Den store Minecraft tråden! (Servere i førstepost, support i egne tråder!)
I got a problem. Alt står på bildet jeg legger ved.
Enkel løsning: Bytt ut AVG med Microsoft Security Essentials
Som TJ sa, falsk positiv.
Takk for svar uansett. Men jeg bare ventet til nå. Fungerer fint nå. Skjer det igjen, prøver jeg din løsning.
Changelog for Beta 1.3:
  • Delay/repeater blocks
  • Beds
  • Added three new half-size blocks (Wooden Plank, Cobblestone, Sandstone)
  • Slimes have a higher spawn rate (confirm?)
  • Wood and logs don't burn forever anymore.
  • New Mojang logo
  • Video settings screen
  • Ability to toggle between classic lighting and "smooth" lighting
  • Regions now use the McRegion format, with built-in auto conversion
  • While starting a new world, players can choose their own name and seed to generate the world
  • More than 5 Worlds possible
  • Added whitelisting to the server. To use, enter “whitelist <cmd>” where cmd is “on”, “off”, “add <player>”, “remove <player>”, “list” or “reload”
  • F1 now toggles
  • F1 in 3rd person mode also no longer flips view
  • F3 now toggles
  • When F3 is pressed, mobs display a number over their head (more info?)
  • F8 toggles mouse smoothing
  • In 3rd person mode, character can be visibly seen to bob side to side when you walk (only when View Bobbing is enabled).
  • Sandstone is now found at the bottom of naturally generated sand.
  • All pressure plates now require two of its materials, instead of 3. The new stone slabs are now created by using 3 of the materials (see specific block pages for further information)
  • Mine time for Sandstone decreased.
  • Redstone dust will get darker the farther away it is from a source of power.
  • New painting added of a flaming skull.
  • New block texture was added (no details on it yet).
    Bugfixes:
  • When breaking double slabs (one slab placed on another) it will drop two slabs instead of one.
    New Bugs:
  • Game may crash upon entering the Nether. When you reload you will be at spawn with no items.
  • Some users reporting worlds getting deleted (confirm?).
  • On a new world, torches disappear near spawn after death in a distant area. Placed torches in peaceful then switched to normal before dying (confirm?).
  • Levers can be placed on the bottom of a block, as long as there is an open space, and a block horizontal to the open space. The lever will act as if placed on the horizontal block, but looks glitched, as shown here: Media:Brokenlever.png
  • When someone lay down in his bed in Multiplayer, One or more players get an error and gets disconnected).
  • Wooden slabs must currently be collected with a pickaxe.
http://www.minecraftwiki.net/wiki/Version_History
Blir oppdatert fortløpende.
