lucky666 Skrevet 28. mai 2010 Del Skrevet 28. mai 2010 Takker! Dette var jeg ikke klar over. Lenke til kommentar
TaZ Skrevet 28. mai 2010 Del Skrevet 28. mai 2010 (endret) Var vist ikke helt rett det der..står i en kommenter lenger nede på den sia.. It will support TRIM with SSDs in an AHCI configuration, or with the RAID controller enabled and the SSD is used as a pass through device. An example of this use case is for users that want to use the SSD as a boot drive but still be able to RAID multiple HDDs together to allow for large protect data storage – a great use for the home theater PC. TRIM support for SSDs in a RAID configuration is under investigation and is not included in Intel® RST 9.6. Endret 28. mai 2010 av taz Lenke til kommentar
