Fosse Skrevet 19. mai 2010 Del Skrevet 19. mai 2010 Har skaffet meg min første berøringsskjerm-telefon, HTC Desire. Men det er en ting. I mange programmer, så er det ingen avsluttknapp. Som f.eks. Opera Mini. For å komme tilbake til hovedmenyen må jeg da trykke "Hjem"-tasten. Men da blir vel programmet fremdeles kjørende? Lenke til kommentar
Cruzative Skrevet 19. mai 2010 Del Skrevet 19. mai 2010 Lettaste måten er vel å laste ned f.eks. Taskiller frå Android Marked Ellers trur eg du kan leite deg fram gjennom instillinger .. Lenke til kommentar
Fosse Skrevet 19. mai 2010 Forfatter Del Skrevet 19. mai 2010 Noen nevnte taskkiller for meg. Men også at det brukte med ressurser og batteri enn det sparte. Lenke til kommentar
rulleguru Skrevet 19. mai 2010 Del Skrevet 19. mai 2010 Det er ikke meningen å avslutte programmer på Android, ikke bruk taskkillere. http://geekfor.me/faq/you-shouldnt-be-using-a-task-killer-with-android/ Sitat Android is hard coded to automatically kill a task when more memory is needed. Android is hard coded to automatically kill a task when it’s done doing what it needs to do. Android is hard coded to automatically kill a task when you haven’t returned to it in a long time. Most services (while possibly running in the background) use very little memory when not actively doing something. A content provider is only doing something when there is a notification for it to give. Otherwise it uses very little memory. Killing a process when it isn’t ready only causes it to have to reload itself and start from scratch when it’s needed again. Because a task is likely running in the background for a reason, killing it will only cause it to re-spawn as soon as the activity that was using it looks for it again. And it will just have to start over again. Killing certain processes can have undesirable side effects. Not receiving text messages, alarms not going off, and force closes just to name a few. The only true way to prevent something from running at all on your phone would be to uninstall the .apk. Most applications will exit themselves if you get out of it by hitting “back” until it closes rather than hitting the “home” button. But even with hitting home, Android will eventually kill it once it’s been in the background for a while. Lenke til kommentar
