tho_kva2 Skrevet 21. juni 2010 Del Skrevet 21. juni 2010 Er vel en smule dårlig tittel Jeg skal installere wow på min skole bærbare.. Har fått installert og patcha opp til "3.1.3.9947". Må patche manuelt siden det funker ikke gjennom wow.. Når jeg skal installere neste patch så får jeg feilmelind: før: There may be problems applying this update. Do you want to continue anyway? The folder "C:\Documents and Settings\All Users\Programdata\Blizzard Entertainment.23720950.temp\Logs.temp\World of Warcraft Update.temp" could not be created. (ConflictManager::CreateObjects) The folder "C:\Documents and Settings\All Users\Programdata\Blizzard Entertainment.23720950.temp\Logs.temp\World of Warcraft Update.temp\Logs.temp" could not be created. (ConflictManager::CreateObjects) The file "C:\Documents and Settings\All Users\Programdata\Blizzard Entertainment.23720950.temp\Logs.temp\World of Warcraft Update.temp\Logs.temp\Blizzard Updater Log.html.temp" could not be created. If this problem persists, you may be able to solve it by uninstalling and then reinstalling the game. If you are unable to correct this problem, please contact Blizzard Technical Support. (InstallerFile::Create) Etter: The update could not be applied. The file "C:\Documents and Settings\All Users\Programdata\Blizzard Entertainment.23720950.temp\Logs.temp" could not be renamed to "C:\Documents and Settings\All Users\Programdata\Blizzard Entertainment.23720950.temp\Logs". If this problem persists, you may be able to solve it by uninstalling and then reinstalling the game. If you are unable to correct this problem, please contact Blizzard Technical Support. (ConflictManager::ResolveConflicts/1) The folder "C:\Documents and Settings\All Users\Programdata\Blizzard Entertainment.23720950.temp\Logs.temp" could not be deleted. (ConflictManager::UncreateObjects) The folder "C:\Documents and Settings\All Users\Programdata\Blizzard Entertainment.23720950.temp" could not be deleted. (ConflictManager::UncreateObjects) To check this installation for problems, click the "Repair" button. The Repair tool can automatically fix many update errors. Så problemet ligger vel i at jeg ikke har tilgang til mappen "C:\Documents and Settings\All Users\Programdata\" ? Denne mappen vises egentlig ikke for meg men får den opp ved å skrive addresen manuelt.. Har prøvd på å endre tilgangsnivået på mappen gjennom "egenskaper - sikkerhet - avansert - eier, krysser av for "erstatt eier av underbeholder av underbeholder og -objekter" - bruk. Dette pleier å funke for andre mapper i en et hvist tidsrom i hvert fall.. men får "feilmelding" når jeg kommer til en av mappene patchen snakker om. "du har ikke tillatelse til å lese innholdet i mappen \device\harddiskvolume1\documents and settings\all users\programdata\blizzard entertainment.411f61b.temp. vil du erstatte mappetillatelsene med tillatelser som gir deg full kontroll?" Jeg tar da ja, men får da kun midlertidig kontroll akkuratt som om vanlig.. Noen som har noen tips? - tho_kva2 Lenke til kommentar
tho_kva2 Skrevet 21. juni 2010 Forfatter Del Skrevet 21. juni 2010 haha klarte det.. var bare å tenke enkelt egenlig.. bare lage mappen manuelt Lenke til kommentar
