Malwarebytes' Anti-Malware 1.46
www.malwarebytes.org
Databaseversjon: 4309
Windows 6.0.6001 Service Pack 3
Internet Explorer 8.0.6001.18928
13.07.2010 19:19:16
mbam-log-2010-07-13 (19-19-16).txt
Skanntype: Hurtigsøk
Objekter skannet: 131779
Tid tilbakelagt: 8 minutt(er), 44 sekund(er)
Minneprosesser infisert: 3
Minnemoduler infisert: 3
Registernøkler infisert: 5
Registerverdier infisert: 5
Registerfiler infisert: 4
Mapper infisert: 1
Filer infisert 25
C:\Users\Kenneth\AppData\Local\Temp\AUTMGR32.EXE (Trojan.Dropper) -> Unloaded process successfully.
C:\Users\Kenneth\AppData\Local\Temp\wscsvc32.exe (Trojan.FakeAlert) -> Unloaded process successfully.
C:\Users\Kenneth\AppData\Roaming\Defense Center\defcnt.exe (Trojan.FakeAlert) -> Unloaded process successfully.
C:\Users\Kenneth\AppData\Local\Temp\mschrt20ex.dll (Rogue.DefenseCenter) -> Delete on reboot.
C:\Users\Kenneth\AppData\Roaming\Defense Center\defhook.dll (Trojan.FakeAlert) -> Delete on reboot.
C:\Users\Kenneth\AppData\Local\ASAupn.dll (Trojan.Hiloti) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\pragmawifexrpqtc (Trojan.DNSChanger) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Malware Defense (Rogue.MalwareDefense) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Paladin Antivirus (Rogue.PaladinAntivirus) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\pragma (Rootkit.TDSS) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\PRAGMA (Rootkit.TDSS) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ djivonibumerujo (Trojan.Hiloti) -> Delete on reboot.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ defense center (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\secfile\shell\open\command\(default) (Rogue.MultipleAV) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\24d1ca9a-a864-4f7b-86fe-495eb56529d8 (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\7bde84a2-f58f-46ec-9eac-f1f90fead080 (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\regfile\shell\open\command\(default) (Broken.OpenCommand) -> Bad: ("regedit.exe" "%1") Good: (regedit.exe "%1") -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\ System\DisableTaskMgr (Hijack.TaskManager) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\ System\DisableTaskMgr (Hijack.TaskManager) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\.exe\(default) (Hijacked.exeFile) -> Bad: (secfile) Good: (exefile) -> Quarantined and deleted successfully.
Mapper infisert:
C:\Windows\PRAGMAwifexrpqtc (Trojan.DNSChanger) -> Quarantined and deleted successfully.
Filer infisert
C:\Users\Kenneth\AppData\Local\Temp\AUTMGR32.EXE (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\wscsvc32.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Roaming\Defense Center\defcnt.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\tmpD624.tmp (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\dhdhtrdhdrtr5y (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\Low\RBZpIFOdAa.exe (Trojan.Hiloti) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\Low\TMP22416.tmp (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\Low\topwesitjh (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\Low\uxptar-update.exe (Trojan.Hiloti) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\Low\emBKjPAnBZ.exe (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\Low\WHSIXoYuhZ.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Windows\PRAGMAwifexrpqtc\pragmabbr.dll (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\Windows\PRAGMAwifexrpqtc\PRAGMAc.dll (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\Windows\PRAGMAwifexrpqtc\PRAGMAcfg.ini (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\Windows\PRAGMAwifexrpqtc\PRAGMAd.sys (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\Windows\PRAGMAwifexrpqtc\pragmaserf.dll (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\Windows\PRAGMAwifexrpqtc\PRAGMAsrcr.dat (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\ProgramData\pragmamfeklnmal.dll (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Users\Kenneth\Favorites\_favdata.dat (Malware.Trace) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Defense Center.LNK (Rogue.DefenseCenter) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\PRAGMA6308.tmp (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\Users\Kenneth\AppData\Local\Temp\pragmamainqt.dll (Rootkit.TDSS) -> Quarantined and deleted successfully.
Gjest
