[løst] Ubuntu 10.04 - conly blinker/hopper på x-aksen
Har nå trålet igjennom google etter en løsning på problemet, har prøvd å legge til double buffer og prøvd to forskjellige Nvidia drivere.
use_xft yes
xftfont verdana:size=8
alignment top_right
xftalpha 0.8
double_buffer yes
own_window yes
own_window_hints undecorate,sticky,skip_taskbar,skip_pager,below
own_window_transparent yes
own_window_type override
border_inner_margin 0
border_width 0
draw_borders no
draw_shades no
stippled_borders 0
border_width 1
default_shade_color grey
default_outline_color black
default_color BADCDD
use_spacer none
no_buffers yes
uppercase no
color1 F8DF58
TEXT
${font}${color orange}Temperaturer ${hr 2}$color
${font weather:size=20}y ${font} $color CPU ${acpitemp}°C ${font weather:size=20}y ${font} ${font}HDD ${execi 1 ~/scripts/hddmonit.sh}°C ${font weather:size=10}y ${font} ${font}GPU: ${execpi 5 nvidia-settings -q GPUCoreTemp -t}°C
${font}${color orange}Tid ${hr 2}$color
${font StyleBats:size=18}P${font} Oppetid: ${uptime_short}
${font StyleBats:size=16}8${font} Batteri: ${battery_percent}% ${battery_bar}
${color orange}Internet ${hr 2}$color
$color${font PizzaDude Bullets:size=16}v${font} Opp: ${upspeed wlan0} Kb/s
${font PizzaDude Bullets:size=16}r${font} Ned: ${downspeed wlan0} Kb/s
${font PizzaDude Bullets:size=16}M${font} Opplastet: ${totalup wlan0}
${font PizzaDude Bullets:size=16}S${font} Nedlastet: ${totaldown wlan0}
${color orange}Prosessor ${hr 2}$color
${font StyleBats:size=16}A${font} CPU0: ${cpu cpu0}% ${cpubar cpu0}
${font StyleBats:size=16}A${font} CPU1: ${cpu cpu1}% ${cpubar cpu1}
${color orange}Minne & disk ${hr 2}$color
${font StyleBats:size=16}J${font} Minne: ${mem} ${membar}
${font StyleBats:size=16}J${font} Swap: ${swap} ${swapbar}
Home: ${alignr}${fs_free /home} / ${fs_size /home}
${fs_bar 4 /home}
Usr: ${alignr}${fs_free /usr} / ${fs_size /usr}
${fs_bar 4 /usr}
${color orange}Nettverk ${hr 2}$color
Tilkoblet: ${wireless_essid wlan0} at ${wireless_bitrate wlan0}
${font PizzaDude Bullets:size=14}Z${font} Signal: ${wireless_link_qual wlan0}% ${wireless_link_bar wlan0}
Lokal IP: ${addr wlan0}
${color orange}Prosesser ${hr 2}$color
Processes: $processes ${alignr}Running: $running_processes
NAME ${alignr}CPU% MEM%
${top name 1} ${alignr}${top cpu 1} ${top mem 1}
${top name 2} ${alignr}${top cpu 2} ${top mem 2}
${top name 3} ${alignr}${top cpu 3} ${top mem 3}
${top name 4} ${alignr}${top cpu 4} ${top mem 4}
${color orange}Annen info ${hr 2}$color
$color${font FreeSans:size=16}@ ${font}Gmail - ${color 95956B}${execi 300 python ~/scripts/gmail.py [email protected] "passord"}
${color 6694B2}${font OpenLogos:size=70} t u $color
Endret av ole_marius
Har hatt noen problemer med conky selv etter jeg oppgraderte til 1.8.0, jeg antar at det er samme versjon som er i 10.04.
Hvis du bruker nvidia sine drivere kan du bruke "own_window_argb_visual 1" sammen med "own_window_argb_value 255" for å få skikkelig gjennomsiktighet (som i compositing). argb_visuals virker ikke sammen med "own_window_type override", du må da også bruke compiz eller en annen type compositing manager.
Jeg bruker "own_window_type panel" siden den fungerer greit sammen med Gnome.
Mikeys, det du anbefalte funket ikke, derimot når jeg studerte den rare oppførselen til conky hoppet den frem og tilbake på x-aksen.
Min løsning var derfor å redigere /etc/X11/xorg.conf
Jeg endret
Section "Module"
Load "gfx"
til Section "Module"
Load "dbe"
Men nå har jeg et nytt problem med noe helt annet, så skal muligens lage ny tråd om det snart...
