Får ikkje kobla til MPD med lan-ip.
Kjører mpd, gmpc verkar fint med desse instillingane:
men om eg forandrer til lan-ip, som i mitt hovud skulle bety det samme som localhost, (på samme maskin som serveren kjører) så skjer dette:
I utgangspunktet har eg tenkt å bruke ein klient på iPhone til å kontrollere serveren, men eg får ikkje kobla til med den heller.
Nokon som kan hjelpe ? Forstår ikkje kva som er gale :-P Har skrudd av ufw
frå /etc/mpd.conf
# An example configuration file for MPD
# See the mpd.conf man page for a more detailed description of each parameter.
# Files and directories #######################################################
# This setting controls the top directory which MPD will search to discover the
# available audio files and add them to the daemon's online database. This
# setting defaults to the XDG directory, otherwise the music directory will be
# be disabled and audio files will only be accepted over ipc socket (using
# file:// protocol) or streaming files over an accepted protocol.
music_directory		"/home/infoskjerm/Musikk"
# This setting sets the MPD internal playlist directory. The purpose of this
# directory is storage for playlists created by MPD. The server will use
# playlist files not created by the server but only if they are in the MPD
# format. This setting defaults to playlist saving being disabled.
playlist_directory		"/home/infoskjerm/Musikk/playlist"
# This setting sets the location of the MPD database. This file is used to
# load the database at server start up and store the database while the
# server is not up. This setting defaults to disabled which will allow
# MPD to accept files over ipc socket (using file:// protocol) or streaming
# files over an accepted protocol.
db_file			"/var/lib/mpd/tag_cache"
# These settings are the locations for the daemon log files for the daemon.
# These logs are great for troubleshooting, depending on your log_level
# settings.
# The special value "syslog" makes MPD use the local syslog daemon. This
# setting defaults to logging to syslog, otherwise logging is disabled.
log_file			"/var/log/mpd/mpd.log"
# This setting sets the location of the file which stores the process ID
# for use of mpd --kill and some init scripts. This setting is disabled by
# default and the pid file will not be stored.
pid_file			"/var/run/mpd/pid"
# This setting sets the location of the file which contains information about
# most variables to get MPD back into the same general shape it was in before
# it was brought down. This setting is disabled by default and the server
# state will be reset on server start up.
state_file			"/var/lib/mpd/state"
# General music daemon options ################################################
# This setting specifies the user that MPD will run as. MPD should never run as
# root and you may use this setting to make MPD change its user ID after
# initialization. This setting is disabled by default and MPD is run as the
# current user.
user				"mpd"
# This setting sets the address for the daemon to listen on. Careful attention
# should be paid if this is assigned to anything other then the default, any.
# This setting can deny access to control of the daemon.
# For network
bind_to_address		"localhost"
# And for Unix Socket
#bind_to_address		"/var/run/mpd/socket"
# This setting is the TCP port that is desired for the daemon to get assigned
# to.
#port				"6600"
# This setting controls the type of information which is logged. Available
# setting arguments are "default", "secure" or "verbose". The "verbose" setting
# argument is recommended for troubleshooting, though can quickly stretch
# available resources on limited hardware storage.
#log_level			"default"
# If you have a problem with your MP3s ending abruptly it is recommended that
# you set this argument to "no" to attempt to fix the problem. If this solves
# the problem, it is highly recommended to fix the MP3 files with vbrfix
# (available from <http://www.willwap.co.uk/Programs/vbrfix.php>), at which
# point gapless MP3 playback can be enabled.
#gapless_mp3_playback			"yes"
# This setting enables MPD to create playlists in a format usable by other
# music players.
#save_absolute_paths_in_playlists	"no"
# This setting defines a list of tag types that will be extracted during the
# audio file discovery process. Optionally, 'comment' can be added to this
# list.
#metadata_to_use	"artist,album,title,track,name,genre,date,composer,performer,disc"
# Symbolic link behavior ######################################################
# If this setting is set to "yes", MPD will discover audio files by following
# symbolic links outside of the configured music_directory.
#follow_outside_symlinks	"yes"
# symbolic links inside of the configured music_directory.
#follow_inside_symlinks		"yes"
# Zeroconf / Avahi Service Discovery ##########################################
# If this setting is set to "yes", service information will be published with
# Zeroconf / Avahi.
#zeroconf_enabled		"yes"
# The argument to this setting will be the Zeroconf / Avahi unique name for
# this MPD server on the network.
#zeroconf_name			"Music Player"
# Permissions #################################################################
# If this setting is set, MPD will require password authorization. The password
# can setting can be specified multiple times for different password profiles.
#password                        "password@read,add,control,admin"
# This setting specifies the permissions a user has who has not yet logged in.
#default_permissions             "read,add,control,admin"
# Input #######################################################################
input {
       plugin "curl"
#       proxy "proxy.isp.com:8080"
#       proxy_user "user"
#       proxy_password "password"
# Audio Output ################################################################
# MPD supports various audio output types, as well as playing through multiple
# audio outputs at the same time, through multiple audio_output settings
# blocks. Setting this block is optional, though the server will only attempt
# autodetection for one sound card.
# See <http://mpd.wikia.com/wiki/Configuration#Audio_Outputs> for examples of
# other audio outputs.
# An example of an ALSA output:
audio_output {
type		"alsa"
name		"My ALSA Device"
device		"hw:0,0"	# optional
format		"44100:16:2"	# optional
mixer_device	"default"	# optional
mixer_control	"PCM"		# optional
mixer_index	"0"		# optional
# An example of an OSS output:
#audio_output {
#	type		"oss"
#	name		"My OSS Device"
#	device		"/dev/dsp"	# optional
#	format		"44100:16:2"	# optional
#	mixer_device	"/dev/mixer"	# optional
#	mixer_control	"PCM"		# optional
# An example of a shout output (for streaming to Icecast):
#audio_output {
#	type		"shout"
#	encoding	"ogg"			# optional
#	name		"My Shout Stream"
#	host		"localhost"
#	port		"8000"
#	mount		"/mpd.ogg"
#	password	"hackme"
#	quality		"5.0"
#	bitrate		"128"
#	format		"44100:16:1"
#	protocol	"icecast2"		# optional
#	user		"source"		# optional
#	description	"My Stream Description"	# optional
#	genre		"jazz"			# optional
#	public		"no"			# optional
#	timeout		"2"			# optional
# An example of a httpd output (built-in HTTP streaming server):
#audio_output {
#	type		"httpd"
#	name		"My HTTP Stream"
#	encoder		"vorbis"		# optional, vorbis or lame
#	port		"8000"
#	quality		"5.0"			# do not define if bitrate is defined
#	bitrate		"128"			# do not define if quality is defined
# An example of a pulseaudio output (streaming to a remote pulseaudio server)
#audio_output {
#	type		"pulse"
#	name		"My Pulse Output"
#	server		"remote_server"		# optional
#	sink		"remote_server_sink"	# optional
## Example "pipe" output:
#audio_output {
#	type		"pipe"
#	name		"my pipe"
#	command		"aplay -f cd 2>/dev/null"
## Or if you're want to use AudioCompress
#	command		"AudioCompress -m | aplay -f cd 2>/dev/null"
## Or to send raw PCM stream through PCM:
#	command		"nc example.org 8765"
## An example of a null output (for no audio output):
#audio_output {
#	type		"null"
#	name		"My Null Output"
# This setting will change all decoded audio to be converted to the specified
# format before being passed to the audio outputs. By default, this setting is
# disabled.
#audio_output_format		"44100:16:2"
# If MPD has been compiled with libsamplerate support, this setting specifies
# the sample rate converter to use.  Possible values can be found in the
# mpd.conf man page or the libsamplerate documentation. By default, this is
# setting is disabled.
#samplerate_converter		"Fastest Sinc Interpolator"
# Volume control mixer ########################################################
# These are the global volume control settings. By default, this setting will
# be detected to the available audio output device, with preference going to
# hardware mixing. Hardware and software mixers for individual audio_output
# sections cannot yet be mixed.
# An example for controlling an ALSA, OSS or Pulseaudio mixer; If this
# setting is used other sound applications will be affected by the volume
# being controlled by MPD.
#mixer_type			"hardware"
# An example for controlling all mixers through software. This will control
# all controls, even if the mixer is not supported by the device and will not
# affect any other sound producing applications.
#mixer_type			"software"
# This example will not allow MPD to touch the mixer at all and will disable
# all volume controls.
#mixer_type			"disabled"
# Normalization automatic volume adjustments ##################################
# This setting specifies the type of ReplayGain to use. This setting can have
# the argument "album" or "track". See <http://www.replaygain.org> for more
# details. This setting is disabled by default.
#replaygain			"album"
# This setting sets the pre-amp used for files that have ReplayGain tags. By
# default this setting is disabled.
#replaygain_preamp		"0"
# This setting enables on-the-fly normalization volume adjustment. This will
# result in the volume of all playing audio to be adjusted so the output has
# equal "loudness". This setting is disabled by default.
#volume_normalization		"no"
# MPD Internal Buffering ######################################################
# This setting adjusts the size of internal decoded audio buffering. Changing
# this may have undesired effects. Don't change this if you don't know what you
# are doing.
#audio_buffer_size		"2048"
# This setting controls the percentage of the buffer which is filled before
# beginning to play. Increasing this reduces the chance of audio file skipping,
# at the cost of increased time prior to audio playback.
#buffer_before_play		"10%"
# Resource Limitations ########################################################
# These settings are various limitations to prevent MPD from using too many
# resources. Generally, these settings should be minimized to prevent security
# risks, depending on the operating resources.
#connection_timeout		"60"
#max_connections		"10"
#max_playlist_length		"16384"
#max_command_list_size		"2048"
#max_output_buffer_size		"8192"
# Character Encoding ##########################################################
# If file or directory names do not display correctly for your locale then you
# may need to modify this setting. After modification of this setting mpd
# --create-db must be run to change the database.
filesystem_charset		"UTF-8"
# This setting controls the encoding that ID3v1 tags should be converted from.
id3v1_encoding			"UTF-8"
Frå /etc/hots.deny:
# /etc/hosts.deny: list of hosts that are _not_ allowed to access the system.
#                  See the manual pages hosts_access(5) and hosts_options(5).
# Example:    ALL: some.host.name, .some.domain
#             ALL EXCEPT in.fingerd: other.host.name, .other.domain
# If you're going to protect the portmapper use the name "portmap" for the
# daemon name. Remember that you can only use the keyword "ALL" and IP
# addresses (NOT host or domain names) for the portmapper, as well as for
# rpc.mountd (the NFS mount daemon). See portmap(8) and rpc.mountd(8)
# for further information.
# The PARANOID wildcard matches any host whose name does not match its
# address.
# You may wish to enable this to ensure any programs that don't
# validate looked up hostnames still leave understandable logs. In past
# versions of Debian this has been the default.
# ALL: PARANOID
