qmail problemer.
root@legolas:/# qmailctl stat
/service/qmail-send: up (pid 20556) 0 seconds
/service/qmail-send/log: up (pid 18739) 40356 seconds
/service/qmail-smtpd: up (pid 18745) 40356 seconds
/service/qmail-smtpd/log: up (pid 18747) 40356 seconds
messages in queue: 0
messages in queue but not yet preprocessed: 0
Jeg får ikke startet /service/qmail-send
root@legolas:/# ps -efl | grep "service errors" | grep -v grep
0 S root     31129 31126  0  69   0 -   333 pipe_w Jun08 ?        00:43:41 readproctitle service errors: ...r/qmail/rc: line 5: default: command not found?/var/qmail/rc: line 5: default: command not found?/var/qmail/rc: line 5: default: command not found?/var/qmail/rc: line 5: default: command not found?/var/qmail/rc: line 5: default: command not found?/var/qmail/rc: line 5: default: command not found?/var/qmail/rc: line 5: default: command not found?/var/qmail/rc: line 5: default: command not found?
Den feilen fikk jeg opp, gikk inn i filen og rettet opp det. Hva annet kan jeg gjøre for å finne feilen? Tips mottas med takk.
Det hadde gjort seg om du pastet run filen til qmail-send. Jeg hadde samme problemet med qmail-smtpd. Sjekket alt, men fant ut at det var en whitespace i run filen som gjorde det. Jeg brukte samme run filene som life with qmail.
Jeg har også fulgt Life wirh qmail..
#!/bin/sh
QMAILDUID=`id -u qmaild`
NOFILESGID=`id -g qmaild`
MAXSMTPD=`cat /var/qmail/control/concurrencyincoming`
LOCAL=`head -1 /var/qmail/control/me`
if [ -z "$QMAILDUID" -o -z "$NOFILESGID" -o -z "$MAXSMTPD" -o -z "$LOCAL" ]; then
   echo QMAILDUID, NOFILESGID, MAXSMTPD, or LOCAL is unset in
   echo /var/qmail/supervise/qmail-smtpd/run
   exit 1
fi
if [ ! -f /var/qmail/control/rcpthosts ]; then
   echo "No /var/qmail/control/rcpthosts!"
   echo "Refusing to start SMTP listener because it'll create an open relay"
   exit 1
fi
exec /usr/local/bin/softlimit -m 2000000
   /usr/local/bin/tcpserver -v -R -l "$LOCAL" -x /etc/tcp.smtp.cdb -c "$MAXSMTPD$
       -u "$QMAILDUID" -g "$NOFILESGID" 0 smtp /var/qmail/bin/qmail-smtpd 2>&1
Der er problemet. flere linjeskift i en kommando uten går ikke. lag alle de 5 linjene til en, så skal du se det funker. :)
jeg ga deg feil fil...
det er /var/qmail/supervise/qmail-send/run som trøbbler, ikke smtpd filen som jeg ga deg. Filen var ikke slik, den ble bare slik her i forumet.
Jeg lurer på om det er problemer med .mbox saken hos meg som kan gjøre noe med saken.
*klø klø* jeg sliter :grumpy:
root@legolas:/home/karlsen# qmailctl stat
/service/qmail-send: up (pid 581) 52 seconds
/service/qmail-send/log: up (pid 582) 52 seconds
/service/qmail-smtpd: up (pid 583) 52 seconds
/service/qmail-smtpd/log: up (pid 584) 52 seconds
:woot::woot::woot::woot::woot::woot::woot:
