Invalid steam key length - hjelp
Hei hei
Jeg har akkuratt kjøpt Day of Defeat S, og skulle til å logge på første gangen,
men får opp feilmeldingen "Invalid steam key length" når jeg prøver å connecte
til en server. Noen som har erfaring med dette? Har lett litt på nettet, men
fant veldig lite om det. :hmm:
Fra Steam forum:
How come nobody understands that when a client and server don't match the same files, you won't be able to join it?
Yeah, Valve should give a simple error message like "Client and Server files don't match: Server out of date. This may result when servers have not received the latest update and restarted."
Gamespot forum:
Yea it's because you have updated and the server your trying to connect to hasn't updated yet. Wait a few minutes and try the server again.
