[Løst] Hjelp til Asynchronous Winsock
Hei
Sitter å prøver å lage en data overføring mellom 2 programmer via en socket.
Sånn den er i dag så må jeg selv kjøre connect og listen osv.
Har lagd en callback som jeg fant i exempel ,men vet ikke hvordan jeg faktisk bruker det.
Så det jeg ønsker hjelp til er å faktisk lage socketen asynchronous.
Her er ServerSocket.cpp fila som jeg bruker:
#include "stdafx.h"
#include "ServerSocket.h"
#define SOCK_STREAM     1
#define SOCK_DGRAM      2
#define SOCK_RAW	3
#define AF_INET		2
#define IPPROTO_TCP     6
#define MY_MESSAGE_NOTIFICATION	1048
ServerSocket::ServerSocket(){
LRESULT CALLBACK ServerSocket::WndProc(HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam){
switch(message){
case  MY_MESSAGE_NOTIFICATION:
	switch(lParam){
case FD_ACCEPT:{
	cout<<"ACCEPT\n";
	break;
case FD_CONNECT:{
	cout<<"CONNECT\n";
	break;
case FD_READ:{
	char buffer[80];
	memset(buffer, 0, sizeof(buffer));
	recv(ss, buffer, sizeof(buffer)-1, 0);
	cout<<"READ\n"<<buffer;
	MessageBeep(MB_OK);
	break;
	case FD_CLOSE:{
		Break;
break;
default:
	return DefWindowProc(hwnd, message, wParam, lParam);
ServerSocket::~ServerSocket(){
CloseConnection();
int ServerSocket::ListenOnPort(int portno)
int error = WSAStartup (0x0202, &w);   // Fill in WSA info
if (error){
	cout<<"Winsock";
	return false; //For some reason we couldn't start Winsock
if (w.wVersion != 0x0202) //Wrong Winsock version?
	cout<<"version";
	WSACleanup ();
	return false;
SOCKADDR_IN addr; // The address structure for a TCP socket
addr.sin_family = AF_INET;      // Address family
addr.sin_port = htons (portno);   // Assign port to this socket
addr.sin_addr.s_addr = htonl (INADDR_ANY);
ss = socket (AF_INET, SOCK_STREAM, IPPROTO_TCP); // Create socket
if (ss == INVALID_SOCKET)
	cout<<"create";
	return false; //Don't continue if we couldn't create a //socket!!
if (bind(ss, (LPSOCKADDR)&addr, sizeof(addr)) == SOCKET_ERROR)
	//We couldn't bind (this will happen if you try to bind to the same
	//socket more than once)
	cout<<"bind";
	return false;
cout<<"shhh!! listen\n";
listen(ss, SOMAXCONN);
WSAAsyncSelect(ss,hwnd ,MY_MESSAGE_NOTIFICATION ,FD_ACCEPT | FD_CONNECT | FD_READ | FD_CLOSE);
Endret av BlueDude
Svarer på min egen tråd tilfelle det skulle være andre som trengte noe lignende.
Siden jeg brukte VCL forms så virket det som om det var vanskelig å få til en Async.Socket
ved hjelp av window messages som jeg prøvde på i første posten, I stede gikk jeg over til å bruke WSAEventSelect() isteden for å bruke WSAAsyncSelect(), Dette gjør at man tar i mot events og legger de til en eventlist og behandler de ut i fra det.
Brukte denne tutorial`n til hjelp med å bygge om socketene mine:
winsocket
