imgorg.ioc, kan det være virus ?
Jeg har et irriterende problem. I alle mapper jeg har mp3 filer dukker denne filen "imgorg.ioc" opp. Sletter jeg den kommer den tilbake etter en liten stund :-?
Jeg brukt følgende programmer :
Spybot - Search & Destroy
Ad-aware 6.0
Norton Antivirus 2002
Noen som har vært borti dette ?
Tar gjerne imot råd ...
Takker på forhånd
Google! :lol:
In the winamp properties, it the general perpose tab there is a plugin for io-player, a song tracking plugin. if u uninstall it u will have no problems
On Wednesday, April 9, 2003 at 3:01 pm, Dave wrote:
>in my kazaa shared folder, as well as other folders, i keep getting a file labeled
>'imgorg.ioc' and everytime i delete it, it comes back. also in winamp when it advances
>songs i get a popup with Abort/Retry/Fail with the label of 'gen_io' 'this folder
>is locked by another process.' i suppose these two have something to do with each
>other. i can't find the program that is doing this, but i'm going to run anti virus
>to see if that helps. thx
