Nikon D3000 eller Canon EOS 1000D
Tar bare å kopierer inn fra Cameralabs.com så får du bestemme selv. Skal ikke være noe fanboi men ser ut som Canon 1000D er et litt bedre kamera :p
Canon’s EOS 1000D / Rebel XS is over a year older than the D3000, but remains Canon’s current entry-level DSLR and hence the main rival for the new budget Nikon. Both the 1000D / XS and D3000 share the same 10 Megapixel resolution, 3fps continuous shooting and the same range from their 18-55mm stabilised kit lenses. In its favour, the Canon features Live View, a depth-of-field preview facility and comes with free software to remote-control the camera from a PC or Mac, along with a much more sophisticated RAW processing application. In its favour, the D3000 features a slightly more sophisticated 11-point AF system (versus 7-point), a larger 3in screen (versus 2.5in), viewfinder gridlines and a friendlier user interface for beginners. But for many beginners, the simple fact the Canon is one of the cheapest DSLRs with Live View will make it an easy choice, while a number of sophisticated features and operation will also see it appeal to enthusiasts on a budget. See our Canon EOS 1000D / Rebel XS review for more details.
