Wolf ET - True Combat Elite vil ikke starte
Fra terminal:
map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_3DFX_texture_compression_FXT1 GL_APPLE_client_storage GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ATI_blend_equation_separate GL_ATI_envmap_bumpmap GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_MESA_pack_invert GL_MESA_texture_signed_rgba GL_MESA_ycbcr_texture GL_MESA_window_pos GL_NV_blend_square GL_NV_depth_clamp GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_texgen_reflection GL_NV_vertex_program GL_NV_vertex_program1_1 GL_OES_read_format GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
GLX_EXTENSIONS: GLX_ARB_get_proc_address GLX_ARB_multisample GLX_EXT_import_context GLX_EXT_visual_info GLX_EXT_visual_rating GLX_MESA_copy_sub_buffer GLX_MESA_swap_frame_usage GLX_OML_swap_method GLX_SGI_make_current_read GLX_SGI_video_sync GLX_SGIS_multisample GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGIX_visual_select_group GLX_EXT_texture_from_pixmap
GL_MAX_TEXTURE_SIZE: 4096
GL_MAX_ACTIVE_TEXTURES_ARB: 8
PIXELFORMAT: color(24-bits) Z(24-bit) stencil(0-bits)
MODE: 4, 800 x 600 fullscreen hz:N/A
GAMMA: hardware w/ 0 overbright bits
CPU:
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 1
texture bits: 32
multitexture: enabled
compiled vertex arrays: enabled
texenv add: disabled
compressed textures: disabled
anisotropy: 1.0
NV distance fog: disabled
Initializing Shaders
----- finished R_Init -----
Sys_LoadDll(/home/runesole/.etwolf/etmain/ui.mp.i386.so)...
Sys_LoadDll(/home/runesole/.etwolf/etmain/ui.mp.i386.so) failed:
"/home/runesole/.etwolf/etmain/ui.mp.i386.so: cannot open shared object file: No such file or directory"
Sys_LoadDll(/usr/local/games/enemy-territory/etmain/ui.mp.i386.so)... ok
Sys_LoadDll(ui) found **vmMain** at  0x9473f40
Sys_LoadDll(ui) succeeded!
^5PunkBuster Client: Not Connected to a Server
Resolving etmaster.idsoftware.com
etmaster.idsoftware.com resolved to 192.246.40.60:27951
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutdown tty console
runesole@rubuntu:~$
runesole@rubuntu:~$ gedit start-et
runesole@rubuntu:~$ /start-et
bash: /start-et: No such file or directory
runesole@rubuntu:~$ sudo ./start-et
[sudo] password for runesole:
esd: no process found
ET 2.60 linux-i386 Mar 10 2005
----- FS_Startup -----
Current search path:
/home/runesole/.etwolf/tcetest
/usr/local/games/enemy-territory/tcetest/pak4.pk3 (113 files)
/usr/local/games/enemy-territory/tcetest/pak3.pk3 (411 files)
/usr/local/games/enemy-territory/tcetest/pak2.pk3 (2066 files)
/usr/local/games/enemy-territory/tcetest/pak1.pk3 (1869 files)
/usr/local/games/enemy-territory/tcetest/pak0.pk3 (728 files)
/usr/local/games/enemy-territory/tcetest/mp_bin.pk3 (6 files)
/usr/local/games/enemy-territory/etmain/pak2.pk3 (22 files)
/usr/local/games/enemy-territory/etmain/pak1.pk3 (10 files)
/usr/local/games/enemy-territory/etmain/pak0.pk3 (3725 files)
/usr/local/games/enemy-territory/etmain/mp_bin.pk3 (6 files)
8956 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing profiles/runesole/etconfig.cfg
execing autoexec.cfg
com_zoneMegs will be changed upon restarting.
Hunk_Clear: reset the hunk ok
------- Input Initialization -------
Joystick is not active.
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
...loading libGL.so.1: Initializing OpenGL display
...setting mode 4: 800 600
Using XFree86-VidModeExtension Version 2.2
XF86DGA Mouse (Version 2.0) initialized
XFree86-VidModeExtension Activated at 800x600
Using 8/8/8 Color bits, 24 depth, 0 stencil display.
GL_RENDERER: Mesa DRI Mobile Intel® GM45 Express Chipset GEM 20091221 2009Q4 x86/MMX/SSE2
Initializing OpenGL extensions
...GL_S3_s3tc not found
...ignoring GL_EXT_texture_env_add
...using GL_ARB_multitexture
...using GL_EXT_compiled_vertex_array
...GL_NV_fog_distance not found
...ignoring GL_EXT_texture_filter_anisotropic
Initializing GLX extensions
... GLX_SGI_swap_control not found
...using GLX_SGI_video_sync
XF86 Gamma extension initialized
GL_VENDOR: Tungsten Graphics, Inc
GL_VERSION: 2.1 Mesa 7.7.1
GL_EXTENSIONS: GL_EXT_compiled_vertex_array GL_EXT_texture_env_add GL_ARB_copy_buffer GL_ARB_depth_texture GL_ARB_depth_clamp GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_half_float_pixel GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_120 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_cull_vertex GL_EXT_copy_texture GL_EXT_draw_range_elements GL_EXT_framebuffer_blit GL_EXT_framebuffer_object GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_3DFX_texture_compression_FXT1 GL_APPLE_client_storage GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ATI_blend_equation_separate GL_ATI_envmap_bumpmap GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_MESA_pack_invert GL_MESA_texture_signed_rgba GL_MESA_ycbcr_texture GL_MESA_window_pos GL_NV_blend_square GL_NV_depth_clamp GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_texgen_reflection GL_NV_vertex_program GL_NV_vertex_program1_1 GL_OES_read_format GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
CPU:
picmip: 1
texture bits: 32
anisotropy: 1.0
------- sound initialization -------
----- Sound Info -----
sound system is muted
   1 stereo
262144 samples
  16 samplebits
   1 submission_chunk
44100 speed
0x0xab726000 dma buffer
No background file.
Sound memory manager started
Sys_LoadDll(/home/runesole/.etwolf/tcetest/ui.mp.i386.so)...
Sys_LoadDll(/home/runesole/.etwolf/tcetest/ui.mp.i386.so) failed:
"/home/runesole/.etwolf/tcetest/ui.mp.i386.so: cannot open shared object file: No such file or directory"
Sys_LoadDll(/usr/local/games/enemy-territory/tcetest/ui.mp.i386.so)...
Sys_LoadDll(/usr/local/games/enemy-territory/tcetest/ui.mp.i386.so) failed:
"libstdc++.so.5: cannot open shared object file: No such file or directory"
Sys_LoadDll(ui) failed dlopen() completely!
RE_Shutdown( 1 )
Sys_Error: VM_Create on UI failed
^C
runesole@rubuntu:~$ ./start-et
./start-et: line 1: /proc/asound/card0/pcm0p/oss: Permission denied
./start-et: line 2: /proc/asound/card0/pcm0c/oss: Permission denied
3763 files in pk3 files
execing default.cfg
couldn't exec autoexec.cfg
Bypassing CD checks
----- R_Init -----
CPU:
picmip: 1
texture bits: 32
anisotropy: 1.0
   1 stereo
262144 samples
  16 samplebits
   1 submission_chunk
44100 speed
0x0xb77b1000 dma buffer
No background file.
Sys_LoadDll(ui) found **vmMain** at  0xb5c1ff40
--- Common Initialization Complete ---
Opening IP socket: localhost:27960
Hostname: rubuntu
IP: 127.0.1.1
Started tty console (use +set ttycon 0 to disable)
^5PunkBuster Client: PunkBuster Client (v1.152 | A0) Enabled
Couldn't write profiles/runesole/etconfig.cfg.
^5PunkBuster Client: Game Version [ET 2.60 linux-i386 Mar 10 2005]
RE_Shutdown( 1 )
^Crunesole@rubuntu:~$
runesole@rubuntu:~$ et +set fs_game tcetest
execing default.cfg
Bypassing CD checks
----- R_Init -----
CPU:
picmip: 1
texture bits: 32
anisotropy: 1.0
   1 stereo
262144 samples
  16 samplebits
   1 submission_chunk
44100 speed
0x0xab81f000 dma buffer
No background file.
RE_Shutdown( 1 )
runesole@rubuntu:~$
Edit: Lagt i spoiler.
Endret av Senyor de la guerra
RE_Shutdown( 1 )
Det virker som om du mangler noen libraries. Har du sjekket om "/home/runesole/.etwolf/tcetest/ui.mp.i386.so" er der de er? Kan være at konfigurasjonen av spillet er litt på avveie.
Hvilken distro bruker du? Bruker du x86_64?
Edit: Er alle dependencies til spillet møtt?
Endret av mikeys
Her er filene i mappa:
runesole@rubuntu:~/.etwolf/tcetest$ ls -la
totalt 465252
drwxr-xr-x 4 root     root          4096 2010-06-16 11:19 .
drwxr-xr-x 8 runesole runesole      4096 2010-06-15 18:56 ..
-rw-r--r-- 1 root     root           135 2006-09-27 16:33 autoexec.cfg
-rw-r--r-- 1 root     root        574276 2006-09-13 21:50 cgame_mac
-rw-r--r-- 1 root     root       1268446 2006-09-13 22:20 cgame.mp.i386.so
-rw-r--r-- 1 root     root       1003520 2006-09-13 21:03 cgame_mp_x86.dll
-rw-r--r-- 1 root     root         37344 2006-09-25 20:01 changelog.rtf
-rw-r--r-- 1 root     root         13776 2006-09-11 11:49 EULA_TrueCombat_Elite.txt
-rw-r--r-- 1 root     root       2009687 2006-09-13 21:55 mp_bin.pk3
-rw-r--r-- 1 root     root           544 2006-09-17 16:12 official.dat
-rw-r--r-- 1 root     root     111633426 2006-09-17 08:45 pak0.pk3
-rw-r--r-- 1 root     root     248251424 2006-09-17 08:47 pak1.pk3
-rw-r--r-- 1 root     root      59329282 2006-09-17 16:05 pak2.pk3
-rw-r--r-- 1 root     root      49407653 2006-09-17 15:58 pak3.pk3
drwxr-xr-x 3 root     root          4096 2010-06-15 15:10 profiles
drwx------ 3 root     root          4096 2010-06-16 11:06 qagame_mac.bundle
-rw-r--r-- 1 root     root       1367281 2006-09-13 22:26 qagame.mp.i386.so
-rw-r--r-- 1 root     root        995328 2006-09-14 07:52 qagame_mp_x86.dll
-rw-r--r-- 1 root     root          9990 2006-09-27 16:32 ReadMe.rtf
-rw-r--r-- 1 root     root         15086 2006-09-18 18:59 tce_icon_pc.ico
-rw-r--r-- 1 root     root        171334 2006-09-13 21:50 ui_mac
-rw-r--r-- 1 root     root        270336 2006-09-13 19:02 ui_mp_x86.dll
Nytt output fra kjøring av spill (noen endringer):
runesole@rubuntu:~$ sudo et +set fs_game tcetest
/home/runesole/.etwolf/tcetest/pak3.pk3 (411 files)
/home/runesole/.etwolf/tcetest/pak2.pk3 (2066 files)
/home/runesole/.etwolf/tcetest/pak1.pk3 (1869 files)
/home/runesole/.etwolf/tcetest/pak0.pk3 (728 files)
/home/runesole/.etwolf/tcetest/mp_bin.pk3 (6 files)
/home/runesole/.etwolf/etmain/z_hunkmeg_fix_etmain.pk3 (5 files)
/home/runesole/.etwolf/etmain/zb_hunkmeg_fix.pk3 (4 files)
/home/runesole/.etwolf/etmain/temple_final.pk3 (57 files)
/home/runesole/.etwolf/etmain/SuperGoldrush_Final.pk3 (170 files)
/home/runesole/.etwolf/etmain/sniperange_et.pk3 (29 files)
/home/runesole/.etwolf/etmain/nfl_b2.pk3 (201 files)
/home/runesole/.etwolf/etmain/mp_sub_rc1.pk3 (155 files)
/home/runesole/.etwolf/etmain/lighthouse.pk3 (110 files)
/home/runesole/.etwolf/etmain/ggmaps.pk3 (2 files)
/home/runesole/.etwolf/etmain/et_beach.pk3 (177 files)
/home/runesole/.etwolf/etmain/Desertfortress_beta.pk3 (80 files)
/home/runesole/.etwolf/etmain/daybreak.pk3 (98 files)
/home/runesole/.etwolf/etmain/citadel_obj.pk3 (74 files)
/home/runesole/.etwolf/etmain/cherbourg.pk3 (79 files)
/home/runesole/.etwolf/etmain/1944_beach.pk3 (60 files)
15337 files in pk3 files
execing default.cfg
Bypassing CD checks
----- R_Init -----
CPU:
picmip: 1
texture bits: 32
anisotropy: 1.0
   1 stereo
262144 samples
  16 samplebits
   1 submission_chunk
44100 speed
0x0xab7ff000 dma buffer
No background file.
RE_Shutdown( 1 )
runesole@rubuntu:~$
Edit: Glemte skjulte filer
Dette ser ut til å være kilden til problemet.
Nå vet jeg ikke hvilken distro du bruker, men tipper distroen din ikke har libstdc++.so.5, da dette er en gammel versjon (av standard C++-biblioteket).
Hos meg har jeg disse filene:
/usr/lib/libstdc++.so.6.0.13
Hvor sistnevnte er en symlink til førstnevnte.
Du kan jo krysse fingre og tær og håpe at versjon 6 er bakoverkompatibel med 5, og gjøre følgende :
sudo ln -s /usr/lib/libstdc++.so.6.0.13 /usr/lib/libstdc++.so.5
(Gitt at du har versjon 6.0.13, hvis du har en annen versjon sjekker du det enkelt med en "ls /usr/lib/libstdc++*")
Endret av Sokkalf™
