nedgradere fra vista til xp gratis?
Vær obs at etter SP3 vil ikke XP få mer oppdateringer. Anbefaler heller at du installerer Windows 7 Pro, da får du med XP Mode gratis.
Men om du absolutt vil så:
1. Install the Machine with XP PRO Media and get any valid XP Product Key.
2. After finishing the installation, there will be 2 options for you to pick for the Windows Activation. Activate online or activate through Phone Call. Pick activate through Phone Call.
3. The system will show a series of Installation ID for activation.
4. Send an email to [email protected], and include all the information below:
- XP PRO Product Key and COA installed to the machine
- Vista Business/Ultimate Product Key and COA if possible
- XP Installation ID that shown in the system
- Customer information
5. Microsoft will verify the information and respond within 24 hours. (Common case is about 5-6 hours)
6. You will received an email from SEAPA, with the activation key. Key in the activation key.
KILDE
Endret av AvidGamer
