Java virker ikke i Internet Explorer
Hei
Problemet fant jeg ved jeg ikke fikk logget inn i nettbanken min. Java er installert men det kommer ikke opp i verktøy, alternativer for internett, avansert.
I Java control panel er er Internet explorer ikke mulig å aktivere. I advanced, default java for browswers. Her er Firefox mulig å sla av å på. Internet explorer er det bare en grå skygge huket av. Ikke mulig å forandre
Jeg har avinstallert og reinstallert flere ganger uten at dette nytter.
Her er det som kommer opp n år jeg kjører test på Java
Java Plug-in 1.6.0_20
Using JRE version 1.6.0_20-b02 Java HotSpot Client VM
User home directory = C:\Users\Christian
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
load: class no.bbs.detector.Detector not found.
java.lang.ClassNotFoundException: no.bbs.detector.Detector
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketException: Permission denied: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.<init>(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.New(Unknown Source)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: no.bbs.detector.Detector
load: class testvm2/Main.class not found.
java.lang.ClassNotFoundException: testvm2.Main.class
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
... 7 more
Exception: java.lang.ClassNotFoundException: testvm2.Main.class
Noen som har en ide om hva dette kan være?
Hvis det funker med Firefox så er vel ikke det noe stress. Er vel egentlig bare nok en grunn til ikke å bruke IE.
Jeg holdt på å skrive det - ønsker ikke svar av typen - så bruk Firefox da, visste det kom.
Et ikke brukbart svar. Lurer på evt. virus eller...? Noe er galt
Hadde denne for en tid tilbake. Men ingenting ved virusscanning nå.
TrojanDownloader:JS/Renos is a JavaScript trojan that displays misleading reports of system infection. It also downloads other malware into the system.
Hadde samme problem for 10 minutter siden.
Viste jeg hadde instalert Java, men virket ikke på netbank.
Det viste seg at jeg hadde instalert 64 bit versjon. (har W7 64 Bit), men hadde åpnet 32 bit
IE som er med på min W7. Vet ikke om du har samme os.
Håper dette hjalp.
Og du har testet med brannmur av/på?
Det kan kanskje også være ett rettighetsproblem siden disse boksene er grået ut.
Det kan jo og være en ide og avinnstallere Java en gang til. Hvis avinnstallasjonen ikke fjerner program folderen til Java så fjern den manuelt etterpå.
Sjekk at alt er borte før du rebooter og legger inn Java på nytt.
Endret av vidarkri
Jeg vet ikke hva som var galt. det som løste problemet var å avinstallere og deretter velge ny plassering ved installering.
Fant svaret ved å google en av linjene i feilmeldingen:
Løst men ikke forstått. Ser gjerne at noen poster et svar hvis de vet hva som forårsaket det.
