Den store League of Legends tråden
har vært bra i hele dag nesten, eller ok, chatten gikk litt ape tidligere.
edit: fant forresten release notes for kommende patch, digger de buffer ezreal sin ult så den kan brukes til annet enn å farme med :p
New Skins in the Store
Commando Jarvan
Dragon Slayer Jarvan
Hextech Anivia
Loch Ness Cho’Gath
PVP.net v1.30.17
The Login Queue will now update your position more regularly
The Login Queue will no longer lock the focus of the application
You can now disable the Music at the main login page
Clickable URLs can now be sent via player to player chat
Updated the splash art for Twitch, Evelynn, Katarina, and Annie
Fixed several bugs with the Login Queue
Fixed a bug where your IP/RP balance would display incorrectly as 0
Fixed a bug where Summoners would display as Level 1 before displaying their correct Level and Rating
Fixed a bug where the display style for the Buddy List was overly dark
Fixed a bug where the Recently Purchased section of the Profile was working incorrectly
League of Legends v1.0.0.112
Jarvan, the Exemplar of Demacia
Dragon Strike: Jarvan IV charges through his opponent, dealing physical damage and lowering their armor by a %. This will pull Jarvan IV to a Standard if it encounters one, knocking up all enemies in his path.
Golden Aegis: Jarvan IV calls upon the ancient kings of Demacia to shield him from harm and slow surrounding enemies. Triggers automatically if damage would reduce Jarvan below 300 Health if it is not on cooldown.
Demacian Standard: Passively grants Jarvan bonus attack speed and armor. Active: Throws a Demacian flag, dealing physical damage and granting passive benefits to nearby allies.
Cataclysm (Ultimate): Jarvan IV heroically leaps at his target, dealing physical damage and creating a circle of terrain around them for a few seconds.
Martial Cadence (Passive): Jarvan IV exploits his target's opening, dealing 8% of the target's current HP as magic damage. This effect cannot occur on the same target for 6 seconds.
Anivia
Glacial Storm initial mana cost decreased to 75/125/175 from 100/150/200
Caitlyn
Ace in the Hole
Projectile speed increased to 3200 from 2200
Range increased to 1600/1900/2200 from 1400/1800/2200
Initial cast time leading up to the channeling time has been significantly decreased
Ezreal
Trueshot Barrage now scales with bonus attack damge at a 1.0 ratio
Garen
Decisive Strike
Movement speed boost increased to 3 seconds from 2
Total duration available to proc the silence and hit reduced to 6 seconds from 7
Bonus damage ratio increased to 150% from 120%
Judgment cooldown reduced to 14/13/12/11/10 from 15/14/13/12/11 seconds
Janna
Monsoon no longer slows enemies who re-enter the storm
Karma
Heavenly Wave base heal increased to 35/55/75/95/115/135 from 30/45/60/75/90/105
Spirit Bond cooldown reduced to 15/14/13/12/11/10 from 20/18/16/14/12/10.
Soul Shield Increased the shield strength by 10 at all ranks.
Mantra cooldown reduced to 25 seconds from 30 seconds.
LeBlanc
Ethereal Chains ability power ratio increased to 0.5 from 0.4 for both damage components
Maokai
Twisted Advance levelup tooltip now correctly displays the increase in mana cost
Fixed a bug where Maokai's death animation would not play if he is slain during Twisted Advance
Mordekaiser
Mace of Spades ability power ratio increased to 0.4 from 0.2
Singed
Fixed a bug that was causing Poison Trail to have a 1 second cooldown upon activation
Sivir
Fixed a bug with Boomerang Blade that was causing certain items to not show their bonus attack damage in the tooltip
Urgot
Fixed a bug with Acid Hunter that was causing missile lock to shoot further then intended
Veigar
Primordial Burst ability power ratio increased to 1.2 of Veigar's ability power and reduced to 0.8 of his target's ability power
Zilean
Fixed a bug where the particle on Time Warp would not persist through the full duration of the movement speed modifier at later ranks
Items
Fixed a tooltip bug where Haunting Guise said it provided 180 Health and 20 Ability Power, when it actually provided 200 Health and 25 Ability Power
Morello's Evil Tome cooldown reduction increased to 20% from 15%
Sight and Vision Wards can now be stacked 5 per slot
Tiamat
Attack damage increased to 50 from 42
Mana regeneration per 5 seconds increased to 5 from 4
Shop tooltip is now more descriptive, matching the inventory tooltip
Spirit Visage increased healing and regeneration effects reduced to 15% from 20%
Summoner Spells
Ghost duration decreased to 10 from 14
General
Death Timers have been reduced on Summoner's Rift to 12-50 seconds from 28-50 seconds
Minions
Melee minion magic resist now increases 1.25 per 3 minutes (up from 0.5)
Ranged minion armor now increases 1.25 per 3 minutes (up from 0.5)
Cannon minion armor and magic resist now increase 3 per 3 minutes (up from 2)
After 20 minutes, cannon minions now spawn every 2 waves (up from every 3 waves)
Cannon minions and super minions now reduce turret damage by 65% (up from 50%)
Fixed a tooltip bug "This unit receive..." with cannon minions and super minions
Minions now deal about 50% more damage to turrets
Turrets
Turrets deal about 10% less base damage to champions
Turrets now have 20% armor penetration
Fixed several typos in the Options Menu
Endret av TorbjørnK
De har implementert login queue, som betyr at etter klokka 7 må du vente et kvarter før du kan logge inn.
Det kommer helt an på hvor mange som er pålogget. Jeg har opplevd å komme inn med en gang på peak men en annen gang var det "2 hours remaining".
Skjønner ikke hvorfor Anivia sin ulti blir buffet. Jeg spiller henne selv som main, og lategame er hun rimelig OP med sin combo. En buff på ultien vil nok neppe gjøre henne mindre OP.
Det er vel at den ble buffa opp til ett mellomstadium fra tidligere. Den ble nerfet forrige patch og rebuffes igjen nå.
Køene er litt fucket, så bare logg på kl 13 elns og la klienten kjøre. Har vært ørlite granne mindre kødd med chatservern de siste dagene, om det var kødd i dag på peak vet jeg ikke da jeg var vekke.
Har aldri muligheten til å logge på før etter 4 på arbeids dager. Så hvis køen starter rundt 13 tiden dropper jeg nok lett LoL litt til.
I hvertfall fram til jeg har tid til å vente i kø, eller ikke har noe bedre å gjøre.
Køen starter ikke da, er bare da jeg logger på :p Køene starter vel heller sånn 4 ellerno ettersom alle slutter på jobb på det tidspunktet. Funker vel like greit å ta seg 1 minutt ekstra og få på lol før man går på jobb.
En kan jo gjøre det, men da hjelper du jo egentlig ikke med køen, og du tar opp en plass på serveren som ikke blir brukt. Tro meg hvis dette blir et problem blir jeg ikke overaska om de implementerer noe for å kicke inaktive spillere som er logget på.
Sist jeg spilte var det så store problemer daglig at det ble nesten mer frustrasjon enn morro å spille. Veldig trist egentlig, siden LoL er et supert spill!
Ah my bad then, er visst ikke så fryktelig oppdatert. Hvordan er det med treanten? Så han i et game nettopp, festlig fyr.
Har prøvd han selv et par kamper. Virker helt ok, men greide ikke helt å plassere rollen hans, så tror nok jeg endte opp med å prøve og gjøre litt for mye på en gang, og dermed feilet litt. >_>
