iPhone 4/4S Café  Prat i vei...
Hvordan lage egne alarmer, prøvde akkurat og funka!
Is it possible to make an app to allow you to play music from your playlist as an alarm. Playing 40 sec of music -once might not wake me up.
I would by it.
better yet Steve might say oops and make it an update
alarm continualy plays the set "song" whether it be buit in or custm made ringtones.
how do you import ringtones without paying for them or do you still have to pay $ 0.99 for ringtone conversion?
its really simple
1)you have to set known file extensions to be visible
http://img526.imageshack.us/img526/3439/itunesstep1iq3.jpg
2)Go into itunes Click "Edit" "Preferences" and click The "Ringtones" Box
http://img68.imageshack.us/img68/3724/itunesstep7nc8.jpg
3)songs have to be aquired some where other then itunes OR IT WONT WORK!!!
4)import desired song(s) into Itunes
http://img526.imageshack.us/img526/5992/itunesstep9nu9.jpg
5)right click song click "get info" click options tab and set the start and stop time to a 30 second frame EXAMPLE 2:32 - 3:02
MAKE SURE both boxes are clicked
http://img68.imageshack.us/img68/8272/itunesstep3sc9.jpg
6)once you have selected a 30 second segmant hit ok and right click the song again and click "Create to ACC Version"
http://img68.imageshack.us/img68/2084/itunesstep4zg7.jpg
7)once it is created copy it to the Desktop rename file from "Song Name.m4a" to "Song Name.m4r"
http://img211.imageshack.us/img211/2121/itunesstep5ma1.jpg
8) go back to itunes delete the ACC version of the song and click "Move To Recycle Bin"
http://img526.imageshack.us/img526/4958/itunesstep6mj1.jpg
9)import the "M4r" file back into iTunes it should show up in the ringtones part of itunes
http://img211.imageshack.us/img211/9474/itunesstep8dl6.jpg
10)sync or manualy drag the ringtone to your iphone and enjoy
***NOTE*** IF THERE IS ANY SONG INFORMATION IN THE SONG IFO DELETE IT OR MULTIPLE RINGTONES SHOW UP IN YOUR RINGTONES ON YOUR IPHONE WHICH GHAS TO BE DONE BEFORE RENAMING THE FILE FROM M4A TO M4R****
Hei.
Jeg har Personsvar Mini med MMS levering fra NetCom.
Hvordan spiller jeg av meldingen uten at den bruker høytaleren(alle hører det). Jeg vil bare bruke "øre-høytaleren".
Hva er forskjellen på Personsvar Mini SMS/MMS? Får man bare sms med at du må ringe opp når du har SMS?
Hei.
Tror nesten ikke det er mulig. "earpiece" høytaleren er kun for telefon samtaler, og denne tjenesten sender vel bare en lydfil til deg, som må spilles av på høytaleren. Alternativet er og koblet til headsettet.
Feil? Jeg vil tippe de fleste setter opp nummere xx xx xx xx framfor xxx xx xxx nå til dags. Langt mer ryddig.
Dette er vel en smakssak. Jeg skriver alltid mobilnummer som xxx xx xxx og for vanlige telefonnumre er det kun "Oslo-numre" jeg skriver på ny-måten. Alle andre som mobiltelefon. Synes det er lettere å si og oppfatte 3+2+3 enn 2+2+2+2....
Nei, man trenger ikke ha problemet selv om alle telefoner før u35/10 skulle ha denne designsvakheten (ikke feil). Det er også avhengig av hvor sterke signaler du her der du befinner deg. Min faller så og si aldri under 3 når jeg forsøker å fremprovosere problemet.
Stoler ikke helt på dine vurderinger når jeg leser hva du skriver.
Så du innrømmer at det er et problem, men du sier at du ikke opplever problemet SOM et problem?
Si meg, går ikke de få menneskene som må hanskes med deg til daglig lei av sirkelretorikken du omgir deg med?
Det kommer klart og tydelig frem hvilke mennesker i dette forumet som neppe hadde ført til noe konstruktivt i en bedrift ;)
Med slike logiske evner hadde ikke mye blitt gjort.
Kategorien "trolling" burde kanskje vurderes i forum som dette så dere får en arena å more dere på.
Endret av Theo343
En ting til som ruger på meg er at de fleste her skal være så satansk formell at poenget dems blir mistet i språkbruken...
