Galt med login.php
Hei.
Jeg får opp en syntax error.
Parse error: syntax error, unexpected $end in C:\xampp\htdocs\xampp\test\login.php on line 81
Logginn.php
<?php
include ("config.php");
# Include the config.php file
if (empty($online['id'])){
# If they're not logged in already
if ($_POST['Login']) {
# If the login was made
$user = clean($_POST['username']);
# clean the username
$pass = clean($_POST['password']);
# clean the password
if (!$user | !$pass){
# if either of the fields are empty
echo 'You left a field empty. <a href="'.$_SERVER['REQUEST_URI'].'">Back</a>.';
else {
$pass = md5($pass);
Make the password a hash so hopefully it'll
be equal to atleast one of the passwords in
the database
$query = "SELECT * FROM `users` WHERE username = '$user' AND password = '$pass'";
$query = mysql_query($query);
# Select the row of the user logging in
if (mysql_num_rows($query) == 1){
# If a row with the right information is found...
$expire = time() + (7*86400);
# We'll set an expire time for the cookie, in this case a week.
setcookie("username", $user, $expire);
# Set a cookie for the username
setcookie("password", $pass, $expire);
# Set a cookie for the hashed password
echo 'Success, you have been logged in!<br />';
echo '<a href="cpanel.php">Continue</a>...';
# Give a message of success
else {
# If no rows were found with the given information
echo 'Incorrect username and password. <a href="'.$_SERVER['REQUEST_URI'].'">Back</a>.';
else {
# The form wasn't submitted
<form method="post" action="<?=$_SERVER['REQUEST_URI']?>">
 Username:<br />
 <input name="username" type="text" id="username">
 <br />
 Password:<br />
 <input name="password" type="password" id="password">
 <br />
 <input name="Login" type="submit" id="Login" value="Login">
</form>
else {
# They're already logged in
echo 'You are already logged in!';
Note, you could include the cpanel.php file here
Noen som veit hva feilen kan være? Jeg ser at koden er litt rotete men men :p
Skal vedde på at serveren har short_tags=Off og at det dermed er <? og <?= som er problemet (burde vært <?php ). Kan iallfall ikke umiddelbart se noe annet problem siden det, som Runar påpeker, mangler indentering i koden.
Endret av Ernie
Rydd opp i koden din (Indentering er en fin start) og post linje 81 og linjene rundt, så skal du nok se vi finner problemet.
Det funket vist etter at jeg kopierte koden min på den linken der :D
Glemte vist at jeg har kodet dette for noen år siden for en bedrift.
Anyway, takk!
