The Sims, Superstar - krasjer bare jeg ser på det
da jeg installerte Superstar oppå alle de andre expansionene kom det opp en liten notice om at siden jeg kjørte WinXP, så måtte jeg oppgradere et eller annet.. i readme.txt står dette:
Playing with Windows® XP
When playing The Sims Superstar on Windows® XP, be sure to use an account that is a member of the Administrators group.
We only support one copy of the game running on Windows® XP, even with multiple users logged in.
If you are running Windows XP hotfix 328310 and attempt to install you will receive a message from the installer that says, "Attention XP users: Since you have Windows XP hotfix 328310 installed, please install Windows XP hotfix 329623 before installing The Sims Superstar. Please refer to the Readme file for additional information."
Hotfix 329623 will fix a problem where the InstallShield would not shut down properly after installing The Sims Superstar.
***To find Windows XP hotfix 329623***
-Go to Microsoft's website
-Click "Support" under the "Resources" menu choice on the left side
-Click "Knowledge Base" under "Support" in the main window
-Enter "kb329623" in the "Search for..." text field and click "Go"
-Click on "Problems with InterVideo DVD Software After Upgrading to Windows XP Service Pack 1" under the "Search Results"
-Click on "All Languages: Download the 329623 package now" under "RESOLUTION" halfway down the page
-Click on "Download" in the box titled "Issue with DirectX May Cause DVD Players To Not Work"
-Select “Open” from the Download window to begin the install
-NOTE: You will have to reboot your computer after the install is completed.
There is a known compatibility issue with the Intel 845G integrated video chipset that causes choppy video playback on these systems. If you have this chipset, we recommend running with -w command line option in your shortcut which is detailed in the "Diagnostic tools:" section under "Video Problems" below.
okey.. altså.. jeg gjorde som den sa, og installerte greia men spillet krasjer fortsatt ved loading. hva gjør jeg? :shrug:
Installer en av de tidligere expansionene til slutt... altså - The Sims - Hotdate - superstar - unleashed eller lignende, for da bruker du cd'n til den siste installerte til å spille med! Fungerer forsåvidt bra å spille superstar å med meg...
Det er typisk for EA-games. Den siste versjonen av NFS var også helt syk. Flere anmeldere skrev om det i omtalene sine. Spillet var et makkverk hva angikk stabilitet. Har sett at dette gjelder noen av Sims versjonene også. Det er synd at de ser ut til å ødelegge for seg selv med å lage slett kvalitet. :shrug:
NÅ virker superstar uten å karsje se her:
1)first of all if u haven't installed the sims superstar lucky for you but
if you have then you have to uninstall all of ur sims and expansions then
clean it out with the sims eraser.
2)after uninstalling. install all the sims and all expansions except for
superstar! before installing the sims superstar make sure to copy the
"sound.far" file)from files/maxis/thesims/expansionshared/sound/)because the
1 on the cd is corupt then make sure to store it in a safe place. to be on
the safe side also copy and store the Program FilesMaxisThe
SimsMusicModesLoadloadloop.wav.
3) finally you get to install the sims superstar. once installed move the 2
files back to its original postion and start the game!
4)the game should be able to get past the intro but if you go into the
studio town and it doesn't do anything when u click on the icons make sure
to download the devience crack and it should work!!
5)have fun playing!! =)"
