Bruke PHP til bildelinker i WordPress
Har et lite problem i WordPress, og prøver lykken her på diskusjon.no. Har skrevet et innlegg på et annet forum som er på engelsk, så jeg gjør det enkelt og klipper og limer det rett inn her:
I've been using the following php code in my template files, and it's been working great.
<?php bloginfo('stylesheet_directory'); ?>/images/MyImage.png
When I go to the WordPress Dashboard > Pages > Add New and try to use it in my pages though, the image doesn't show up. I tried using this one as well:
<?php bloginfo('name'); ?>
but that doesn't work either.
Does anyone know what the problem might be? There surely must be a way to use the img-tag in pages and posts without having to use absolute image paths?
I need to add over a thousand images, so by using absolute paths, I risk having to do a lot of work later if I should move around some files, or rename the theme or something like that.
Håper noen kan hjelpe! :)
