Forslag til et god hovedkort?
LMH1
Hei hvordan kommer man med forslag til asus angående hovedkort?
Grensesnitt I/O:
7.1 x lyd - line-In -micophone- stereo minijack 3,5 mm
1 x tastatur - generell - 6-pin mini-DIN (PS/2-stil)
1 x mus - generell - 6-pin mini-DIN (PS/2-stil)
4 x USB3 SuperSpeed - 4 pin USB Type A
1 x nettverk - Ethernet 100Base-TX/1000Base-T - 10000Base-T- RJ-45
1 x IEEE 1394 (FireWire) - 6 pin FireWire
1 x E-sata
1 x HDMI
Harddrives:
8 X Serial ATA-600 (sata 3)
eSATA-port
Features:
DMI 2.0-støtte, WfM 2.0 støttet, norsk språklig BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ACPI 2.0a-støtte, SMBIOS 2.5-støtte
C.P.R. (CPU-parameterminne), jakk-retasking, MemOK!, varmerørschipsetavkjøling, ASUS Turbo Key, ASUS Q-Design, Stack Cool 3, T.Probe, 12+2 Phase Power Design, CrashFree BIOS 3, ASUS Q-Connector, ASUS AI NET2, ASUS Noise Filter, ASUS Stepless Frequency Selection (SFS), lydjakkpåvisningsteknologi, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, ATI CrossFireX-teknologistøtte, Intel Extreme Memory Profile (XMP)-støtte, ASUS Express Gate, ASUS Fan Xpert, ASUS TurboV, Intel Turbo Boost Technology.
Advance overclock features
Power:
24-pin hovedstrømforsyningskontakt, 8-pin ATX12V-kontakt
Ram:
6x DDR3 ram modules
CPU:
Single AMD or intel CPU quad core/6 core
Boot
Support to boot from USB,sata harddrives, network (Wake on LAN (WOL), Wake on Ring (WOR).
Expansion card:
6x PCI-E 16x v2
Overclock features:
Can clock cpu to 200% with all cpu without damaged motherboard.
Support cpu voltage rage from 0.2 volt to 1.6 volt.
Support ram voltage from 1.5 volt to 2.2 volt.
Bios size:
Up to 8 MB size
Boot time max 2 sec.
Use ISO bios that is the same as all motherboard that support ix6878 features.
ASUS express gate:
Use CF or SD memory card on motherboard that can be upgraded to 32 GB.
Secure:
Bios passord with max 12 letters (support æøå and number)
Overclock settings recovery if bios failed to load
LEDS
One led to show that motherboard PSU cable is connected, and one reed to show damages/wrong connected device.
Hardware supported
All ram and cpu that exist on socket AMD3 is supported ix6878
Skipped:
IDE, floppy, serial/paraell kabelen kan droppes, også s-video og RCA video.
Tror dere det blir noe tilsvarende hovedkort som dette til ca 1000-1500 kr?
Altså en rask oppsumering:
  • Bruker SD eller CF minnekort for express gate isteden for harddisk.
  • Støtter 200% overklokking uten defekt hovedkort. (levetiden på andre komponentene kan ikke garanteres).
  • Pris 1000 - 1500 kr.
  • Støtte for USB3, HDMI, Esata, sata, PS2, 10 gigabit nettverkkort.
  • Støtter alle prosessorer og ram brikker som bruker samme sokkel f.eks DDR3 og AM3 med standarderisert bios.
  • Norsk bios, på 8 MB størrelse og 12 siffer passord med tall og æøå.
  • Flere led for feilsøking, grønn = Ok, rød = feil, oransje = feil.
  • levetid minst 5 år (3 år med 200% overklokking).
Endret av LMH1
En HK produsent har ikke så veldig mange valg, du må huske at det AMD eller Intel som bygger brikkesettene og selger LØSE brikker til de slik at de får designe, utenom det så har ikke en HK produsent så mye de skulle ha sagt.
Ellers for overklokkere så vil de ikke gi slipp på IDE... Hvorfor? IDE er IKKE påvirket av PCI-E frekvensen og denne bruker også å bli klokket opp og da faller SATA kontrollerne ut etter du når en viss frekvens.
I tilegg er det andre problemer med å bygge ett hovedkort slik som plass, nå er det ikke bare spor som man må tenke på, men man har også andre ting slik som motstandere, kobberbaner, kondensatorer osv som må monteres på overflaten i tilegg til brikkene for nettverk, BIOS og harddisk kontrollere.
EVGA E759 Classified er ett eksempel på ett HK som er såpass fullt at du ikke får stappet ditt mye mer, ikke en mostander engang er det plass til.
Endret av 007CD
Nå er det vel noe plass på baksiden av hovedkortet?
Kanskje ikke mye, men det er nok altid mulig med litt høyere skruer og muttere som går litt lenger opp.
Selv har jeg aldri overklokket, PCI-E eller PCI, setter det som regel, på 100 mhz (33 mhz) siden jeg ble anbefalt at det ikke er så mye vits å overklokke der.
Spessielt på budsjett skjermkort, som flaskehalsen vil altid være GPU eller grafikk minne som vil være flaskehalsen.
Men dere er vel enig i at, hovedkort produsentene kan bli bedre på overklokking og garanti?
Hva er det vits å kunne sette volt over 1.6 på en core 2 duo/Quad prosessor? når prosessoren ikke er beregnet på høyere en 1.5 volt.
Baksiden er det litt verre å plassere saker og ting, spesielt ICer, jekke opp HKet høres interresant ut, men da bryter du ATX standarden ved at du kommer for høyt for ekspansjonskort og I/O panelet på baksiden.
Det er en masse mål i ATX standarden som også skal passe sammen, og disse er også hindre for hva man kan gjøre.
Ellers hadde jeg sagt ja takk til meterlange hovedkort med 20 sloter, hadde desidert vært kjekt med 6x PCI-E spor, eller 3x for dual slot kort, og en drøss med PCI spor.
  • 4 måneder senere...
