power Skrevet 14. juni 2003 Del Skrevet 14. juni 2003 Linux Osgiliath 2.4.21 #2 Sat Jun 14 20:31:12 CEST 2003 i686 AMD Athlon XP 2100+ AuthenticAMD GNU/Linux Hurray Lenke til kommentar
Yamato47 Skrevet 14. juni 2003 Del Skrevet 14. juni 2003 Hvordan er det med Alan Cox-patchene? Pleier de å virke bra? Her er changelogen til den siste: Linux 2.4.21-ac1 o Further ehci fixes and updates (David Brownell) o CPUfreq updates (Dominik Brodowski) o Updated DMI blacklists and facility to disable (Arjan van de Ven) APM idling o Allow an NFS to specify if d_revalidate is a (Trond Myklebust) stale handle event or not | Should fix CODA and VFAT problems o Ignore residue on autosense commands in (Tony Battersby) sym53c8xx_2 o SiS frame buffer updates (Tomas Winischhofer) o Add Xyratex to scsi list of large/sparse lun (David Lethe) o MPT fusion driver updates (Pam Delaney) o Hopefully fix the Promise SX6000 clash with (me) PDC202xxx IDE drivers when using 20277. o Add a framework for plug in ac97 drivers (me) o Fix IRQ handling in speedstep-ich (Samuel Thibault) o Redo the AC97 codec plugin interface (me) Lenke til kommentar
tivolieselet Skrevet 14. juni 2003 Del Skrevet 14. juni 2003 ifra mdk cooker listen: "> What I would really like to see is Mandrake update packages for 9.1 that > makes 9.1 compatible with the 2.5 kernel. The two biggies are the module > tools and screen-saver password problems. > > Ed-T. > IMHO it's not worth the truoble, and since MDK update policy is security and bugfix only they won't do it. And 2.5 kernel is "testing" only so ... As for MDK 9.2 Release things change... (Juan is already working on 2.5 kernels AFAIK...) According to current timeplans by Linus, the 2.5 will go 2.6 Release hopefully by the end of this summer... And Marcelo will push out 2.4.22 at the same time ... Ofcourse things still may change... Thomas" men det er mye knoting med 2.5 enda da.. jeg har testa den før, men i det siste så har det rotet seg mye til.. er det noen som vet om det er lang tid igjen?? til 2.6 Lenke til kommentar
Klette Skrevet 16. juni 2003 Del Skrevet 16. juni 2003 Kjører kernel 2.4.20 nå, er ny med linux. Så da lurer jeg på hvor stor nytte har man av å oppgradere? Har sett litt på change-log'en, og ser liksom ikke de helt store greiene der, iallefall ikke som jeg har noe speielt bruk for da. Kjører Gentoo 1.4.rc4 Takker for gode argumenter... Du kjører gentoo, vær en Gentooer! emerge sync ; emerge vanilla-sources asap Lenke til kommentar
Langtind Skrevet 16. juni 2003 Del Skrevet 16. juni 2003 Du kjører gentoo, vær en Gentooer! emerge sync ; emerge vanilla-sources asap Men hva mer kan jeg da si, 2.4.21 er på vei.... Lenke til kommentar
Cretinous Git Skrevet 17. juni 2003 Del Skrevet 17. juni 2003 Hei Egil.B, har du oversikt over hva som kreves av ting og tang fra Debian Sid for å lage fx. 2.4.21-kjerne under Sarge eller Woody? Jmf. http://www.debian.org/doc/manuals/referenc...-kernel.en.html Masse prat om bl.a. headers. Du trenger ikke noe mer for å kompilere 2.4.21 enn for 2.4.0. Bare last ned kildekoden fra http://linux-kernel.uio.no/pub/linux/kernel/v2.4/ og pakk den ut ; cd linux-2.4.21 ; make menuconfig ; fakeroot make-kpkg --revision 1 kernel_image ; osv. Forresten anbefales Con Kolivas sin patch med low latency, O(1), preemtible m.m. fra http://members.optusnet.com.au/ckolivas/kernel/ Den gir en litt mer snappy desktop. Lenke til kommentar
