Live! Came Avatar v1.0 (hvordan kontrolere)
Hei.
Ei veninne av meg har installert "Live! Came Avatar v1.0" på sin laptop. Hun ønsker ikke å slette programmet siden hun har mistet installasjons CD'ene.
Hvordan slår hun av/på programmet uten å slette det? Er veldig irriterende å se på en kattepus når man ønsker å se veninna si..
Edit:
Fant et svar på en fremmed side som sa:
This problem is not fixed through the settings of your Creative device but by selecting the right webcamin your messaging software.
When you install your Creative Camera it installs the physical Camera as well as a virtual Camera. So there are actually 2 (or more Camera's installed). The Avatar plays through the virtual Camera.
Whatever programme you are using (MSN or SKYPE etc) you need to select the correct video Camera.
So, for example in MSN messenger, select Tools, Audio Video Setup and select your camera from the list (make sure the Virtual camera is not selected).
To be even clearer as an example: If you are using a LiveCam Notebook Ultra 3 camera, you will see the following listed as cameras when you go to select a webcam to use within your messaging software :
Live! Cam Ultra Notebook #3 -- this is your normal camera
Live! Cam Virtual -- this us the Avatar etc camera,
Live! Cam Ultra Notebook Ultra (VFW) -- this is your widescreen camera
Just select the right one!
Men problemet er at veninna mi ikke finner det riktige webcamera. Her er screenshot av hva hun finner:
http://www.a3share.com/members/30900/Rainewebcam.JPG
Endret av Lurkern
