x16+x4 - gjør det noe?
Cleaf
Denne nettsiden gir deg svar på det meste man kan lure på angående SLi og Crossfire.
http://www.tomshardware.co.uk/forum/245454-15-crossfire-faqs
A note about Motherboards:Some Motherboards support Multi-GPU Technology at Dual 16x mode, some support it at Dual 8x mode and some support it at 16x 4x mode Etc, what are the differences?
Well for getting the best performance out of Multi-GPU cards,you need a Motherboard that supports Multi-GPU at dual(Or more) 16x mode like Nvidia 790i ULTRA SLI, Nvidia790i SLI, Nvidia 780i SLI, Nvidia 680i( As i said, NVIDIA 790i ULTRA SLI ,790i SLI ,780i SLI and 680i SLI support 3-Way SLI too(Nvidia 680i LT SLI chipset has 2 PCI-E 16x slot which supports 2-way SLI only.),Nvidia 590i SLI, Nvidia nForce4 SLI 16x, ATI CrossFire Xpress 3200,Intel X38,X48 and X58.
Dual 8x is a very good configuration too,it doesn't have alot of difference(performance wise) with Dual 16x and its cheaper too.
Chipests like Intel P55*,Intel P45 Nvidia 750i SLI, Nvidia 650i SLI,NVIDIA 570i SLI, NVIDIA nForce4 SLI, ATI Radeon Xpress 200, Intel 975x and ONLY few Intel P35 boards(Like ASUS BLITZ FORMULA and ASUS BLITZ EXTREME) support Multi-GPU at dual 8x mode.
However,there are some expections too,for example EVGA has a 750i Motherboard(The model of it is
EVGA 750i SLI FTW)Which supports SLI at dual 16x mode unlike many 750i Motherboards which support SLI at dual 8x mode.
The last one is 16x 4x, this one is the weakest and doesn't perform very good compared to dual 8x or dual 16x,so i won't recommend it for Multi-GPU configuration. Intel P35 and P965 chipsets support Multi-GPU at 16x 4x mode.
Here is a good review which compares CrossFire performance between dual 16x,dual 8x and 16x 4x:
4x blir en begrensning ja.
Jeg har samme begrensning på mitt hovedkort, 16x og 4x. Derfor jeg kjørte på med ett kraftig skjermkort som holder lenge, isteden for å satse på xfire.
Å kjøpe 2x 5770 for xfire til å begynne med synes jeg virker litt rart. Jeg ser på xfire og sli som en mulighet å oppgradere ved en seinere anledning. Kjøp heller 5850 eller 5870, noe som vil holde i massevis. Det blir uansett bedre enn å kjøre 5770 i xfire over 16x/4x...
jeg kjøpte i utgangspunktet 2x 5770 fordi de var på tilbud og 2stk skulle yte mer enn et enkelt 5850. På siden til hovedkortet kom det ikke veldig klart fram at spor nr2 var x4, men fant ut det i ettertid. Litt kjipt, men sånn ble det.
Jeg kjøper heller et nytt skjermkort enn å kjøpe ett til, for når tiden er moden til skjermkortbytte så er gjerne enkeltmuligheten mye kraftigere og gir bedre ytelse enn hva et nytt av samme type kunne gjøre. Så at jeg kjøpte Crossfire nå hadde ikke så mye å si, men pga. begrensningen x4 så er det ikke veldig attraktivt lenger.
Har en kamerat som kjøpte 5770 hawk. Men det ytelsen var ikke bra nok i bc2 så han kjøpte ett til og kjørte xfire. Han har derimot 8x/8x og det går helt fint uten ytelses tap. Nå kjører han bc2 på maks.
Hvis jeg var deg ville jeg byttet ut dine 5770 og skaffet ett nytt kort. 5850 er ett godt kort som burde holde. Beveger du deg opp i pris er jo valget mellom 5870 og gtx470.
Han nevner P35 og eldre 965, disse har det problemet med at de henter de 4x PCI-E 1.1 fra Sørbrua og da går det tregt, faktisk tregere med 2 kort enn med 1.
Men på P55 er fortsatt 16x og 4x ikke noe å foretrekke.
P55 har 8x/8x , ikke 16x/4x.
Du får p55 med 16x/4x OG 8x/8x.. Jeg har P55-UD3, som er 16x/4x... ;)
Som nevnt av andre, P55 kommer i begge varianter, både 8x / 8x og 16x / 4x så her må man passe på ellers kan man brenne seg kraftig.
ok. det viste jeg ikke. litt merkelig, de kan vel ikke selge så mye av 16x/4x versjonene, da sli funker dårlig da.
men åssen tror dere 2 stk GTX 470 vil fungere i en 8x/8x oppsett. er vel ikke mer en et par fps man mister contra 16x/16x ?
Endret av Blazer
