ThaBear Skrevet 14. juli 2010 Forfatter Del Skrevet 14. juli 2010 (endret) Kanskje dette er vesentlig? [2010/07/14 15:59:02, 0] nmbd/nmbd.c:(723) Netbios nameserver version 3.0.35 started. Copyright Andrew Tridgell and the Samba Team 1992-2009 [2010/07/14 15:59:02, 0] param/params.c:(536) params.c:OpenConfFile() - Unable to open configuration file "/etc/sfw/smb.conf": No such file or directory [2010/07/14 15:59:02, 0] nmbd/nmbd.c:(723) Netbios nameserver version 3.0.35 started. Copyright Andrew Tridgell and the Samba Team 1992-2009 [2010/07/14 15:59:02, 0] param/params.c:(536) params.c:OpenConfFile() - Unable to open configuration file "/etc/sfw/smb.conf": No such file or directory [2010/07/14 15:59:02, 0] nmbd/nmbd.c:(723) Netbios nameserver version 3.0.35 started. Copyright Andrew Tridgell and the Samba Team 1992-2009 [2010/07/14 15:59:02, 0] param/params.c:(536) params.c:OpenConfFile() - Unable to open configuration file "/etc/sfw/smb.conf": No such file or directory [2010/07/14 16:20:36, 0] nmbd/nmbd.c:(723) Netbios nameserver version 3.0.35 started. Copyright Andrew Tridgell and the Samba Team 1992-2009 [2010/07/14 16:20:36, 0] param/params.c:(536) params.c:OpenConfFile() - Unable to open configuration file "/etc/sfw/smb.conf": No such file or directory [2010/07/14 16:20:37, 0] nmbd/nmbd.c:(723) Netbios nameserver version 3.0.35 started. Copyright Andrew Tridgell and the Samba Team 1992-2009 [2010/07/14 16:20:37, 0] param/params.c:(536) params.c:OpenConfFile() - Unable to open configuration file "/etc/sfw/smb.conf": No such file or directory [2010/07/14 16:20:37, 0] nmbd/nmbd.c:(723) Netbios nameserver version 3.0.35 started. Copyright Andrew Tridgell and the Samba Team 1992-2009 [2010/07/14 16:20:37, 0] param/params.c:(536) params.c:OpenConfFile() - Unable to open configuration file "/etc/sfw/smb.conf": No such file or directory Men hadde en smb.conf fil der... men kvifor "eksisterer" den ikkje? feil fil format? brukte bare star office writer til å lage den, og lagret den under /etc/sfw/smb.conf Edit: ordnet opp med å opne smb.conf-example og fjernet alt og la inn det eg skal ha som samba conf fil. og lagret dette som smb.conf ... tenkte aldri på fil type Da er det kun dette maintenance 16:20:37 svc:/network/wins:default Endret 14. juli 2010 av ThaBear Lenke til kommentar
Sokkalf™ Skrevet 14. juli 2010 Del Skrevet 14. juli 2010 Fungerer det å nå serveren "utenfra" nå da? Tviler på at du trenger WINS til noe. Lenke til kommentar
ThaBear Skrevet 14. juli 2010 Forfatter Del Skrevet 14. juli 2010 Eg finner ikkje serveren på /netowrk på win 7 maskinen... mulig dette har noke med workgrp å gjere, eller fordi eg faktisk ikkje klarte å ordne på server name, ja eg prøvde ut å google det du sa, men finner fan ikkje de filene som skulle endrest, og den ene eg fant var tom Lenke til kommentar
Sokkalf™ Skrevet 14. juli 2010 Del Skrevet 14. juli 2010 Prøv med IP-adressen da, \\ip-adresse\sharenavn i Windows explorer. 1 Lenke til kommentar
ThaBear Skrevet 14. juli 2010 Forfatter Del Skrevet 14. juli 2010 Kommer fram til noke.. kommer opp enter pw etc. Mulig eg har glemt noke? har kun addet users til solaris, har ikkje gjort noke med samba.. eller trenger en ikkje det? Lenke til kommentar
Sokkalf™ Skrevet 14. juli 2010 Del Skrevet 14. juli 2010 Er det ikke du som hadde en sånn diger Samba-bibel, da? Lenke til kommentar
ThaBear Skrevet 14. juli 2010 Forfatter Del Skrevet 14. juli 2010 (endret) jau, 600 uoversiktlige sider xD skal prøve å finne ut noke kanskje eg vart litt lat da du omtrent viste alt finner det nok ut Endret 14. juli 2010 av ThaBear Lenke til kommentar
ThaBear Skrevet 14. juli 2010 Forfatter Del Skrevet 14. juli 2010 (endret) Vel, har ikkje smbpasswd filen... tror den er veldig vesentlig.. /usr/local/samba/bin/smbpasswd: not found Edit: Google ga meg noke som tilsvaret solaris 10, men kommandoen var feil, fikk tak i den rette og nå fungerer NESTEN alt Bare att eg faktisk ikkje har lov til å skrive til disk... =/ Har prøvd å sette security = user Men dette fungerer ikkje, hugser att det var eit ord på 4 bokstaver og eit par tall som skulle en eller anna plass, men finner ikkje dette :S Ivertfall ikkje noke som hjelper Endret 14. juli 2010 av ThaBear Lenke til kommentar
siDDis Skrevet 14. juli 2010 Del Skrevet 14. juli 2010 Har du prøvd ein av desse på din share write list = olav <-- samba bruker read only = No writable = yes create mask = 0765 Lenke til kommentar
ThaBear Skrevet 14. juli 2010 Forfatter Del Skrevet 14. juli 2010 (endret) Har du prøvd ein av desse på din share write list = olav <-- samba bruker read only = No writable = yes create mask = 0765 Vel, har write list, som er samba bruker. create mask = 0775 fungerer ivertfall ikkje =( [Musikk] path = /media/Musikk browseable = yes write list = Luckys create mask = 0775 Edit, korleis reboot samba server enkelt aa greit etter aa edita smb.conf? Endret 14. juli 2010 av ThaBear Lenke til kommentar
ThaBear Skrevet 14. juli 2010 Forfatter Del Skrevet 14. juli 2010 (endret) ah, eg køyrde svadm restart samba, dette var jo listet under svadm men nå er IKKJE samba oppe å køyer en anna ting, som dere sikkert ser får eg ikkje brukt æøå og div andre tegn ? er egentlig _ i solaris nå.. loger ut, velger norsk bokmål, og logger inn, dette fungerte fint sist eg gjorde det.. men nå er ting og tang annerledes Vel, samba er oppe å køyrer igjen. Har endret til create mask = 0765 Men forsatt samme prob... rart! Endret 14. juli 2010 av ThaBear Lenke til kommentar
ThaBear Skrevet 14. juli 2010 Forfatter Del Skrevet 14. juli 2010 Finner ikkje ut av dette, virker som det ikkje finnest en fasit på akuratt dette... ingen som veit noke ang problem til å skrive til samba share? Lenke til kommentar
Sokkalf™ Skrevet 14. juli 2010 Del Skrevet 14. juli 2010 Hva er rettighetene i selve filsystemet da? Stemmer eieren overens med unixbruker/sambabruker? Lenke til kommentar
ThaBear Skrevet 14. juli 2010 Forfatter Del Skrevet 14. juli 2010 Er det også noke? trudde dette gikk fint siden det var samba som tok seg av slikt og siden samba blir satt opp av root.. Skal prøve dette Lenke til kommentar
kpolberg Skrevet 14. juli 2010 Del Skrevet 14. juli 2010 Tror det er på tide du blar opp i bibelen. Samba mapper opp mot unixbrukere. Altså må du legge til brukeren med smbpasswd -a user Lenke til kommentar
ThaBear Skrevet 15. juli 2010 Forfatter Del Skrevet 15. juli 2010 (endret) Off, var det eg fryktet Men skal først sjekke om eg finner eit eller anna ang samba på rettigheter på mappene Fikk det til! Endret 15. juli 2010 av ThaBear Lenke til kommentar
Sokkalf™ Skrevet 15. juli 2010 Del Skrevet 15. juli 2010 (endret) Det hele er ganske enkelt. Du trenger en unixbruker, som er mappet mot en sambabruker (med smbpasswd). Deretter må mappen være eid av samme (unix)bruker på filsystemet, eller ha rettigheter så denne brukeren kan skrive til den. Hvilken bruker Samba "er" mot filsystemet, avhenger av hvilken unixbruker sambabrukeren blir mappet mot. Endret 15. juli 2010 av Sokkalf™ Lenke til kommentar
Lufen Skrevet 15. juli 2010 Del Skrevet 15. juli 2010 Jeg vil egentlig anbefale deg å bruke opensolaris istedet for vanlig solaris, da det har blitt gjort en del endringer på samba i opensolaris og det har blitt mye enklere Da vil du kunne dele ut områder bare ved å bruke zfs kommando: zfs set sharesmb=on filesystem/zpool Se linkene under: http://developers.sun.com/openstorage/articles/opensolaris_nas.html http://blogs.sun.com/timthomas/entry/solaris_cifs_in_workgroup_mode http://www.cyberciti.biz/tips/opensolaris-unix-nas-storage-server.html PS. for å se om samba kjører, så kjør kommandoen: svcs -xv Hvis samba blir listet opp der så kjører den ikke. For å bytte hostname på en solaris maskin: endre i filen /etc/nodename (navnet du ser i shell) Lenke til kommentar
ThaBear Skrevet 15. juli 2010 Forfatter Del Skrevet 15. juli 2010 Det hele er ganske enkelt. Du trenger en unixbruker, som er mappet mot en sambabruker (med smbpasswd). Deretter må mappen være eid av samme (unix)bruker på filsystemet, eller ha rettigheter så denne brukeren kan skrive til den. Hvilken bruker Samba "er" mot filsystemet, avhenger av hvilken unixbruker sambabrukeren blir mappet mot. Det eg gjorde får å få dette til var egentlig å først lage en bruker på Solaris som eg kalla Luckys, deretter adda eg en samba bruker som eg også kalla Luckys, og endra eier til Luckys på folderen... da gikk alt så mykje betre... Men kva vist eg vil att mer enn 2 samba brukere skal kunne skrive da? har også testet med rettigheter som deamon skal kunne skrive, men ingen hjelp.. Eier hjelper meg ivertfall fint lite vist mer enn en konto skal kunne skrive.. Lenke til kommentar
