Hvorfor får jeg opp følgene når jeg starter css?
Og hvordan får jeg det vekk?
Can't use cheat cvar cam_snapto in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_ideallag in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealdelta in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealyaw in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealpitch in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealdist in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealdistright in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealdistup in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_collision in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_maxpitch in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_minpitch in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_maxyaw in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_minyaw in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_maxdistance in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_mindistance in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_orthowidth in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_orthoheight in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cl_upspeed in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cl_forwardspeed in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cl_backspeed in multiplayer, unless the server has sv_cheats set to 1.
Network: IP 192.168.1.200, mode MP, dedicated No, ports 27015 SV / 27005 CL
Can't use cheat cvar fog_start in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_end in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_color in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_colorskybox in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_startskybox in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_endskybox in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar r_farz in multiplayer, unless the server has sv_cheats set to 1.
