[Løst]Kinsesere og fargen sort
jeg fant ikke noe bedre sted å poste denne. hvis noen har bedre forslag om kategorivalg tas dette imot med takk.
senere idag får vi besøk på jobben av noen kinesere. Planen er at de skal få noen svarte slips men noen hpå jobben ar hørt at kinesere blir fornærmet av dette da det er noe ved denne fargen iht kinesisk kultur (uten at jeg kan definere hva dette "noe" er for noe) som gjør at de reagerer på dette. noen som kan avkrefte/bekrefte dette?
ser ikke ut som om det er noe galt med sort i kina...
http://en.wikipedia.org/wiki/Color_in_Chinese_culture#Black
Black, corresponding to water, is a neutral color. The I Ching, or Book of Changes, regards black as Heaven’s color. The saying “heaven and earth of mysterious black” was rooted in the observation that the northern sky was black for a long time. They believed Tian Di, or Heavenly Emperor, resided in the North Star.
The Taiji symbol uses black and white to represent the unity of Yin and Yang. Ancient Chinese regarded black as the king of colors and honored black longer than any other color. Lao Zi said that five colors make people blind, so the Dao School chose black as the color of the Dao.
In modern China, black is used in daily clothing. Possibly adopted from Western practices, black may also be used during a funeral to symbolize mourning. A black ribbon is usually hung over the deceased's picture.[1]
http://www.chinatownconnection.com/colors-chinese-culture.htm
The I-Ching, or Book of Changes, regards black as Heaven's color. The saying "heaven and earth of mysterious black" was rooted in the observation that the northern sky was black for a long time. White represented gold and symbolized brightness, purity, and fulfillment. White also is the color of mourning.
Endret av aklla
Hvit er også sorgens farge, dermed det de tradisjonelt går med i begravelser.
Sort er derimot egentlig symbolet på starten.
Skulle vel stått noe her hvis det var noe så alvorlig.
Var ingenting konkret jeg fant i de kildene jeg så om fargesymbolisme.
"Black
In modern China, black is used in daily clothing. Possibly adopted from Western practices, black may also be used during a funeral to symbolize mourning. A black ribbon is usually hung over the deceased's picture."
Endret av multisync
Du skal unngå fargen raud og kombinasjonen svart og kvitt
http://www.ehow.com/facts_5561459_chinese-gift-traditions.html
Men etter å ha googla litt så ser det ikkje ut som at ei svart gave er så gale, hadde slipset vært kvitt så hadde det vært ei anna sak.
Her er forøvrig nokre andre tips:
Min lenkehttp://www.bellaonline.com/articles/art48137.asp
Ser her at søtsaker kan være ein god ide å legge til om det her er snakk om kinesiske samarbeidspartnere.
