Radeon 8500LE kontra OEM, to av samme alen ? Hva tilbyr Topl
Desdichado
Heisann...
Ser at mange lurer på forksjeller mellom ATI LE og OEM, kontra Retail.
Sitat tatt fra http://www.rage3d.com
"R200, is the latest graphic chip of ATI that gives full hardware support to DirectX v8.x and ATI8500LE uses this chip as GPU. In fact there is no such a model on the market called 8500LE, it is only produced and sold to OEM companies. The only difference between ATI8500 is that the core and RAM frequencies are 250/250 MHz. instead of 275/275 MHz. R200, with its T&L (Transform, Clipping and Lighting) unit, called Charisma Engine II, has the ability to draw 69M polygons per second. Can reach up to a 8.8 GB/s bandwidth using 275 MHz. DDR Rams and its HyperZ-II technology. Its 3D rendering engine is called Pixel Tapestry-II and can process 6 textures at a time using 4 parallel rendering pipelines. This gives a fill-rate of 2.2 GigaTexel/s. Besides there is an FSAA engine called Smoothvision. Moreover, unlike NV20, it has dual-display support and gives a better 2D image quality with its 400MHz. RAMDAC. And finally ATI will announce R300 in the near future to compete with NVIDIA’s GeForce4."
Med andre ord, hvilke kort er det Topline tilbyr sine kunder nå ? Er det LE/OEM kort som de/leverandøren har klokket opp til Retail ? Uansett, stemmer dette så er det jo bare å bestille med en gang...
All tvil borte nå ?
Mvh
Jan Fredrik Lund
[email protected]
Vi har hatt en lang prat med Topline etter at en leser klaget på annonseringen deres om 275/550 kort.
Det ivser seg at produsenten og ATi bekrefter at det er 275/550 kort de får. Muligens er det en modell som ATi ikke har lansert ennå (?). Det er tross alt ingen grunn til at de skal selge 250 og 275 kort... Alle Chipene klarer fint 275 uansett...
