RPM problem
[root@fanta:/home/shared/linux] $ rpm -Uvh *.rpm
Preparing...                ########################################### [100%]
package binutils-2.11.93.0.2-11 is already installed
package cpp-2.96-113 is already installed
package glibc-devel-2.2.5-42 is already installed
package glibc-kernheaders-2.4-7.16 is already installed
installing package ncurses-devel-5.2-26 needs 4Mb on the / filesystem
installing package patch-2.5.4-12 needs 4Mb on the / filesystem
installing package rpm-build-4.0.4-7x.18 needs 5Mb on the / filesystem
installing package zip-2.3-12 needs 5Mb on the / filesystem
installing package libgcj-2.96-29 needs 14Mb on the / filesystem
installing package libgcj-devel-2.96-29 needs 28Mb on the / filesystem
installing package gcc-java-2.96-113 needs 31Mb on the / filesystem
[root@fanta:/home/shared/linux] $ df -h
Filesystem            Size  Used Avail Use% Mounted on
/dev/hda3             802M  590M  171M  78% /
/dev/hda1              31M  5.9M   23M  20% /boot
none                   30M     0   30M   0% /dev/shm
Noen som kan fortelle meg hvorfor rpm pakkene ikke blir installert?
