Bråkete modem
Hadde samme problemet med mitt Conexant 56k Fax, Data, Voice modem. Fant dette:
To solve this problem do the following :-
1. Go into My Computer.
2. Go into Control Panel.
3. Go into System.
4. Go into Hardware.
5. Go into Device Manager.
6. Click on Modems.
7. Double click on the Installed Modem.
8. Click on Driver.
9. Click on Update Driver.
10. Click on Install From a Specific Location.
11. Click on Dont Search I Will Choose the Driver Myself.
12. Untick Show Compatible Hardware.
13. Select Generic in the manufacturer list.
14. Choose Fujitsu LB RWModem V.90 56K J.
15. Click finish.
Once installed reboot the PC (otherwise the modem will not
detect a dialling tone).
Dette gjelder i utgangs punktet for Conexant 56k Fax, Data, Voice modem, men hva har du å tape.
