Trenger litt hjelp til å sette opp apache2
Hei,
Jeg skal sette opp apache2 slik at jeg har noen prosjekter på dev.project og et annet prosjekt på dev.iw3.
Det jeg har gjort til nå er å sette opp en virtual host i apache2/sites-available/default sånn som dette:
<VirtualHost *:80>
ServerAdmin [email protected]
DocumentRoot /var/www/dev.project
ServerName dev.project
ServerAlias dev.project *.dev.project
<Directory />
	Options FollowSymLinks
	AllowOverride None
</Directory>
<Directory /var/www/dev.project>
	Options Indexes FollowSymLinks MultiViews
	AllowOverride None
	Order allow,deny
	allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
	AllowOverride None
	Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
	Order allow,deny
	Allow from all
</Directory>
ErrorLog /var/log/apache2/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog /var/log/apache2/access.log combined
   Alias /doc/ "/usr/share/doc/"
   <Directory "/usr/share/doc/">
       Options Indexes MultiViews FollowSymLinks
       AllowOverride None
       Order deny,allow
       Deny from all
       Allow from 127.0.0.0/255.0.0.0 ::1/128
   </Directory>
</VirtualHost>
<VirtualHost *:80>
       DocumentRoot /var/www/iw3/html
       ServerName dev.iw3
       ServerAlias dev.iw3 *.dev.iw3
       <Directory /var/www/iw3>
               AllowOverride All
               Order allow,deny
               allow from all
       </Directory>
               AllowOverride All
               Order allow,deny
               Allow from all
       </Directory>
       # alert, emerg.
       LogLevel warn
       AllowOverride None
       Order deny,allow
       Deny from all
   </Directory>
</VirtualHost>
Sånn som det er nå, så fungerer dev.project, men ikke dec.iw3.
Jeg har min mistanke om at jeg har feilen i /etc/hosts eller i alle fall med IPene...
/etc/hosts ser slik ut:
127.0.0.1	dev.project
127.0.0.1	dev.iw3
127.0.1.1	teis-laptop
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
Noen som kan hjelpe?
Mm, jeg må ha det som er i /html mappa det er dit dev.iw3 skal peke, men prøvde å sette begge pathene til samme sted. (/var/www/iw3/html)
Men får samme feilmelding hele tiden:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [email protected] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Erroren i loggen er:
] /var/www/iw3/html/.htaccess: Invalid command 'RewriteEngine',
Noen som vet hva dette kan skyldes?
