at B2 tas opp til 45kg, C1 til 12,5kg og C2 tas med en 20kg vektskive i hendene
Trener i tillegg høyrep for tiden (for glykogentømming/fettforbrenning) og da skal det være gunstig å supersette øvelser som ligger langt fra hverandre for blodstrømmer og sånn derre...
Har ikke lest meg opp på det enda, men det skal være gunstig å trene knebøy for så å trene roing i et og samme supersett. Det skal ha noe med at blodet må vandre andre veier plutselig og det vil føre til anaerob trening som igjen fremmer fettforbrenning... elns...
edit: rettskriving...
Puls ja... Det er sånn at jeg hiver etter pusten midt ut i økta og det er sånn helt til slutten :p
Jeg kjører en del indirekte kardio på "hviledagene", blir en del innebandy og rugby med "aussie rules" fremover... Sistnevnte er dritgøy og mandig som f**n :ph34r:
Gjest
