PciE x1 og x16
A PCIe card will fit into a slot of its physical size or larger, but may not fit into a smaller PCIe slot. Some slots use open-ended sockets to permit physically longer cards and will negotiate the best available electrical connection. The number of lanes actually connected to a slot may also be less than the number supported by the physical slot size. An example is a x8 slot that actually only runs at ×1; these slots will allow any ×1, ×2, ×4 or ×8 card to be used, though only running at ×1 speed. This type of socket is described as a ×8 (×1 mode) slot, meaning it physically accepts up to ×8 cards but only runs at ×1 speed. The advantage gained is that a larger range of PCIe cards can still be used without requiring the motherboard hardware to support the full transfer rate, which keeps design and implementation costs down.
Så for meg så virker dette ut som et ja. Så lenge PCI slotten er av samme størrelse eller større enn kortet, så skal det fungere.
kommer ann på hva man putter i PCie x16 porten, og hvilket brikkesett/produsent
funka ikke for meg å putte en silicon image 3132 basert pcie x1 kort i en x16 port på et MSI hovedkort med AMD 690G, men funka fint i Gigabyte 790FX hovedkort
