[LØST] Uønsket firkant i Conky
Eg fant et Conky script som eg har sett en del bruker, men helt på slutten etter Rythmbox info får eg en uønsket firkant. Hvordan får eg den bort? :|
#avoid flicker
double_buffer yes
#own window to run simultanious 2 or more conkys
own_window  yes
own_window_transparent no
own_window_type normal
own_window_hints undecorate,sticky,skip_taskbar,skip_pager
#borders
draw_borders no
border_margin 1
#shades
draw_shades no
#position
gap_x 5
gap_y 0
alignment top_left
#behaviour
update_interval 1
#colour
default_color  8f8f8f
#default_shade_color 000000
own_window_colour 222222
#font
use_xft yes
xftfont DejaVu Serif Book:pixelsize=9
#to prevent window from moving
use_spacer none
minimum_size 1680 0
#mpd
mpd_host localhost
mpd_port 6600
# Possible variables to be used:
#      Variable         Arguments                  Description
#  acpiacadapter                     ACPI ac adapter state.
#  acpifan                           ACPI fan state
#  acpitemp                          ACPI temperature.
#  adt746xcpu                        CPU temperature from therm_adt746x
#  adt746xfan                        Fan speed from therm_adt746x
#  battery           (num)           Remaining capasity in ACPI or APM
#                                    battery. ACPI battery number can be
#                                    given as argument (default is BAT0).
#  buffers                           Amount of memory buffered
#  cached                            Amount of memory cached
#  color             (color)         Change drawing color to color
#  cpu                               CPU usage in percents
#  cpubar            (height)        Bar that shows CPU usage, height is
#                                    bar's height in pixels
#  downspeed         net             Download speed in kilobytes
#  downspeedf        net             Download speed in kilobytes with one
#                                    decimal
#  exec              shell command   Executes a shell command and displays
#                                    the output in torsmo. warning: this
#                                    takes a lot more resources than other
#                                    variables. I'd recommend coding wanted
#                                    behaviour in C and posting a patch :-).
#  execi             interval, shell Same as exec but with specific interval.
#                    command         Interval can't be less than
#                                    update_interval in configuration.
#  fs_bar            (height), (fs)  Bar that shows how much space is used on
#                                    a file system. height is the height in
#                                    pixels. fs is any file on that file
#                                    system.
#  fs_free           (fs)            Free space on a file system available
#                                    for users.
#  fs_free_perc      (fs)            Free percentage of space on a file
#                                    system available for users.
#  fs_size           (fs)            File system size
#  fs_used           (fs)            File system used space
#  hr                (height)        Horizontal line, height is the height in
#                                    pixels
#  i2c               (dev), type, n  I2C sensor from sysfs (Linux 2.6). dev
#                                    may be omitted if you have only one I2C
#                                    device. type is either in (or vol)
#                                    meaning voltage, fan meaning fan or temp
#                                    meaning temperature. n is number of the
#                                    sensor. See /sys/bus/i2c/devices/ on
#                                    your local computer.
#  kernel                            Kernel version
#  loadavg           (1), (2), (3)   System load average, 1 is for past 1
#                                    minute, 2 for past 5 minutes and 3 for
#                                    past 15 minutes.
#  machine                           Machine, i686 for example
#  mails                             Mail count in mail spool. You can use
#                                    program like fetchmail to get mails from
#                                    some server using your favourite
#                                    protocol. See also new_mails.
#  mem                               Amount of memory in use
#  membar            (height)        Bar that shows amount of memory in use
#  memmax                            Total amount of memory
#  memperc                           Percentage of memory in use
#  new_mails                         Unread mail count in mail spool.
#  nodename                          Hostname
#  outlinecolor      (color)         Change outline color
#  pre_exec          shell command   Executes a shell command one time before
#                                    torsmo displays anything and puts output
#                                    as text.
#  processes                         Total processes (sleeping and running)
#  running_processes                 Running processes (not sleeping),
#                                    requires Linux 2.6
#  shadecolor        (color)         Change shading color
#  stippled_hr       (space),        Stippled (dashed) horizontal line
#                    (height)
#  swapbar           (height)        Bar that shows amount of swap in use
#  swap                              Amount of swap in use
#  swapmax                           Total amount of swap
#  swapperc                          Percentage of swap in use
#  sysname                           System name, Linux for example
#  time              (format)        Local time, see man strftime to get more
#                                    information about format
#  totaldown         net             Total download, overflows at 4 GB on
#                                    Linux with 32-bit arch and there doesn't
#                                    seem to be a way to know how many times
#                                    it has already done that before torsmo
#                                    has started.
#  totalup           net             Total upload, this one too, may overflow
#  updates                           Number of updates (for debugging)
#  upspeed           net             Upload speed in kilobytes
#  upspeedf          net             Upload speed in kilobytes with one
#                                    decimal
#  uptime                            Uptime
#  uptime_short                      Uptime in a shorter format
#  seti_prog                         Seti@home current progress
#  seti_progbar      (height)        Seti@home current progress bar
#  seti_credit                       Seti@hoome total user credit
#$alignc center text
TEXT
${voffset -1} Cpu: ${color e0e0e0}${font}${cpu cpu0}% ${color} | Mem: ${color e0e0e0}${font}${mem}${color}  |  ${color} Uptime: ${color e0e0e0}${font}${uptime_short}${color}  |  ${color} Down: ${color e0e0e0}${font}${downspeed wlan0} Kb/s ${color} ${totaldown wlan0} downloaded${color}  |  Up: ${color} ${color e0e0e0}${upspeed wlan0} Kb/s ${color} ${totalup wlan0} uploaded${color}  |  ${color}Root: ${color e0e0e0}${font}${fs_free /} ${color} Home: ${color e0e0e0}${font}${fs_free /home}${color}  | Now Playing : ${color e0e0e0}${font} ${exec rhythmbox-client --no-start --print-playing-format %aa} - ${exec rhythmbox-client --no-start --print-playing-format %tt}
Endret av Kleivert
Ja, men firkanten går ikke bort uansett om eg fjerner alt som har med Rythmbox å gjøre, så det er ikke der feilen ligger tror eg.
Fant forsåvidt ut av det var nok med: ${exec rhythmbox-client --print-playing}
som du sier :)
Endret av Kleivert
Har sett lignende når tekstfiler (i dette tilfellet conky-configen) har vært innom en Windows-maskin og fått med seg en CRLF. Unix bruker bare LF (linefeed), så CR (carriage return) vises ofte som en firkant e.l.
Prøv å gå på linjen under, trykk backspace, så enter igjen og lagre. Evt. spesifiser i en tekst-editor at du vil lagre fila i unix-format, og ikke dos-format.
