Mulighet for equalizer til Spotify?
Fant dette når jeg søkte på nettet:
If you need an equalizer: use DSbridge to stream Spotify music to Foobar. It sounds SO much better! I use it to get the best surround sound (using the Foobar Channel Mixer) + to adjust music to my taste using the equalizer.
Instruction:
1. Download dsbridge (http://code.google.com/p/dsbridge/dow...)
2. Extract the dsound.dll + dsbridge.ini file into your Spotify folder (c:\program files\spotify)
3. Get lame_enc.dll (google "lame_enc.dll") and also put it in your Spotify folder. (so now you have three files)
4. Open Foobar-->File-->add location--> http://localhost:8124/ --> press the play button
5. Restart spotify (sound will automatically be streamed to Foobar, you don't have to put the volume down or anything. If you quit Foobar, Spotify will automatically take over)
